[waves2Foam] Compilation Error with OF-2.4.0 on Ubuntu 18.04 |
February 25, 2020, 13:22 |
Callum Guy
Rep Power: 6 |
I'm trying to compile waves2Foam on ubuntu 18.04 and with OF-2.4.0. I'm getting an error when the compiler trys to make waveFoam. When Compiling the library I get an error at the start:
/usr/bin/ld: cannot find -lgfortran Code:
/usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamSampling collect2: error: ld returned 1 exit status /home/callum/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/callum/OpenFOAM/callum-2.4.0/platforms/linux64GccDPOpt/bin/waveFoam' failed make: *** [/home/callum/OpenFOAM/callum-2.4.0/platforms/linux64GccDPOpt/bin/waveFoam] Error 1 I've attached a log if anyone can help. |
March 6, 2020, 05:36 |
#2 | |
Masoumeh
Rep Power: 7 |
I have this problem too. |
March 6, 2020, 10:54 |
Marc
I have the same problem
May 12, 2020, 08:08 |
Peng Ningning
Rep Power: 6 |
hi, Callum
Have you figure it out? I meet the same problem when I complie waves2Foam with OpenFOAM1912 using Bash on Ubuntu on Windows. |
May 12, 2020, 10:38 |
Callum Guy
Rep Power: 6 |
Unfortunately not, I opted to use another toolbox called olaFlow because of this issue.
May 13, 2020, 04:25 |
Peng Ningning
Rep Power: 6 |
December 28, 2020, 06:15 |
#7 | |
le
Rep Power: 16 |
I also install wave2Foam in OF1812 centos 7, but I get error "cannot find -lwaves2Foam" can you tell more detail your case, please. Many thanks |
September 3, 2021, 04:56 |
#8 | |
Peng Ningning
Rep Power: 6 |
For me, the root of the error is WSL. I only met this problem when installing wave2Foam on WSL, and it didn't happen for my desktop with Ubuntu 18.04. |
September 15, 2022, 07:48 |
#9 |
Pedro Ramos
Rep Power: 14 |
November 26, 2022, 09:58 |
#10 |
Lige Zhao
Hi,Ningning, I also complied waves2Foam with OpenFOAM1912 using Ubuntu virtual system on Windows.
when I complie the "ThirdParty" folder, I met the error: make: *** [makefile:138:ORDERINGS/ccn.o] error 1 mv:'libskit_gfortran.a' folder state (stat): No such file or directory Do you have any idea of this error? really appreciate for any suggestions |
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 | JGadelho | OpenFOAM Community Contributions | 36 | April 27, 2024 16:46 |
[OpenFOAM.org] Install OpenFOAM-2.4.0 in Ubuntu 18.04? | luckyraymond | OpenFOAM Installation | 10 | April 26, 2023 13:26 |
[Other] Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04 | gcengineer | OpenFOAM Installation | 9 | June 22, 2020 18:45 |
[OpenFOAM.org] OpenFOAM 3.0.1 in Ubuntu 18.04 | jlr | OpenFOAM Installation | 4 | January 3, 2019 12:57 |
OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit | keepfit | OpenFOAM Installation | 2 | March 26, 2013 09:43 |
