[Other] Boundary layer extrusion tool for OF using Blender
Like Tree3Likes
  • 3 Post By tkeskita
Old   January 8, 2023, 04:10
Post Boundary layer extrusion tool for OF using Blender
Tuomo Keskitalo
tkeskita is on a distinguished road
Hello world,
I made a tool for Blender which extrudes boundary layer cells on top of any surface mesh, or an existing OpenFOAM mesh created with e.g. SnappyHexMesh. I call the tool Shell extrusion method, and it's part of my Unstructured Grids add-on for Blender. I made it to create flat cells by extruding new edges towards adjusted vertex normal directions. It can be used to create boundary layers, although my original target was to mesh thin solid shells. Here's example pictures of a mesh, where a mesh of a steel shell was built on top of a vessel geometry meshed with Snappy. I tested this on a conjugate heat transfer case with chtMultiregionFOAM, seems to work. You're welcome to try it out, but beware: It creates intersections if extrusion thickness is too large!
dlahaye, lourencosm and hogsonik like this.
tkeskita is offline   Reply With Quote
blender, boundary layer meshing, mesh extrusion
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
Divide Prismatic Boundary Layer Mesh causes overlapping faces SilentRunner42 enGrid 4 May 4, 2015 04:37
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
