[foam-extend.org] Error during the installation of foam-extend 3.1 |
July 18, 2014, 04:16 |
Baris (Heewa)
Rep Power: 13 |
Hi to all,
I am using openfoam version 2.2.2 with ubuntu 12.04 and tried to install foam-extend 3.1 using this instruction in this link by following the 2nd option: installation from source code: http://openfoamwiki.net/index.php/In...om_source_code 1st: i run the following command for ubuntu 12.04 at this link: http://openfoamwiki.net/index.php/In...end-3.1/Ubuntu 2nd: get the source code using following commands: Code:
cd ~ mkdir foam cd foam git clone git://git.code.sf.net/p/openfoam-extend/foam-extend-3.1 foam-extend-3.1 However when i tried to compile the code as indicated here: Code:
cd ~/foam/foam-extend-3.1 source etc/bashrc echo "alias fe31='source \$HOME/foam/foam-extend-3.1/etc/bashrc'" >> $HOME/.bashrc Code:
efs@efs-desktop:~/foam/foam-extend-3.1$ source etc/bashrc bash: /opt/foam-extend-3.1/bin/foamGetSystemInfo: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/etc/settings.sh: No such file or directory bash: /opt/foam-extend-3.1/etc/aliases.sh: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory Thanks in advance. B |
July 19, 2014, 03:12 |
#2 | |
Hi Baris
When you install foam-extend from a terminal with OpenFOAM settings, the error will occur. Could you try the following steps. 1. Comment out OpenFOAM2.2.2 related part from ~/.bashrc 2. Open a terminal windows 3. compile foam-extend Quote:
July 20, 2014, 00:06 |
Thank you
Baris (Heewa)
Rep Power: 13 |
Dear Nakagawa Sensei,
Thank you very much. Finally, i have compiled foam-extend and works well after your kind help. I would like to ask one thing more: After running any case of tutorial in foam-extend when i try to view the result using paraview all the time it shows the attached list "open data with.." if i choose the openfoam it shows the results properly. Just i would like to ask that is there any setting not to choose all the time "openfoam" option when i view the results in foam-extend. Thanks in advance. Baris |
October 24, 2014, 05:48 |
#4 | |
behzad Ghasemi
Rep Power: 13 |
I have same problem, but i didn't get this step 1. Comment out OpenFOAM2.2.2 related part from ~/.bashrc what should i do exactly? I'm amateur please explain more. I have not install any open foam version and i was trying to install extend 3.1 version on fedora 20 |
March 5, 2016, 09:50 |
GS
Rep Power: 10 |
exactly
what does this mean...? 1. Comment out OpenFOAM2.2.2 related part from ~/.bashrc confused |
March 6, 2016, 05:04 |
#6 | |
If you want to use multiple versions of OpenFOAM and/or foam, you should not read automatically the setting files for specific version. Instead, you can create aliases for openfoams and execute the alias which corresponds to the version you want to use. There are helpful pages … http://openfoamwiki.net/index.php/In...with_the_Shell http://www.cfd-online.com/Forums/ope...e-machine.html http://www.cfd-online.com/Forums/blo...vironment.html |
April 18, 2016, 07:37 |
Saideep
Rep Power: 12 |
Hi guys,
I installed OF-ext 3.1 in my Home and sourced my bash with an alias. Though the inbuilt libraries and solvers work, when I try to modify the code or use the existing code into another folder to compile that, I get this: relocation _ has invalid symbol index error. I guess I made a mistake somewhere but unable to find it out. Could anyone of you advice me!! Saideep |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 10:45 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
