[OpenFOAM.org] unable to source openFOAM under $HOME directory
Like Tree1Likes
  • 1 Post By palmerlee
Old   November 6, 2012, 14:03
Default unable to source openFOAM under $HOME directory
llh
lilinghan8 is on a distinguished road
Dear all,
I would like to modify the solver in openfoam210 but it seems that I cannot make any changes to the files under /opt/
So I moved it to my home directory and add the following line into my $HOME/.bashrc file
source $HOME/openfoam210/etc/bashrc.
Then I run “source $HOME/.bashrc” in the terminal window and these were the information I got:
bash: /opt/openfoam210/bin/foamEtcFile: No such file or directory
bash: /opt/openfoam210/bin/foamCleanPath: No such file or directory
bash: /opt/openfoam210/etc/config/settings.sh: No such file or directory
bash: /opt/openfoam210/etc/config/aliases.sh: No such file or directory
can anyone please tell to me is there any thing I miss?
Regards,
L
lilinghan8 is offline   Reply With Quote
Old   November 7, 2012, 03:18
treima is on a distinguished road
did you move your hole OpenFOAM folder? In this case you have to compile again...
You can modify solvers in your home folder. You just have to copy the solver into your user directory of OpenFoam, normally
home/<user>/OpenFOAM/<user>-<version>/applications/...
In this case you can modify solvers without a sudo or moving the OpenFOAM installation. It´s like the run directory .
regards
treima
treima is offline   Reply With Quote
Old   November 7, 2012, 18:51
llh
Hi treima,
Thanks for your reply, I moved the whole OpenFOAM folder, How to compile it again?
I type wmake all or ./Allwmake under the new directory in terminal window but it doesnt work. It says that wmake commmand is not found
Regards,
L
Old   November 8, 2012, 03:52
blacksquirrel is on a distinguished road
Hello lilinghan,
look into your bashrc.
(gedit $HOME/.bashrc)
there should be written something like:
source /opt/openfoam211/etc/bashrc
change this to your new location of the OpenFOAM folder, e.g.
source $HOME/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
source the bashrc again (. $HOME/bashrc) and try ./Allwmake in the OpenFOAM folder
regards,
squirrel
blacksquirrel is offline   Reply With Quote
Old   November 8, 2012, 05:44
llh
Hi Squirrel,
Thanks for ur reply, I have done the step that changing the location in bashrc, and when and run "source $HOME/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc" I got the error messages as I mentioned in my post above.
Regards,
L
Old   November 8, 2012, 06:38
Ok, sorry I didn't check the bash file of the OpenFOAM installation.
In /OpenFOAM/OpenFOAM-2.1.0/etc/bashrc file there is written
(line 43)
# Location of the OpenFOAM installation
foamInstall=/opt
# foamInstall=~$WM_PROJECT
# foamInstall=/opt/$WM_PROJECT
# foamInstall=/usr/local/$WM_PROJECT
Which means, it still searches your OpenFOAM in the /opt/ directory
So you have two possibilities, I would suggest the first one, because it is less likely to accidentally overwrite a working solver:
1.) you move your whole OpenFOAM directory back to the /opt/ directory and test whether it works again.
Then you create a directory in your home $HOME/OpenFOAM/user-2.1.0
Then you COPY the solver you want to modify from the opt/openfoam into your user directory, but keep a similar directory tree
e.g. simpleFoam would be
copy from /opt/openfoam210/applications/solvers/incompressible/simpleFoam
to $HOME/OpenFOAM/user-2.1.0/applications/solvers/incompressible/simpleFoam
In the copied solver directory edit the Make/files
EXE = $(FOAM_USER_APPBIN)/mysimpleFoam
compile the solver with wmake,
modify to whatever you want and compile again.
You can use the modified solver with the new name mysimpleFoam (you can name it whatever you like in Make/files, but I would suggest not using the original name).
2. you change in
to the correct foamInstall directory.
foamInstall = $HOME/$WM_PROJECT
regards
squirrel
Old   November 8, 2012, 08:38
llh
Hi again,
I need to modify the solver and I download a other people's work which is also needed to change the libraries in the original file so I prefer the 2rd method.
I changed the foamInstall directory to
foamInstall=$HOME/$WM_PROJECT
BUt I still got the error message, do i need also change the code:
#- note the location for later use (eg, in job scripts)
: ${FOAM_INST_DIR:=$foamInstall}; export FOAM_INST_DIR
Any idea?
Regards,
L
Old   November 8, 2012, 08:57
Ok, this is curious. What do you get, if you type
echo $WM_PROJECT_DIR
and
echo $FOAM_INST_DIR
I don't think you need to change the code for FOAM_INST_DIR, because
sets the $FOAM_INST_DIR to the location of foamInstall.
And you can also compile new libraries with my first method. I'm doing the same, modifying solvers and libraries. It isn't more complicated.
Old   November 8, 2012, 09:09
llh
HI,
one is
/opt/OpenFOAM-2.1.1
and the second is
/opt
Old   November 8, 2012, 09:19
Ok, so there is still the wrong directory.
Let's try the simplest thing: close the terminal and open another one. Try again.
Still the same?
I tried it with my installation and it doesn't change the directory despite sourcing the bash file, but it worked after closing and reopening the terminal.
I'm kinda out of ideas right now, sorry...
Old   November 8, 2012, 09:56
llh
HI,
I close and open a new terminal window, and now it works!
Thanks very much for your replies!
Regards,
L
Old   January 9, 2014, 09:12
Peter
palmerlee is on a distinguished road
Hi, blacksquirrel!
Here is my situation:
hpc@node23:/opt/openfoam201$ echo $WM_PROJECT_DIR
/home/hpc/OpenFOAM/openfoam201
hpc@node23:/opt/openfoam201$ echo $FOAM_INST_DIR
/home/hpc/OpenFOAM
Could you please tell me if there is something wrong and how to fix it?
Regards.
Peter
elvis likes this.
palmerlee is offline   Reply With Quote
Old   January 10, 2014, 06:16
Hi Peter,
Please specify your problem. What exactly do you want to do, and what is not working?
Your output means, that the installation directory of OpenFOAM is /home/hpc/OpenFOAM.
If you want to modify a solver and/or library and have the problem, that you don't have the permission to do it in the /opt directory, I strongly recommend possibility 1 of my post from November 8, 2012 11:38.
Regards
squirrel
Old   January 10, 2014, 06:28
Peter
Hi, squirrel!
Thank you for your reply. I try to install OpenFOAM following this instruction: http://www.openfoam.org/archive/2.0....oad/ubuntu.php
I think I have already solved the problem by adding
export FOAM_INST_DIR=/opt
into /opt/openfoam201/etc/bashrc file. Thank anyway!
Regards.
Peter
Old   November 16, 2016, 23:09
QuocThien
neiht is on a distinguished road
All you need is just
0. make sure in etc/bashrc file : foamInstall=$HOME/$WM_PROJECT (no # before)
1. go straight to the .../etc/ directory
2. open the terminal in directory above then type: source bashrc
3. echo $WM_PROJECT_DIR to check
4. Install OpenFoam in the main OpenFOAM directory by ./Allwamke
5. F*** someone to enjoy
neiht is offline   Reply With Quote
Old   October 15, 2019, 03:53
Default OpenFOAM sourcing
  #16
Usama Niaz
Niazi is on a distinguished road
I am installing OpenFOAM 1906 version. right now i am sourcing the OpenFOAM environment through the following command;
source ~/OpenFOAM/OpenFOAM-v1906/etc/bashrc
but i am getting the following error message
No completion added for /home/anonymous/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/bin
... incorrect platform, or not yet compiled?
can any one help? i am not getting it.
Niazi is offline   Reply With Quote
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 Yage OpenFOAM Community Contributions 18 February 15, 2016 03:02
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
