Can different OpenFOAM versions share the same ParaView? |
July 4, 2013, 11:19 |
Ye Zhang
Rep Power: 17 |
Dear all,
There are two versions OpenFOAM in my computer, OpenFOAM-2.1.1 and OpenFOAM2.2. When I turn on OpenFOAM-2.1.1 version, I can use ParaView(ParaFoam) to do post-processing. While I switch to OpenFOAM-2.2, I can not use ParaFoam, and it says 'FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake I can not see the ParaView folder under openfoam-2.2/ThirdParty/, but there is in openfoam-2.1/ThirdParty. So my question is How can I use shared paraView for both versions? Best regards, Ye |
July 5, 2013, 05:30 |
Anton Kidess
Rep Power: 30 |
The easiest way in my opinion is to not use paraFoam, but use paraview with the native reader instead. All you have to do is create an empty *.foam file in the case directory, and you will be able to open it with paraview.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
July 7, 2013, 09:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
To complement Anton's response: http://www.cfd-online.com/Forums/ope...tml#post425147 post #4 In addition, it is possible to use the same custom build version for both installations, if you follow these steps (note: I haven't tested them yet):
Bruno
July 8, 2013, 03:21 |
Ye Zhang
Rep Power: 17 |
Dear Anton and Bruno,
Many thanks for your help. Now I can use Paraview in OpenFOAM 2.2.0. Thank you! Best regards, Ye |
July 23, 2021, 10:20 |
Leon
I am running cases on amazon servers and viewing the results on my own PC. The two versions of openFOAM are different, and it wouldn't allow me to use paraFoam because the headers were different. Creating an empty empty.foam file, opening that in paraview and skipping to last timestep worked! No idea why. But cheers
How to install two versions of OpenFoam | Argen | OpenFOAM Installation | 25 | August 9, 2012 16:25 |
OpenFOAM v.2.x Courant Number 4 time higher then in previous versions | makaveli_lcf | OpenFOAM Running, Solving & CFD | 8 | February 18, 2012 22:28 |
Can't get older versions of OpenFOAM | fabioc | OpenFOAM Installation | 4 | February 7, 2012 10:13 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
Qt version of Paraview 3.8.0 in OpenFOAM 1.7 | waynezw0618 | OpenFOAM Installation | 10 | March 3, 2011 09:53 |
