June 19, 2013, 05:10 |
OpenFOAM does not work any more!
Ye Zhang
Rep Power: 17 |
Dear guys,
I have been using OpenFOAM2.1.0 for a while. But suddenly it does not work after I am trying to compile the utility foamToTecplot360. I think this is the reason which caused OpenFOAM can not work properly.... It gives the error: icoFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory I use "foamInstallationTest " to test, and get: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: tud204501 OS: Linux version 3.0.51-0.7.9-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /opt/apps/openfoam-2.1.0 yes yes $WM_PROJECT_USER_DIR /home/yzhang13/OpenFOAM/yzhang13-2.1.0 yes no $WM_THIRD_PARTY_DIR /home/yzhang13/OpenFOAM/ThirdParty-2.1.0 yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0 yes yes yes $FOAM_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN .../2.1.0/platforms/linux64GccDPOpt/bin no no $FOAM_USER_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin yes yes no $WM_DIR .../openfoam-2.1.0/OpenFOAM-2.1.0/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib yes yes yes $FOAM_SITE_LIBBIN .../2.1.0/platforms/linux64GccDPOpt/lib no no $FOAM_USER_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib yes yes no $MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.5.3 no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.3.4 /usr/bin/gcc gzip 1.3.12 /usr/bin/gzip tar 1.26 /bin/tar icoFoam ...0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. Done Can someone guide me to fix the problem? Thank you in advance! Best regards, Ye |
June 19, 2013, 06:20 |
Ye Zhang
Rep Power: 17 |
Dear Laurence,
Thank you for your reply. OpenFOAM works perfectly before I am trying to add utility foamToTecplot360. I added this utility maybe also added ThirdParty package (I can not remember.....). Because I remembered that there is no ThirdParty folder in my user folder before..... but now, there it is. Hope this gave you some information. Thanks! Best regards, Ye |
June 19, 2013, 09:29 |
Ye Zhang
Rep Power: 17 |
Dear Laurence,
First of all, thank you so much! The output looks like: echo $MPI_ARCH_PATH /home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3 echo $WM_MPLIB OPENMPI echo $LD_LIBRARY_PATH | tr -s ' ' '\n' /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3/lib:/home/yzhang13/OpenFOAM/yzhang13-2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/site/2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/dummy:/usr/lib64/mpi/gcc/openmpi/lib64:/usr/lib64/mpi/gcc/openmpi/lib64/ locate libmpi.so /usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.0 /usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.0.0.3 Best regards, Ye |
June 19, 2013, 15:38 |
Laurence R. McGlashan
Rep Power: 23 |
It should be picked up then.
Does you $MPI_ARCH_PATH have anything in it? Your WM_MPLIB is OPENMPI so you should have openmpi installed in the ThirdParty folder. If you want to use the system openmpi libraries then change WM_MPLIB to SYSTEMOPENMPI. Can you then also do: ldd $(which icoFoam)
Laurence R. McGlashan :: Website |
June 20, 2013, 17:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Just passing by to say that building foamToTecplot360 shouldn't have lead to such a big confusion It would have been as simple as following the instructions provided here: https://github.com/wyldckat/localFoamToTecplot360 Best regards, Bruno
June 20, 2013, 19:48 |
Ye Zhang
Rep Power: 17 |
Dear Laurence,
Sorry for the delay. Thanks! Today I tried to change WM_MPLIB to SYSTEMOPENMPI. But I can not edit /etc/bashrc file due to no permission(I can not change this situation in our faculty). Probably this means the original option is WM_MPLIB, am I right? So maybe this is no the reason result in this problem?? To be mentioned, I have also installed OpenFOAM-1.6-ext version, and it works good. I check /etc/bashrc file, and the option is SYSTEMOPENMPI..... So I am confused..... By the way, I also check ldd $(which icoFoam) as you said, and it gives: linux-vdso.so.1 => (0x00007fff75bff000) libfiniteVolume.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so (0x00007f2d8a209000) libOpenFOAM.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so (0x00007f2d89ae7000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f2d8989e000) libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f2d89593000) libm.so.6 => /lib64/libm.so.6 (0x00007f2d8931a000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f2d89104000) libc.so.6 => /lib64/libc.so.6 (0x00007f2d88d8c000) libPstream.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so (0x00007f2d88b81000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f2d88964000) libtriSurface.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libtriSurface.so (0x00007f2d886ef000) libmeshTools.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so (0x00007f2d8824d000) libz.so.1 => /lib64/libz.so.1 (0x00007f2d88037000) /lib64/ld-linux-x86-64.so.2 (0x00007f2d8b277000) libmpi.so.1 => not found libfileFormats.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfileFormats.so (0x00007f2d87e2e000) Best regards, Ye |
June 20, 2013, 19:53 |
#9 |
Ye Zhang
Rep Power: 17 |
Dear Bruno,
Thanks for your reply. I am quite sure that OpenFOAM does not work after I tried to compile this utility as the guideline in this forum. Because of no permission as ordinary user in my office computer, I failed to compile it. After that, OpenFOAM stoped working.... Hope you can help me! Thanks! Best regards, Ye |
June 23, 2013, 12:55 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Ye,
If the "WM_THIRD_PARTY_DIR" variable is pointing to the "ThirdParty-2.1.0" folder in your home path, then you clearly modified something critical. What changes have you made to the file "$HOME/.bashrc"? You can see the path to the file I'm talking about by running: Code:
echo $HOME/.bashrc Notice that this is a folder named ".OpenFOAM", not "OpenFOAM"! Best regards, Bruno
June 24, 2013, 05:32 |
#11 |
Ye Zhang
Rep Power: 17 |
Dear Bruno,
Thanks for your help! Indeed, there is folder under $HOME/.OpenFOAM which named 2.1.0, and there is a file 'prefs.sh' in it. The phase in the file is: export WM_THIRD_PARTY_DIR=/home/yzhang13/OpenFOAM/ThirdParty-2.1.0 Is it the reason which caused OpenFOAM does not work? Thank you again, Bruno. Best regards, Ye |
June 24, 2013, 17:31 |
#12 |
Bruno Santos
Rep Power: 128 |
Hi Ye,
Yes, once you remove that file 'prefs.sh' and start a new terminal, OpenFOAM 2.1.0 should work properly once again. As for foamToTecplot360, when you followed the instructions from here: https://github.com/wyldckat/localFoamToTecplot360 - at which step were you not able to follow? Did you try the instructions from section "Using Zip or Tar"? Best regards, Bruno
June 25, 2013, 03:56 |
#13 |
Ye Zhang
Rep Power: 17 |
Dear Bruno,
Thank you! OpenFOAM worked again after I removed the file! I am not sure at which step I failed to install foamToTecplot360. I think that I don't have write permission on my office computer, because I have compiled it successfully on my own laptop. Thank you again, Bruno. Best regards, Ye |
how does the I/O work in OpenFOAM? | goodkid | OpenFOAM | 8 | October 27, 2011 12:39 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
OpenFOAM Training in Europe and USA | hjasak | OpenFOAM | 0 | August 8, 2008 06:33 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 22:07 |
