Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 |
May 20, 2013, 03:24 |
Angus Hutchison
Rep Power: 13 |
Hey everyone,
I'm a complete beginner with Ubuntu having always been a windows user, but I require OpenFOAM for my thesis. I'm having trouble with the installation of OpenFOAM 2.2.0 in Ubuntu 12.10 using the i686 architecture. I have tried both Deb and Source pack installations but I cant get either to work. I have tried installing by following the steps in this link http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu but there is no 3rd step for i686. I would like to know: what is the difference between deb pack and source pack installation? Which one do I use? How to install OpenFOAM 2.2.0 for ubuntu 12.10 using i686 Much appreciated, please remember I am completely new to this! |
May 20, 2013, 18:14 |
#2 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Angus,
Building from source gives the ability to build on any Linux Distribution, as well as having more control on how things are built. It also makes it easier to modify the source code and build it again. As I wrote in the beginning, you can continue to follow the instructions for i386/i686. Or you can give some more information on what happened when you tried to install the Deb pack version. Best regards, Bruno
May 21, 2013, 20:21 |
Amir
Rep Power: 14 |
Guys,
Can you help me how I can install UBUNTO and OPEN FOAM? Thanks, Amir |
May 21, 2013, 23:44 |
#4 | |
Angus Hutchison
Rep Power: 13 |
Step 1 - ubuntu@ubuntu:~$ VERS=$(lsb_release -cs) ubuntu@ubuntu:~$ sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list" Step 2 - ubuntu@ubuntu:~$ sudo apt-get update Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal InRelease Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/main Translation-en_US Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/main Translation-en Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/restricted Translation-en_US Ign cdrom://Ubuntu 12.10 _Quantal Quetzal_ - Release i386 (20121017.2) quantal/restricted Translation-en Ign http://security.ubuntu.com quantal-security InRelease Ign http://archive.ubuntu.com quantal InRelease Ign http://www.openfoam.org quantal InRelease Ign http://archive.ubuntu.com quantal-updates InRelease Hit http://security.ubuntu.com quantal-security Release.gpg Ign http://www.openfoam.org quantal Release.gpg Hit http://archive.ubuntu.com quantal Release.gpg Hit http://security.ubuntu.com quantal-security Release Get:1 http://archive.ubuntu.com quantal-updates Release.gpg [933 B] Ign http://www.openfoam.org quantal Release Hit http://security.ubuntu.com quantal-security/main i386 Packages Hit http://archive.ubuntu.com quantal Release Ign http://www.openfoam.org quantal/main i386 Packages/DiffIndex Get:2 http://archive.ubuntu.com quantal-updates Release [49.6 kB] Hit http://security.ubuntu.com quantal-security/restricted i386 Packages Hit http://security.ubuntu.com quantal-security/main Translation-en Hit http://archive.ubuntu.com quantal/main i386 Packages Hit http://archive.ubuntu.com quantal/restricted i386 Packages Hit http://security.ubuntu.com quantal-security/restricted Translation-en Hit http://archive.ubuntu.com quantal/main Translation-en Hit http://archive.ubuntu.com quantal/restricted Translation-en Get:3 http://archive.ubuntu.com quantal-updates/main i386 Packages [235 kB] Ign http://security.ubuntu.com quantal-security/main Translation-en_US Ign http://security.ubuntu.com quantal-security/restricted Translation-en_US Hit http://www.openfoam.org quantal/main i386 Packages Ign http://www.openfoam.org quantal/main Translation-en_US Ign http://www.openfoam.org quantal/main Translation-en Get:4 http://archive.ubuntu.com quantal-updates/restricted i386 Packages [4,841 B] Hit http://archive.ubuntu.com quantal-updates/main Translation-en Hit http://archive.ubuntu.com quantal-updates/restricted Translation-en Ign http://archive.ubuntu.com quantal/main Translation-en_US Ign http://archive.ubuntu.com quantal/restricted Translation-en_US Ign http://archive.ubuntu.com quantal-updates/main Translation-en_US Ign http://archive.ubuntu.com quantal-updates/restricted Translation-en_US Fetched 291 kB in 12s (24.0 kB/s) Reading package lists... Done Step 3 - ubuntu@ubuntu:~$ sudo apt-get install openfoam220 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: openfoam220 : Depends: csh but it is not installable Depends: libopenmpi1.3 but it is not installable Depends: libptscotch-5.1 but it is not installable Depends: libscotch-5.1 but it is not installable Depends: libscotch-dev but it is not installable Depends: libopenmpi-dev but it is not installable Depends: openmpi-bin but it is not installable Recommends: libptscotch-dev but it is not installable E: Unable to correct problems, you have held broken packages. Which is where i think things are going wrong (step 3) |
May 22, 2013, 19:40 |
Bruno Santos
Rep Power: 128 |
Hi Angus,
The "universe" repository isn't turned on. For more information on how to turn it on: http://askubuntu.com/questions/78613...e-command-line After turning it back on, don't forget to do step #2 once again! Best regards, Bruno
May 22, 2013, 20:53 |
Angus Hutchison
Rep Power: 13 |
Hi Bruno,
Everything seems to be installing quite nicely now, thank you very much! You're probably my favourite person at the moment! Gus |
June 4, 2013, 13:11 |
SBR
Rep Power: 13 |
My problem in installing the OpenFOAM was solved. Best Regards Last edited by Sbr_CFD; June 4, 2013 at 20:00. Reason: The problem solved |
[Discussion] Restructuring the Installation page at openfoamwiki.net | wyldckat | OpenFOAM Installation | 16 | November 2, 2013 12:43 |
OF-1.6-ext: compiling fails on ubuntu 12.10 | A.Wendy | OpenFOAM Installation | 1 | March 22, 2013 07:47 |
Ubuntu 12.10 64bit: To compile or not? | CrazyFatDude | OpenFOAM Installation | 2 | January 14, 2013 05:18 |
Installing OpenFOAM 2.1 and enGrid | aerospain | OpenFOAM Installation | 7 | April 1, 2012 06:19 |
Trouble with installing OpenFOAM on Ubuntu | Milos | OpenFOAM Installation | 16 | November 16, 2009 03:44 |
