how to disable paraview in ThirdParty
Like Tree2Likes
  • 2 Post By wyldckat
Old   March 25, 2013, 21:02
Default how to disable paraview in ThirdParty
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I would like to use paraview-3.98. I installed it from OpenSUSE.org website. I have not problem running paraview-3.98 when logged in as root. However, with the "source $HOME/OpenFOAM/OpenFOAM-2.2.x/etc/bashrc" in my user .bashrc, I got conflicts, hence, paraview-3.98 gave me errors.
If I do not source OpenFOAM-2.2.x/etc/bashrc, then, paraview-3.98 ran fine. Is there a good way to disable paraview in ThirdParty?
Thanks!
Pei-Ying
phsieh2005 is offline   Reply With Quote
Old   March 27, 2013, 17:58
Retired Super Moderator
Bruno Santos
Hi Pei-Ying,
There are at least two possibilities:
  • Comment out the respective line in OpenFOAM's etc/bashrc file: https://github.com/OpenFOAM/OpenFOAM...tc/bashrc#L214
    Something like this:
    # _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/paraview.sh`
  • Or remove or move completely the built binaries:
    1. Check if it's there:
      echo $ParaView_DIR
      ls -l $ParaView_DIR
    2. Move it or remove it:
      mv $ParaView_DIR ${ParaView_DIR}_backup
      #or to remove it, uncomment the next line
      #rm -r $ParaView_DIR
You might also want to add an alias command to your "~/.bashrc" file:
alias paraFoam='paraFoam -builtin'
Best regards,
Bruno
Jonathan and wbywbywby6 like this.
Old   March 27, 2013, 20:36
Smile
Pei-Ying Hsieh
Hi, Bruno,
As usually, thanks a lot for your help! How can we do without you?!
Pei-Ying
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 03:32
Paraview not found fusij OpenFOAM Installation 2 January 1, 2011 21:44
[OpenFOAM] Distributed ParaView and PV3FoamReader micalil ParaView 4 July 1, 2010 06:09
OpenFOAM 1.6 and ThirdParty Software Paraview dunlopjp OpenFOAM Installation 0 February 24, 2010 12:35
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
