[waves2Foam] External source file to generate wave motion
Like Tree1Likes
  • 1 Post By Phicau
Old   December 17, 2019, 12:18
Question External source file to generate wave motion
MP Delisle
mdelisle is on a distinguished road
Hi all,
I am attempting to replicate a wave tank experiment (transient, breaking wave) with a piston-like wave maker (I have x and eta at at the wavemaker), but the solver I wish to use (sedWaveFoam) does not have dynamic mesh capabilities. I tried to use interDyMFoam with an extended domain for the dynamic mesh (derived velocity from wavemaker data) and but due to wave shape and length of wavemaker motion (~40 sec) this does not provide satisfactory results. I'm hoping to find a way to generate the wave while still using sedWaveFoam (I am looking into sediment properties).
I looked into groovyBC to generate wave motion but due to wave reflection it becomes unstable. The waves2foam manual briefly describes using an external source file to generate wave motion - has anyone been successful in doing so? Using interDyMFoam I could get all necessary information at one location (e.g., eta, velocity, pressure) and then use this as an input in sedWaveFoam. Any suggestions or examples would be greatly appreciated!
mdelisle is offline   Reply With Quote
Old   December 17, 2019, 19:04
Pablo Higuera
Phicau is on a distinguished road
Hi mdelisle,
if you have a time series of displacement and free surface at a wavemaker you can use olaFlow to generate the waves. It has active wave absorption too to account for the reflected waves. Check https://olaflow.github.io and follow the wavemakerFlume tutorial included in the source code to learn how to work with it.
Eventually, you can also potentially link the wavemaker boundary condition dynamically into the sedWaveFoam solver to account for sediment too (if the solver allows using dynamic meshes).
Best,
Pablo
mrozki likes this.
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   December 17, 2019, 20:44
Yeulwoo Kim
Yaroo is on a distinguished road
Hi Pablo,
I think MP wants to use static mesh instead of dynamic mesh, prescribing the wave at the inlet using the external source files (alpha.water and U). We are wondering if olaFlow has that capability.
I am also working on the SedWaveDyMFoam, and it is partially done. The main issue is SedWaveFoam works stable only in the GAMG pressure solver. But that seems not the best solver for dynamic mesh.
Yeulwoo
Yaroo is offline   Reply With Quote
Old   December 18, 2019, 05:38
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi MP,
The external source in waves2Foam is an abstract base class that allows you to program an interface to any wave input, as long as you can provide surface elevation and velocity field. Consequently, you should be able to program the necessary control yourself.
You could also apply OceanWave3D that comes with functionality of mimicking wave paddle motion.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 19, 2019, 19:36
Pablo Higuera
Hi Yeulwoo,
yes, if the waves are close to shallow water conditions, olaFlow has an option to generate waves in such way. Check the olaFlow manual included in the references folder for a full description, the waveType is called wavemaker (it will be renamed to waveSeries in the future) and you can provide a time series of displacement and free surface to allow actve wave absorption too.
Best,
Pablo
dynamic, external, file, mesh, source
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
