[PyFoam] PyFoam on macOS
Like Tree1Likes
  • 1 Post By Delta Cheng
Old   January 10, 2021, 19:49
Default PyFoam on macOS
xuegy is on a distinguished road
Hello all,
I have issues running pyFoamPlotWatcher.py on macOS. (installed thru pip)
gnuplot> set terminal aqua
line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list
gnuplot> set terminal x11 noraise noenhanced
line 0: line 0: unknown or ambiguous terminal type; type just 'set terminal' for a list
gnuplot> set terminal x11 title "pyFoam: Bounded variables"
gnuplot> set terminal x11 title "pyFoam: Continuity"
gnuplot> set terminal x11 title "pyFoam: Residuals"
Obvisouly it is caused by the incomplete installation of gnuplot on macOS.
However brew install gnuplot --with-qt or --with-x11 is now deprecated. https://stackoverflow.com/questions/...11-not-working
Is there any solution to get PyFoam supported on macOS? The author uses mercurial for source code and I don't even know how to submit an issue!
Thanks in advance.
xuegy is offline   Reply With Quote
Old   January 13, 2021, 20:31
Assistant Moderator
Bernhard Gschaider
Originally Posted by xuegy View Post
Hello all,
Thanks in advance.
I don't have access to an up to date Mac anymore so I can only guess
There is a setting that allows specifying the terminal to be used in Gnuplot. So it might be fixed by putting
[Plotting]
gnuplot_terminal: x11
into a file ~/.pyFoam/pyfoamrc and replace x11 with whatever is now the default terminal to use in Gnuplot on a Mac
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 13, 2021, 21:28
[Plotting]
Here's what's supported in pyFoam
Error in /usr/local/bin/pyFoamPlotWatcher.py : FatalError in PyFoam: 'PyFoam FAT
AL ERROR on line 52 of file /usr/local/lib/python3.9/site-packages/PyFoam/Basic
s/PlotTimelinesFactory.py: Terminal qt not in list of valid terminals x11, wxt,
caca, dumb, aqua'
Here's what supported by gnuplot in macOS
Available terminal types:
cairolatex  LaTeX picture environment using graphicx package and Cairo backend
canvas  HTML Canvas object
cgm  Computer Graphics Metafile
context  ConTeXt with MetaFun (for PDF documents)
domterm  DomTerm terminal emulator with embedded SVG
dumb  ascii art for anything that prints text
dxf  dxf-file for AutoCad (default size 120x80)
emf  Enhanced Metafile format
epscairo  eps terminal based on cairo
epslatex  LaTeX picture environment using graphicx package
fig  FIG graphics language V3.2 for XFIG graphics editor
gif  GIF images using libgd and TrueType fonts
hpgl  HP7475 and relatives [number of pens] [eject]
jpeg  JPEG images using libgd and TrueType fonts
lua  Lua generic terminal driver
mf  Metafont plotting standard
mp  MetaPost plotting standard
pcl5  PCL5e/PCL5c printers using HP-GL/2
pdfcairo  pdf terminal based on cairo
pict2e  LaTeX2e picture environment
png  PNG images using libgd and TrueType fonts
pngcairo  png terminal based on cairo
postscript  PostScript graphics, including EPSF embedded files (*.eps)
pslatex  LaTeX picture environment with PostScript \specials
pstex  plain TeX with PostScript \specials
pstricks  LaTeX picture environment with PSTricks macros
qt  Qt cross-platform interactive terminal
sixelgd  sixel using libgd and TrueType fonts
svg  W3C Scalable Vector Graphics
tek40xx  Tektronix 4010 and others; most TEK emulators
tek410x  Tektronix 4106, 4107, 4109 and 420X terminals
texdraw  LaTeX texdraw environment
tikz  TeX TikZ graphics macros via the lua script driver
tkcanvas  Tk canvas widget
unknown  Unknown terminal type - not a plotting device
vttek  VT-like tek40xx terminal emulator
xterm  Xterm Tektronix 4014 Mode
The only option seems to be "dumb"
Which is definitely not what I want. I guess this will be a simple fix, by setting the terminal to qt if the system is macOS, but I'm not a pro in python.
Old   January 14, 2021, 04:24
Assistant Moderator
Bernhard Gschaider
caca, dumb, aqua'
Attachment 82104
Go to the file /usr/local/lib/python3.9/site-packages/PyFoam/Basics/GnuplotTimelines.py line 16. Extend the variable terms with the terminal qt
terms=["x11","wxt","caca","dumb","qt"]
Let me know which terminal works and I'll adapt the sources accordingly
Side note: the reason why PyFoam has a list of valid terminals is to prevent people from specifying a terminal "png" and ending up with an unusable terminal
PS: I think terminal "dumb" is really cool
Old   January 14, 2021, 10:34
I modified GnuplotTimelines.py
terms=["x11","wxt","caca","dumb"]
    if uname()[0]=="Darwin":
        terms.append("qt")
    return terms
Surprisingly there's something for macOS but "aqua" just no longer exists.
I still got some error messages
                     line 0: ^
qt.qpa.fonts: Populating font family aliases took 230 ms. Replace uses of missing font family "Sans" with one that exists to avoid this cost.
But eventually the plot popped up
Old   January 14, 2021, 15:28
Assistant Moderator
Bernhard Gschaider
        terms.append("qt")
    return terms
                     line 0: ^
Attachment 82111
Aqua was this: https://sourceforge.net/projects/aquaterm/ That used to be "standard" for gnuplot on Mac OS X if you didn't use X11
I must check. I think I gave "aqua" a special treatment on darwin so that it used x11 if X11 was started (much faster) and otherwise fell back to aqua
Old   January 14, 2021, 15:45
Have you considered switching to qt for Linux as well? It's cross-platform anyway.
Old   April 14, 2022, 00:42
Thumbs up Solution using qt instead of x11 or dumb on up to date Macos (M1 INCLUDED)
Guanda CHENG
Delta Cheng is on a distinguished road
Thanks to your discussion with gschaider, I've found the final solution by adopting only a few changes to the file 'GnuplotTimelines.py' using qt.
Here is the solution. What you need to do is just a few modifications for the terms marked red:
   def __init__(self,
                 timelines,
                 custom,
                 terminal="qt",
                 showWindow=True,
                 quiet=False,
                 registry=None):
   GeneralPlotTimelines.__init__(self,timelines,custom,showWindow=showWindow,registry=registry)
        Gnuplot.__init__(self, persist=self.spec.persist, quiet=quiet)
        self.itemlist=[]
        self.terminal="qt"
duanwuCHEN likes this.
Delta Cheng is offline   Reply With Quote
pyfoam
[PyFoam] PyFoam 6.6.9 installation problems klausb OpenFOAM Community Contributions 2 October 2, 2022 06:56
[PyFoam] PyFoam BasicRunner producing LinuxMem error tas38 OpenFOAM Community Contributions 2 October 5, 2016 12:29
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
[PyFoam] How to extract values with pyFoam? chriss85 OpenFOAM Community Contributions 13 January 27, 2014 21:16
pyFoam, pyFlu, extend: How does they relate? Horus OpenFOAM 9 May 21, 2011 13:49
