Compiler error with makeParaView
Like Tree1Likes
  • 1 Post By laz0r_viking
Old   December 13, 2012, 19:06
Default Compiler error with makeParaView
Mei Zhang
zhang88 is on a distinguished road
I'm trying to compile paraview using the script makeParaView in ThirdParty package. I'm using Intel compiler icpc. The compilation failed with the following message. I wonder if there is any solution for this. Thanks.
Ying
Linking C shared library ../../../bin/libvtktiff.so
[ 4%] Built target vtktiff
[ 4%] Built target vtkexpat
[ 4%] Built target vtkfreetype
[ 4%] Built target vtklibxml2
[ 4%] Built target vtkDICOMParser
[ 4%] Building CXX object VTK/Utilities/MaterialLibrary/CMakeFiles/ProcessShader.dir/ProcessShader.cxx.o
In file included from /apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkSystemIncludes.h:50,
from /apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkIndent.h:24,
from /apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkObjectBase.h:43,
from /apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkObject.h:41,
from /apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Utilities/MaterialLibrary/ProcessSh
ader.cxx:16:
/apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkOStreamWrapper.h:79: error: declaration of ‘ope
rator<<’ as non-function
/apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkOStreamWrapper.h:79: error: expected ‘;’ before
‘(’ token
/apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkOStreamWrapper.h:80: error: ‘vtkOStreamWrapper&
vtkOStreamWrapper:perator<<(unsigned int)’ cannot be overloaded
/apps/openfoam/ThirdParty-2.1.1/ParaView-3.12.0/VTK/Common/vtkOStreamWrapper.h:70: error: with ‘vtkOStreamWra
pper& vtkOStreamWrapper:perator<<(unsigned int)’
make[2]: *** [VTK/Utilities/MaterialLibrary/CMakeFiles/ProcessShader.dir/ProcessShader.cxx.o] Error 1
make[1]: *** [VTK/Utilities/MaterialLibrary/CMakeFiles/ProcessShader.dir/all] Error 2
make: *** [all] Error 2
zhang88 is offline   Reply With Quote
Old   December 15, 2012, 13:59
Retired Super Moderator
Bruno Santos
Greetings zhang88 and welcome to the forum!
Knowing which operating system and version, as well as ICPC version would make it a lot easier to help you!
Otherwise I'd suggest:
  1. Use GCC instead of ICPC for building ParaView.
  2. If possible, use a pre-built version of ParaView, instead of trying to build your own. The ones from www.paraview.org usually work just fine and they already come with Python integrated!
  3. You can check openfoamwiki.net for some possible hacks. For example: http://openfoamwiki.net/index.php/In...dora#Fedora_17 - scroll to the end of the page
Best regards,
Bruno
Old   December 10, 2013, 14:12
Exclamation
LV
laz0r_viking is on a distinguished road
Just an addendum in case anyone else find themselves at this problem:
I was having this same error, compiling ThirdParty-2.2.x on a machine using all Intel compilers. I thought that the icc and icpc should've already been declared as my functioning compilers but when running
echo $WM_CXX
it would always return
g++
I was able to force this by simply adding the line
export WM_CXX=icpc
in
./makeParaView
Hope this helps!
LV
http://xkcd.com/979/
wyldckat likes this.
laz0r_viking is offline   Reply With Quote
makeparaview
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Intel compiler for linux x86 marcus Siemens 1 November 9, 2006 17:43
Fluent 6.2 and gcc compiler in Sun Blade 2500 Nitu Gupta FLUENT 8 April 29, 2005 14:58
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
