OF 2.3.x libconformalVoronoiMesh Compilation Error |
June 16, 2014, 18:58 |
Brock Lee
Rep Power: 14 |
Foamers,
I'm attempting to compile OF 2.3.x (ddafa9836ad9) on RHEL 5.7 using GCC 4.9.0. Everything compiles fine except for a small portion of foamyHexMesh (the app that I wanted to test). I receive the following error... Code:
/home/brock/my_apps/binutils-2.24/bin/ld: /usr/lib/../lib64/libmpfr.a(clear.o): relocation R_X86_64_32 against `.text' can not be used when making a shared object; recompile with -fPIC /usr/lib/../lib64/libmpfr.a: error adding symbols: Bad value collect2: error: ld returned 1 exit status /apps/OpenFOAM/OpenFOAM-2.3.x/wmake/Makefile:172: recipe for target '/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libconformalVoronoiMesh.so' failed make[2]: *** [/apps/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libconformalVoronoiMesh.so] Error 1 make[2]: Target 'libso' not remade because of errors. The error notes to add -fPIC and recompile, however I have been unable to correctly identify where that needs to be added. Can anyone help me diagnose and fix this error? Thanks! Brock Last edited by GRAUPS; June 17, 2014 at 13:04. |
June 18, 2014, 12:41 |
Figured it out
Brock Lee
Rep Power: 14 |
Foamers,
I figured it out. I compiled CGAL with mpfr and gmp libraries that I placed in... Code:
ThirdParty-2.3.x/platforms/linux64 I ended up having to put the mpfr and gmp libraries I used to compile CGAL into $FOAM_SITE_LIBBIN so that they would get used instead of the system versions of mpfr and gmp. Cheers, Brock |
July 15, 2014, 07:02 |
alternatevly give wmake libso correct path
Andreas Ruopp
Rep Power: 17 |
I encountered the same problem: Code:
... /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: warning: libCGAL.so.10, needed by /mnt/fs2/home/bla/OpenFOAM23_susi12_3/OpenFOAM-2.3.x/platforms/linux64GccDPDebug/lib/libconformalVoronoiMesh.so, not found (try using -rpath or -rpath-link) ... Code:
... -lsampling \ -L$(WM_THIRD_PARTY_DIR)/platforms/linux64Gcc/CGAL-4.3/lib \ -lCGAL |
compile, error, foamyhexmesh |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 07:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
