openfoam-2.3.0 on ubuntu natty 11.04
Like Tree1Likes
  • 1 Post By wyldckat
Old   July 27, 2014, 17:43
Default openfoam-2.3.0 on ubuntu natty 11.04
mike h
mickjazz is on a distinguished road
Hi
I have tried for some hours to make openfoam230 on an ubuntu 11.04 box. Problem is the repositories don't exist to install the dependent libraries etc. I built from source flex bison and quite a few more but got stuck on libreadline which is down the line dependent on libc6 which it turns out needs v15 or greater. But when i try to install libc6 v19 from deb it fails due to a conflict somewhere.
I'm beginning to think that to install new versions of openfoam one MUST update the os with it. on a machine dedicated to openfoam but on a workstation with many other software builds that a minimum will require a lot of fiddling to get to work on the updated os this seems unreasonable.
Question then : has anyone anywhere got openfoam230 to install on natty in the past few months or since 11.04 was sunsetted? if so, can you enlighten me as to what one needs for dependencies?
thx mike
i list the sources.list i have been using here. I swapped 'archive' for 'old-releases' but it didn't help.
# deb cdrom:[Ubuntu 11.04 _Natty Narwhal_ - Release amd64 (20110427.1)]/ natty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://us.old-releases.ubuntu.com/ubuntu/ natty main restricted
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://us.old-releases.ubuntu.com/ubuntu/ natty-updates main restricted
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://us.old-releases.ubuntu.com/ubuntu/ natty universe
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty universe
deb http://us.old-releases.ubuntu.com/ubuntu/ natty-updates universe
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://us.old-releases.ubuntu.com/ubuntu/ natty multiverse
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty multiverse
deb http://us.old-releases.ubuntu.com/ubuntu/ natty-updates multiverse
deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://us.old-releases.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
# deb-src http://us.old-releases.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu natty-security main restricted
deb-src http://security.ubuntu.com/ubuntu natty-security main restricted
deb http://security.ubuntu.com/ubuntu natty-security universe
deb-src http://security.ubuntu.com/ubuntu natty-security universe
deb http://security.ubuntu.com/ubuntu natty-security multiverse
mickjazz is offline   Reply With Quote
Old   August 5, 2014, 14:01
Retired Super Moderator
Bruno Santos
Greetings Mike,
Well, if you don't want to upgrade your Ubuntu installation every 6 months, then it's advisable to use one of the LTS (Long Term Service) versions of Ubuntu, such as 10.04, 12.04 or 14.04.
Because official support for Ubuntu 11.04 (aka Natty) ended on the 28th of October 2012: https://wiki.ubuntu.com/Releases
The deb packages of OpenFOAM for Ubuntu are only released for the most recent versions and/or LTS versions and usually only built when a new version of OpenFOAM is released. For example, only with OpenFOAM 2.3.1 will Ubuntu 14.04 be supported with a deb package.
Nonetheless, if you build OpenFOAM from source code, it's usually possible to continue using an outdated Ubuntu installation. For example, if you follow the instructions provided here: http://openfoamwiki.net/index.php/In...u#Ubuntu_10.04 - and adapt to using OpenFOAM 2.3.0 instead of 2.2.2, then you should still be able to build it on your Ubuntu Natty.
Best regards,
Bruno
babakflame likes this.
I cant find openfoam for ubuntu 14.04 LTS seju OpenFOAM Installation 15 August 30, 2014 13:07
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 12:46
openFOAM installation in ubuntu 11.10 kirubhakaran OpenFOAM Installation 5 February 17, 2012 03:16
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 11:14
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 StuntedChicken OpenFOAM Installation 1 January 9, 2011 11:43
