[OpenFOAM.org] Current directory is not $WM_PROJECT_DIR
Like Tree6Likes
  • 2 Post By cdm
  • 2 Post By cdm
  • 1 Post By ordinary
  • 1 Post By Alisa_W
Old   July 20, 2014, 06:36
Default Current directory is not $WM_PROJECT_DIR
zohreh imani nejad
imani is on a distinguished road
hi formers
i have of2.1.1
but now i want to install of2.3.0
i do all steps in the openFoam.com site
but i have this error
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
i read the page
http://www.cfd-online.com/Forums/ope...oject_dir.html
but i canot solve my problem
thanks
imani is offline   Reply With Quote
Old   July 22, 2014, 05:32
zohreh imani nejad
no one can help me?
Old   July 23, 2014, 18:51
cdm
cdm is on a distinguished road
Check what value is stored in the $WM_PROJECT_DIR.
echo $WM_PROJECT_DIR
If it is not the installation directory for openfoam230 (for e.g., /home/user/openfoam230/) then you need to source the openfoam230 bashrc.
Make sure you do not have the line
source $HOME/openfoam211/etc/bashrc
in your local bashrc file ($HOME/.bashrc).
If you do, you should change it to
alias foam211='source $HOME/openfoam211/etc/bashrc'
and add
alias foam230='source $HOME/openfoam230/etc/bashrc'
Then when you open a terminal, source the version you want to use by typing either foam211 or foam230.
Once this is set up, you can run ./Allwmake after sourcing the openfoam230 bashrc.
(The above assumes you installed OpenFOAM v2.3.0 in your user $HOME directory.)
Hope that helps.
ali_atrian and Shitiz like this.
cdm is offline   Reply With Quote
Old   July 24, 2014, 01:39
zohreh imani nejad
hi
thanks for your attention
when i run
i dont have any output in terminal .... just a blank line !!!! like bellow
dell@ubuntu:~$ echo $WM_PROJECT_DIR
dell@ubuntu:~$
i dont understand your meaning about local bashrc file
i have two bashrc file : one in openFoam2.1.1 file and other in openFoam2.3.0 file
in these basrc files i change end of it to :
alias of230='source $HOME/openfoam230/etc/bashrc'
alias of211='source $HOME/openfoam211/etc/bashrc'
when i put ./Allwmake in terminal
dell@ubuntu:~/OpenFOAM/OpenFOAM-2.3.0$ ./Allwmake
i have this output :
Old   July 24, 2014, 11:28
cdm
You need to add
in the file $HOME/.bashrc and not in the OpenFOAM etc/bashrc files. $HOME/.bashrc is your local bashrc file (for sourcing all scripts and environment variables, not just for OpenFOAM). If you don't have a .bashrc file, it may be under a different name depending on your Linux distribution. Google search should help you there.
Then, open a new terminal, type of230, and run ./Allwmake in the openfoam230 directory.
irwin and SHUBHAM9595 like this.
Old   July 24, 2014, 14:35
zohreh imani nejad
tanks alot
i found that bashrc file
Old   September 1, 2018, 11:02
王莹
Alisa_W is on a distinguished road
Hello, when I type ofv30(my second version), it said that cannot find that command. Could you help me ?
Originally Posted by imani View Post
tanks alot
Alisa_W is offline   Reply With Quote
Old   September 1, 2018, 15:43
Emre
ordinary is on a distinguished road
I think you have to first check your .bashrc file in your home folder. It is a hidden file so you should enable 'Show hidden files' button if you use window manager. The file named .bashrc must have an ending like @cdm said:
Originally Posted by cdm View Post
wyldckat likes this.
ordinary is offline   Reply With Quote
Old   September 1, 2018, 18:33
Retired Super Moderator
Bruno Santos
Adding to Emre's answer:
Old   September 2, 2018, 02:20
王莹
Thank you Emre, actually I have added the lines to my .bashrc file as cdm suggested.
alias ofdev='source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc'
alias ofv30='source $HOME/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc'
But it still failed. When I typed 'alias' in terminal, it showed two aliases above haven't been defined...
When I type 'echo $WM_PROJECT_DIR', my dir is still $HOME/openfoam/openfoam-dev(The version I have installed).
There is a strange thing: I have install openfoam-dev in my computer before, but in the ending of my .bashrc files, no "source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc" existed at first...
Old   September 2, 2018, 02:38
王莹
Thank you Bruno, I have done things as cdm and Emre suggested:
“alias ofdev='source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc'
alias ofv30='source $HOME/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc'”
was added to my ./bashrc file. But it still failed.
When I typed 'alias' in terminal, it showed two aliases above haven't been defined...In the link you gave me, I cannot find how to solve this problem.
Here is some information I get after I added two aliases in ./bashrc
1.When I type 'echo $WM_PROJECT_DIR', my dir is still $HOME/openfoam/openfoam-dev (The version I have installed).
2.There is a strange thing: I have installed openfoam-dev in my computer before, but at the very beginning, no "source $HOME/OpenFOAM/OpenFOAM-dev/etc/bashrc" existed in the ending of my .bashrc files...
Old   September 2, 2018, 10:23
Bruno Santos
Quick answer:
  1. Run the following command:
    grep -i "openfoam" ~/.bash*
    It will reveal the majority of the environments being loaded-in automatically. It might tell you that there is more than one file with lines referring to OpenFOAM.
  2. After you modify the ".bash*" files to all use alias, then start a new terminal and try checking again.
Old   September 2, 2018, 10:32
Smile
  #13
王莹
Thanks so much, Bruno! Now I have solved my problem and of v3.0+ is compiling in my book ^_^.
Quick answer:
Old   July 10, 2020, 11:30
pointdipole is on a distinguished road
Quick answer:
Bruno, thanks for your replies on this thread! I have the same issue as the above posters, except that I only have one OF installation (2.3.1) and therefore only one alias. GCC 5.4.0, CUDA 8.0, Ubuntu 16.04.
The specific error message is below. Thank you for your help!
Error: Current directory is not /root/OpenFOAM/OpenFOAM-2.3.1
pointdipole is offline   Reply With Quote
Old   July 11, 2020, 03:48
bestucan's Avatar
Tu Can
bestucan is on a distinguished road
"~" is a syombol refer to "$HOME"
and "$HOME" is home directory of a user.
"echo $HOME" will show what it is.
mostly, "$HOME" refer to "/home/<your user name>/"
specially, when user name is "root", "$HOME" refer to "/root/"
seems like you are using "sudo" or login as root. It's not recommend.
bestucan is offline   Reply With Quote
Old   August 25, 2020, 04:42
Ali Shayegh
amuzeshi is on a distinguished road
What does WM mean in the beginning of WM_PROJECT_DIR at all? Is it abbreviation for wmake?
amuzeshi is offline   Reply With Quote
Old   September 6, 2020, 04:10
Default 3.2.2.5 wmake environment variables
  #17
Rahul Vadrabade
Rvadrabade is on a distinguished road
Yes, More information is available at
https://cfd.direct/openfoam/user-gui...x10-730003.2.2
Rvadrabade is offline   Reply With Quote
Old   September 6, 2020, 09:19
Ali Shayegh
Thanks, but I want to know where does WM name originated from; what is the rational behind it? I have heard that this is abbreviated for "Weller Make"!
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
Error: Current directory is not $WM_THIRD_PARTY_DIR lapsednun OpenFOAM Installation 1 August 30, 2014 11:46
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 20:09
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
