November 2, 2013, 12:49 |
OpenFOAM on arm7 processor
Jon Elvar Wallevik
Rep Power: 20 |
Hello fellow foamers
I recently bought my first arm unit, more specifically a very small desktop called "trim-slice pro". It has arm version 7 (more precisely the NVIDIA Tegra2 Dual Core Arm Cortex A9 1GH). After upgrading to Ubuntu 12.04 I quickly started to wonder if it was possible to compile OF 2.2.x (using git pull) on it. before the compilation I did the following: sudo ln -s /usr/bin/make /usr/bin/gmake sudo ln -s /lib/arm-linux-gnueabihf/libz.so.1 /usr/lib/libz.so.1 sudo ln -s /lib/arm-linux-gnueabihf/libc.so.6 /lib/libc.so.6 I did the above because /usr/bin/gmake, /usr/lib/libz.so.1 and /lib/libc.so.6 did not exist. After about 12 to 13 hours of compiling (using "export WM_NCOMPPROCS=2"), everything seemed fine. The only problems occurs if I try to compile paraview, which is not really important. There are no errors (except for paraview) in my wmake log file. However, when I go to the tutorial cases, it is as the binaries do nothing (the binaries do exist!). For example, doing a blockMesh in the icoFoam example gives nothing. Also, foam2vtk gives nothing. Nothing happens when starting icoFoam. The same applies for the other tutorial cases like interFoam. Have any of you had the same problem? Cheers Jon p.s. the wmake log file is from 2 days ago, from my last git pull. |
November 2, 2013, 16:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Jon,
Nice! I've always wondered if OpenFOAM runs on the latest generations of ARM processors. If I understood you correctly, you're compiling OpenFOAM directly on that small desktop computer, correct? Because (theoretically) is should be possible to cross-compile on an i686/x86_64 processor and then pass the resulting binaries to the target machine, which is why I'm asking just to confirm this. So, the first thing to check is: do the binaries see the library files? You can check this by running: Code:
ldd $(which blockMesh) Code:
blockMesh echo $? Code:
blockMesh -help Best regards, Bruno
November 3, 2013, 17:07 |
Jon Elvar Wallevik
Rep Power: 20 |
Thanks for the quick reply Bruno
Yes I did compile OpenFOAM directly on that small desktop! The arm is RISK, while the Intel x86 is CISC, so I dont think it will work to transfer the binaries directly. Unfortunately "ldd $(which blockMesh)" gave nothing. "blockMesh && echo $?" gave 1 (probably an error mark) "blockMesh -help" gave nothing, unfortunately Thus there is something fundamental wrong. Thanks |
November 3, 2013, 17:32 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Jon,
Mmm... strange that ldd didn't give any feedback. OK, then let's go down to the basics:
Bruno
November 4, 2013, 16:21 |
Jon Elvar Wallevik
Rep Power: 20 |
Hallo Bruno
First, thanks for the info about the cross-compilation tools. This could be a really good solution. As you suggested I did the points you asked. Here are the results: (1) which blockMesh, gives... /home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/bin/blockMesh (2) run with the full path gave no output (3a) echo $PATH, gives... /home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/gperftools-svn/bin:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/paraview-3.12.0/bin:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/openmpi-1.6.3/bin:/home/jonelvar/OpenFOAM/jonelvar-2.2.x/platforms/linuxARM7GccDPOpt/bin:/home/jonelvar/OpenFOAM/site/2.2.x/platforms/linuxARM7GccDPOpt/bin:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/bin:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/bin:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/wmake:/usr/local/bin:/usr/bin:/bin:/usr/games:/home/jonelvar/bin (3b) echo $LD_LIBRARY_PATH, gives... /home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/gperftools-svn/lib:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/paraview-3.12.0/lib/paraview-3.12:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/lib/openmpi-1.6.3:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7GccDPOpt/lib/openmpi-1.6.3:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/openmpi-1.6.3/lib:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7Gcc/openmpi-1.6.3/lib32:/home/jonelvar/OpenFOAM/jonelvar-2.2.x/platforms/linuxARM7GccDPOpt/lib:/home/jonelvar/OpenFOAM/site/2.2.x/platforms/linuxARM7GccDPOpt/lib:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/lib:/home/jonelvar/OpenFOAM/ThirdParty-2.2.x/platforms/linuxARM7GccDPOpt/lib:/home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/lib/dummy (4) file $(which blockMesh), gives... /home/jonelvar/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxARM7GccDPOpt/bin/blockMesh: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.31, BuildID[sha1]=0x495a6955bdae3820686a0741dccfd0fed31a68fb, not stripped Curiously, this line has "for GNU/Linux 2.6.31", while the linux version during compilation was 3.1.10. B.t.w. I have been wondering if I should try to squeeze Fedora 19-ARM into the small pc, and try again. The fedora folks seem to be very committed to the arm architecture. But Im not sure, since I really like the Ubuntu-ARM (we will see what I will decide). Cheers Jon |
November 4, 2013, 17:47 |
Bruno Santos
Rep Power: 128 |
Hi Jon,
The 2.6.31 reference might be the minimum compatible kernel version, or the minimum GLIBC version. Well, there are a few more possibilities that come to mind:
Bruno
November 5, 2013, 12:00 |
Jon Elvar Wallevik
Rep Power: 20 |
Hallo again Bruno and thanks for the replies so far.
Here are the results: ------------------------------------------------ 1. "blockMesh > log 2>&1" gives nothing and the "log" file is empty. ------------------------------------------------ 2. "ulimit -a" gives core file size (blocks, -c) 0 data seg size (kbytes, -d) unlimited scheduling priority (-e) 0 file size (blocks, -f) unlimited pending signals (-i) 4743 max locked memory (kbytes, -l) 64 max memory size (kbytes, -m) unlimited open files (-n) 1024 pipe size (512 bytes, -p) 8 POSIX message queues (bytes, -q) 819200 real-time priority (-r) 0 stack size (kbytes, -s) 8192 cpu time (seconds, -t) unlimited max user processes (-u) 4743 virtual memory (kbytes, -v) unlimited file locks (-x) unlimited ------------------------------------------------ 3. "mv openmpi-1.6.3/ z1234", gives no change, tried both with blockMesh and icoFoam. thus libPstream.so is not being called, regardless. ------------------------------------------------ 4. Yes I have source in both C++ and Fortran and these compile and run just fine. ------------------------------------------------ I am starting to think this is a dead end. This is not a critical thingi (is more a curiosity), since I will acces my main OpenFOAM computers through ssh on this small device. Cheers Jon |
November 5, 2013, 18:02 |
Bruno Santos
Rep Power: 128 |
Hi Jon,
Well, unfortunately I'm all out of ideas. Well, at least ideas that don't require a lot of fiddling with OpenFOAM's source code. I am curious to know how good/bad it would perform on ARM type processors, but I guess it will still take a while to get there . Although that "armv71" entry in "etc/config/settings.sh" - https://github.com/OpenFOAM/OpenFOAM...ttings.sh#L117 - does give me hopes as well that said future is closer than we might imagine Best regards, Bruno
November 6, 2013, 08:04 |
#9 |
Jon Elvar Wallevik
Rep Power: 20 |
Great news Bruno
(at least I think this is it) I was testing the opt parameters on some Fortran code I have. Without optimization, the Fortran code runs, and with the Openfoam optimization, the code don't run, don't do anything just as in the OpenFOAM case above. By testing back and forth, then with "-mfloat-abi=hard" the Fortran code runs as normal, while with the standard OpenFOAM "-mfloat-abi=softfp" the code is silent and don't do anything. The softfp is supposed to be backward compatible to the soft-float OS (like Ubuntu 11.10 arm), as well to the new float architecture hard-float OS (like Ubuntu 12.04 arm and Fedora 18/19 arm). But apparently its not! In my case, I have to use "-mfloat-abi=hard" for the code to run. I am going recompile OF with the new parameter and I will report back to you as soon as I'm finished. Cheers Jon |
November 10, 2013, 19:43 |
#10 |
Jon Elvar Wallevik
Rep Power: 20 |
Great news Bruno!
OpenFOAM now compiles, I have just tested interFoam and icoFoam, both runs without problems thus, the approach is 1) cd OpenFOAM-2.2.x/wmake/rules/linuxARM7Gcc 2) nedit cOpt c++Opt & In c++Opt, then the following should be valid: ------------------------- c++DBUG = c++OPT = -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -mcpu=cortex-a9 -mfpu=vfpv3-d16 -mfloat-abi=hard #c++OPT = -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -mcpu=cortex-a9 -mfpu=vfpv3-d16 -mfloat-abi=softfp ------------------------- The second lines was already present but commented (i.e. with #), thus the OpenFOAM developers already had the hard-float thingi in mind. ...same for the cOpt... ------------------------- c++DBUG = c++OPT = -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -mcpu=cortex-a9 -mfpu=vfpv3-d16 -mfloat-abi=hard #c++OPT = -O3 -floop-optimize -falign-loops -falign-labels -falign-functions -falign-jumps -fprefetch-loop-arrays -mcpu=cortex-a9 -mfpu=vfpv3-d16 -mfloat-abi=softfp ------------------------- ... again the second line was already present. It is just about commenting and uncomennting the lines. Now in my case I did... 3) export WM_NCOMPPROCS=2 4) foam 5) ./Allwmake You have to repeat step 5 without step 3 above (of course with a new terminal). P.s. paraview did not compile. This is OK, since I just use "foamToVTK" and thereafter "paraview &" Now I have ultra small device that fits into my pocked that includes the newest version of OpenFOAM Cheers Jon |
November 15, 2013, 03:26 |
#11 |
Bruno Santos
Rep Power: 128 |
Hi Jon,
This is Awesome! Many thanks for sharing this information! By the way, from your description, it seems that you are able to run ParaView on your small machine? Did you install ParaView by using Ubuntu's package manager? Best regards, Bruno
November 19, 2013, 19:16 |
#12 |
Jon Elvar Wallevik
Rep Power: 20 |
Hi again Bruno and sorry for the late reply. The answer to your last question is yes.
I.e. sudo apt-get install paraview (using /etc/apt/sources.list), with no problems Cheers Jon |
arm, armv7 |
Problem with parallel run | Hisham | OpenFOAM Running, Solving & CFD | 9 | March 13, 2012 09:31 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 06:26 |
OpenFOAM 14 stock version parallel bug | msrinath80 | OpenFOAM Bugs | 2 | May 30, 2007 15:47 |
Parallel LES computation stops with reason | vvqf | OpenFOAM Running, Solving & CFD | 4 | March 6, 2006 08:55 |
