Python support when building Paraview ?
Like Tree1Likes
  • 1 Post By francois
Old   June 16, 2014, 15:54
Default Python support when building Paraview ?
Francois Beaubert
francois is on a distinguished road
Hi all,
I've just switched from Ubuntu 13.10 to 14.04, so I build OpenFOAM from source with the excellent wiki page.
http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu
Everything seems OK in the compilation stage but it looks like Paraview was not build with Python support.
Did I miss something ?
Thank you very much.
François
francois is offline   Reply With Quote
Old   June 16, 2014, 16:00
Francois Beaubert
Is it the withPYTHON flag in the makeParaView4 build script ?
Old   June 16, 2014, 16:37
Francois Beaubert
I've used the following parameters in makeParaView4:
# Python support:
# note: script will try to determine the appropriate python library.
# If it fails, specify the path using the PYTHON_LIBRARY variable
withPYTHON=true
PYTHON_LIBRARY="/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0"
and I've got a fresh Paraview with Python support
Cheers
Romarius likes this.
[General] Building Paraview 4.1.0 with MPI and Python support reynoldsStress ParaView 10 July 27, 2017 09:38
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
[OpenFOAM] paraview v4 - building with python - OF2.3.0, PVv4, Python 2.7 aylalisa ParaView 4 June 13, 2014 09:52
How to get Python Shell into ParaView 3.8.1? blaise OpenFOAM Installation 3 July 24, 2012 05:58
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
