[OpenFOAM.com] paraFoam reader module libraries do not exist
Like Tree5Likes
  • 1 Post By wyldckat
  • 3 Post By wyldckat
  • 1 Post By sjtuwjh
Old   March 13, 2014, 06:18
Default paraFoam reader module libraries do not exist
Wang Jianhua
sjtuwjh is on a distinguished road
When doing post-processing with paraview, there always is problem shown below after I type the command 'paraFoam'.
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
After I doing what the terminal suggest me to do, but there is no help. Is there anyone who can help me handling this?
sjtuwjh is offline   Reply With Quote
Old   March 15, 2014, 06:24
Retired Super Moderator
Bruno Santos
Greetings Wang Jianhua and welcome to the forum!
Please provide the following information:
  1. Which Linux Distribution are you using?
  2. Which OpenFOAM version are you using?
  3. Which installation instructions did you follow for installing OpenFOAM?
Best regards,
Bruno
Usman15 likes this.
Old   March 17, 2014, 04:25
Default Reply
Wang Jianhua
Best regards,
Bruno
Hello!
I am now using the ubuntu13.10, and the version of my openfoam is 2.0.1. I downloaded the deb package, and then installed it, I wish you can help me solving this problem!
Best regards!
Wang Jianhua
Old   March 22, 2014, 06:14
Bruno Santos
Hi Wang Jianhua,
Is there a specific reason why you must use the version 2.0.1 of OpenFOAM? Because there have been already several new features added to OpenFOAM in the latest versions, as well as plenty of bug fixes.
Anyway, to fix the problem, run these commands (one line at a time):
sudo -s
apt-get install paraview
cd /opt/openfoam201/bin
sed -i -e 's/requirePV=1/requirePV=0/' -e 's/extension=OpenFOAM/extension=foam/' paraFoam
exit
If all goes well, you should now be able to use paraFoam.
Best regards,
Bruno
Usman15, sjtuwjh and PumBlum like this.
Old   March 24, 2014, 13:51
Tom
RTom is on a distinguished road
Hi I have the same problem with OpenFOAM 2.3.0, the instalation was ok and I can do the Processing without troubles, but when I execute the "paraFoam" it shows me this:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
./Allwclean
./Allwmake
My Linux is Ubuntu 12.04, Processor: AMD 64bits
Also I have installed the OpenFOAM 2.2.1 and 2.2.2, but those are not activated. I make sure to let in the .bashrc file just source /opt/openfoam230/etc/bashrc
RTom is offline   Reply With Quote
Old   March 26, 2014, 17:27
Bruno Santos
Quick answer:
  1. Which installation instructions did you follow?
  2. Did you try running the commands indicated by paraFoam?
Old   March 27, 2014, 12:26
Tom
1) I followed the instructions from http://www.openfoam.org/download/ubuntu.php
But I installed the OpenFOAM 2.3.0 and the next day I turn on my laptop and installed Paraview 4.10 with:
sudo apt-get install paraviewopenfoam410
2) It works properly using:
paraFoam -case <caseName>
However it should works well with just typing from the case directory:
paraFoam
Like the others OpenFOAM versions I had. At least It works, I can use it in that way. Thanks!
Old   March 28, 2014, 01:52
Tom
After use:
paraFoam -builtin
It's all ok. Now PARAFOAM works fine
Old   March 28, 2014, 08:49
Wang Jianhua
Hi Wang Jianhua,
sudo -s
exit
Best regards,
Bruno
Hi wyldckat,
After following what you have said, now my paraFoam can run again, thank you very much. Because our solver is developed on the version 2.0.1. So I have to use this version since we didn't update our solver. Finally, I am very appreciate your enthusiastic help.
Best regards!
Usman15 likes this.
Old   March 28, 2014, 10:35
Wang Jianhua
One more question, after I do as what you have said, my paraFoam cannot reading from the keyboard. I don't know why, but if I open the paraview just like before: typing paraview, it can be readable from the keyboard. What's the reason?
Old   March 28, 2014, 18:15
Bruno Santos
Quick answer - try running like this:
paraFoam &
Old   April 9, 2014, 08:37
Wang Jianhua
paraFoam &
I just have tried this way, there is no help. So any other way to solve this problem? I don't understand why it could not type in?
Old   April 10, 2014, 16:47
Bruno Santos
Mmm... well, the first detail is that the ampersand "&" will launch the application as a background job, in the sense that the job will be running without locking out keyboard control from the terminal window.
The second detail is that you might be loosing keyboard control inside the terminal window if the ParaView window gains keyboard focus. If this is the case, it means that you will have to click in the textual part the terminal window.
Old   April 25, 2014, 10:36
Namsu
Usman15 is on a distinguished road
Dear Bruno Santos,
Thank you very very very much. I was facing the same problem in using paraFoam but your valuable post solved my problem.
Some information about my installed packages:
1. ubuntu 14.04 LTS
2. OpenFOAM-2.1.1
3. To install OpenFOAM-2.1.1 I followed the instructions from:
http://www.openfoam.org/archive/2.1....oad/source.php
4. Paraview-4.1.0
5. To install Paraview-4.1.0 I followed the instructions from:
The error which I was getting:
./Allwclean
./Allwmake
I used this to solve my problem:
sudo -s
cd /opt/openfoam211/bin
exit
Once again many thanks
Usman
Usman15 is offline   Reply With Quote
Old   May 6, 2016, 14:55
alex
crusen mind is on a distinguished road
well I also faced the same probelm
type "paraFoam -builtin"
works like a charm. Thanks for all the support.
crusen mind is offline   Reply With Quote
fatal error, parafoam
Why is my rhopimplefoam crashing? marxlolop OpenFOAM Running, Solving & CFD 1 January 6, 2019 17:39
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS matheusmonjon OpenFOAM Installation 3 February 25, 2017 15:46
FATAL ERROR: ParaView reader module libraries do not exist ciaci88 OpenFOAM Pre-Processing 3 November 4, 2016 05:39
Parafoam - FATAL ERROR: ParaView reader module libraries do not exist Amit_Pawarpawar OpenFOAM Installation 1 August 25, 2014 11:31
FATAL ERROR: ParaView reader module libraries do not exist adarsh tiwari OpenFOAM Installation 6 April 5, 2014 12:47
