February 8, 2021, 06:42
Guidance: How to create an OpenFOAM Project (Video Screencasts)
Tobias Holzmann
Dear community,
at the moment I am recording the latest community screencasts for OpenFOAM v8. During the YouTube videos we are going through a variety of different topics that should be known while using OpenFOAM. At the moment, the screencast series reached 12 videos and explains everything step-by-step starting at zero.
You will find the announced playlist here:
https://youtube.com/playlist?list=PL...eLWb6OZaMOHiST
Topic of the videos are summed up:
Part 1 - Introduction
Part 2 - Fluid Region Extraction- Fluid region extraction
- Repairing the geometry
- Closing holes with different algorithms
- Merging/Sewing methods for closing gaps
- Tips & Tricks (maybe)
- Checking the created surface
- Intersections / Free boundaries
Part 3 - Surface Triangulation- exporting STL files from the Geometry module (similar to a common CAD export)
- Extended surface triangulation
- Exporting the single named triangulated surfaces
- Giving information about the general file structure of an STL file (a reference to József Nagy's video is given)
- Combining the single STL files to a region STL file
- Analyzing the STL's in ParaView
Part 4 - Case Preperation for Meshing- Background mesh generation using Salome®
- Mesh conversion using the »ideasUnvToFoam« application
- Creating missing files that are needed to run snappyHexMesh (including a general but brief description of what the files do) such as controlDict, fvSolutions, fvSchemes, snappyHexMeshDict, meshQualityDict
- And as always, Tobi live
Part 5 - SnappyHexMesh Castellated Meshing- Analyzing the snappyHexMeshDict
- Explaining the control parameters of the castellatedMeshControls dictionary within the snappyHexMeshDict especially the keywords:
- maxLocalCells
- maxGlobalCells
- minRefinementCells
- maxLoadUnbalancing
- nCellsBetweenLevels
- features
- refinementSurface
- refinementRegions
- locationInMesh
- resolveFeatureAngle
- allowFreeStandingZoneFaces
- Set-up the control file of snappyHexMesh for the smoking pipe geometry
- Creating the first castellated meshes
- Resolving errors
- Analyzing partially the output of the application
- Showing the influence of the levels (x y) in combination with the feature angle approach
Part 5.1 - SnappyHexMesh castellatedMesh Complementary- Refinement level
- What is a castellatedMesh
- maxGlobalCells
- Use the regions of the STL file for individual refinement
Part 5.2 - SnappyHexMesh castellatedMesh Cell Types- Cell type generation during the castellated process
- Explaining why we get polyhedron cells
- Hints for ParaView how to display the cell type
- Extract cells from the mesh in ParaView and display them correctly
Part 6 - SnappyHexMesh Snapping- Explaining what snapping means
- Creation of the first snapped mesh and the influence of the parameter »tolerance«
- Resetting the »tolerance« parameter and recreating the mesh
- Explaining »feature Snapping«
- Influence of nFeatureSnapIter parameter
- Details about nSolveIter
- Details about nRelaxIter
- Details about nSmoothPatch and nonOrthogonality
- Further information regarding the control parameters (Engys PDF)
- Analysis of the mesh in general and optimization suggestions
Part 7 - SnappyHexMesh Layer Generation- Activating the layer generation algorithm
- The »addLayersControls« dictionary
- The »relativeSize« description
- The »layers« sub-directory and the control settings
- Extended options for layer-set-up and definitions
- First layer generation and visualization (including explanation)
- How does snappyHexMesh add layers (algorithm idea)
- Other meshing examples with different layer-parameters
Part 8 - Boundary Condition for field U- General information regarding the boundary condition files
- Why the application looks at the conditions in the file 0
- Copying existing boundary conditions
- Analyzing the complete text file U
- Deeper insight into the dictionary boundaryField {}
- Adapt the boundary conditions to our first set-up
Part - Boundary Condition for field p- Starting analyzing the p file located in the 0 folder
- The units of the pressure [m²/s²] or [kg/m/s²]
- Advantage of dividing by the density for numerics
- The values of the pressure corresponding to the units
- The boundaryField
- Outlook to the next topics we are talking about
Part 10 - Solver Set-up & First Simulation- Short introduction about what we are doing in the first simulation and explaining the simpleFoam solver
- Start the simpleFoam solver and analyzing the output (error) while giving general information about the fvSolution and fvSchemes files
- Explicit explanation of the fvSchemes file
- Explicit explanation of the fvSolution file
- Explicit explanation of the algorithm sub-dictionary we are using (brief)
- A few words regarding the field and matrix relaxation
- The transportProperties file that handles the fluid in use
- The momentumTransport file that handles the methodology we are using (laminar, RAS, LES)
- Generals hint regarding steady-state simulation and the controlDict settings - especially the time information
- Analyze the converged data using #ParaView
- Glyph hack for #ParaView
- Outlook to the next video
I hope these screencasts will support your work regarding OpenFOAM. Leave a comment here or give some feedback. You are warmly welcomed to share my work around your network.
Keep foaming,
Tobias Holzmann
