Paraview installation on scientific linux??
Like Tree7Likes
  • 1 Post By linnemann
  • 2 Post By linnemann
  • 2 Post By wyldckat
  • 1 Post By wyldckat
Old   July 17, 2012, 07:03
Default Paraview installation on scientific linux??
EllieM
EllieM is on a distinguished road
I'm not a newbie, but still not too technical! I have never had a problem installing in fedora, but when my laptop died I decided that I could stomach gnome3 nor more, hence SL.
I have a fresh installation of SL6.2, 64 bit fully updated.
Openfoam appears to have installed without a hitch, I pulled the latest release from the git repository yesterday.
When I get to the ./makeParaview command, I get
*** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
Can't pretend to know what this means! So I tried running ./makeQt and got
Starting build: Qt-4.7.3
./makeQt: line 107: cd: /home/ellie/OpenFOAM/ThirdParty-2.1.x/qt-everywhere-opensource-src-4.7.3: No such file or directory
I apologise if this is a duplicate post, I spent all afternoon yesterday (& this morning) trawling forums, google searches not much use, especially when I am not entirely sure what I am looking for!
Thanks in advance
EllieM is offline   Reply With Quote
Old   July 17, 2012, 07:29
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi you need to install qt4
yum install qt4-devel
wyldckat likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 17, 2012, 07:32
Retired Super Moderator
Bruno Santos
Greetings EllieM and welcome to the forum!
This is a bit outdated, but the principle is the same: Building ParaView 3.10.1 with custom Qt 4.6.4
Adapt 4.6.4 to 4.7.3 and 3.10.1 to 3.12.0 and you should be good to go.
Additionally, you might already have a valid Qt installation. Try:
qmake-qt4 --version
Or type qmake and hit the tab key a couple of time, to see if it auto-completes. If it does, from that blog post you can follow the instructions from the line where makeParaView is called instead!
edit: Linnemann, you got 3 minutes ahead of me
Best regards,
Bruno
Old   July 17, 2012, 07:41
EllieM
Hi, thank you both for getting back to me..
linnemann, when I run 'sudo yum install qt4-devel' I get
Package 1:qt-devel-4.6.2-24.el6.x86_64 already installed and latest version
Nothing to do
wyldeckat, 'qmake-qt4 --version' gives
QMake version 2.01a
Using Qt version 4.6.2 in /usr/lib64
I am a bit lost in the link for the post you sent, sorry - where should I be looking?
Thanks again
Old   July 17, 2012, 07:57
linnemann's Avatar
Niels Nielsen
In the makeParaview script you need to change the following lines
# Set the path to the Qt-4.5 (or later) qmake if the system Qt is older
QMAKE_PATH=""
# Set the path to cmake
CMAKE_PATH=""
So for qmake you insert the return you get from running
which qmake-qt4
and similar for cmake
which cmake
If you dont have cmake you need to install it.
yum install cmake
I think this should work
wyldckat and EllieM like this.
Linnemann
Bruno Santos
Instead of simply running makeParaView, run it like this:
./makeParaView -qmake `which qmake-qt4` > makePV.log 2>&1
This will make sure it uses the qmake-qt4 binary instead of the default qmake one, as well as keeping a full build log in the file "makePV.log".
The rest is the same as explained in the official OpenFOAM instructions.
linnemann and EllieM like this.
Old   July 17, 2012, 08:37
EllieM
Thank you again for both getting back to me.
I followed both your sets of instructions
makeParaview has been changed to
QMAKE_PATH="/usr/bin/qmake-qt4"
CMAKE_PATH="/usr/bin/cmake"
When I run
my makePV.log tells me that
CMake Error at VTK/Utilities/vtkhdf5/CMakeLists.txt:1 (cmake_minimum_required):
CMake 2.8 or higher is required. You are running version 2.6.4
There are also a couple of other errors, but they appear to be connected.
I have the most up to date version available on SL, so I enabled the atrpms repo (as suggested here http://www.linuxforums.org/forum/red...linux-6-a.html) and I still cannot get cmake 2.8....
I am now going to walk away from the machine before it ends up in a million pieces!
Old   July 17, 2012, 08:49
linnemann's Avatar
Niels Nielsen
Download the latest release of cmake
yum install ncurces-devel
unpack cmake
go to cmake dir
./configure --prefix=/usr/local
make && make install
run which cmake
should be in /usr/local/bin and not /usr/bin
EllieM likes this.
Linnemann
Old   July 17, 2012, 08:57
Bruno Santos
Or as an alternative to Linnemann's instructions - from within the ThirdParty folder run these commands:
wget "http://www.openfoam.org/mantisbt/file_download.php?file_id=143&type=bug" -O getCmake
wget "https://raw.github.com/OpenFOAM/ThirdParty-2.0.x/master/makeCmake"
chmod +x get* make*
./getCmake
./makeCmake > mkcmake.log 2>&1
wmSET
Source for most of the commands: http://www.cfd-online.com/Forums/blo...untu-8-04.html
EllieM likes this.
Old   July 17, 2012, 09:15
EllieM
Thank you both for your help, but I give up!
wyldckat, your method gives me an error with Linking CXX static library libCMakeLib.a
linnemann, your method gives me an error of
The bug is not reproducible, so it is likely a hardware or OS problem.
gmake: *** [cmBootstrapCommands.o] Error 1
Error when bootstrapping CMake:
Problem while running gmake
Again, thank you both so much, I really do appreciate it, but I simply do not have the time at the moment to fix this! :-(
Old   May 12, 2013, 22:32
Kiddosuper
kiddosuper is on a distinguished road
encountered same problem as #7 , cmake version is not matching requried version 2.8
follow the instruction from linnemann
So I download cmake 2.8 , and compile with
# ./configure --prefix=/usr/local
# ./bootstrap; make; make install
after that, still need to modify the link for cmake
# cd /usr/bin
# mv cmake xxxcmake
# ln -s /usr/local/bin/cmake ./
and then , problem solved
kiddosuper is offline   Reply With Quote
installation, openfoam, paraview 3.12, scientific linux
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 19:13
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 13:59
