[cfMesh] Salome 9.3.0 cannot generate .fms file |
Rep Power: 7 ![]() |
first to avoid syntax errors. I had to replace all occurrences of
print ---whatever---- with print (---whatever----) in scripts extractFeatureEdges.py and salomeTriSurf.py ( the opening and closing parentheses are essential) (These scripts are found under the installation of cfMesh software you can download cfMesh from their site or find it part of OpenFoam 18.0.6) I load script salomeTriSurf.py in Salome 9.3.0 after highlighting my mesh in the Mesh module and pressing Ctrl-t) Then, when I type triSurf().writeFms('FileName.fms') in the command window opened up by the loaded script, I get the following error on line 113: AttributeError: 'collections.OrderedDict' object has no attribute 'iteritems' I am beginning to wonder if those scripts were written to be understood by python 2.7 but not by python 3.6 which is the one used by Salome 9.3.0 Has anybody encountered this error ? |
#2 | |
Igor Leonardo
Rep Power: 10 ![]() |
General workflow to create a flawless mesh in cfMesh Alternatively, you can download salime 8.5, and it should work there. Best regards, Igor Carvalho |
Thanks Igor. I will stick with version 7.4.0 since I had already downloaded it. Version 9.3.0 does not even work when you modify the scripts using the 2to3 python conversion program. (you get TypeError updateObjBrowser() takes 1 argument but 2 were given)
Carlo_P
Rep Power: 8 ![]() |
Hey, anohter way can be to export a stl file a then convert it with surfaceToFMS.
#5 | |
Abraham Vivas
You were close, the problem is that it open the file to write in binary: Code:
open(fileName, 'wb') Code:
open(fileName, 'w') And for using it, after loading the script, I selected a surface mesh and then on the console i typed: Code:
S = triSurf(allEdges=True) S.writeFms("/path/to/fileName.fms") |
Claudio Boezio
Hi celestial, I've encountered the same problems and I believe you're correct, that the cfMesh Python scripts are for older versions of Python. As a workaround I've used an online converter to convert the source code from Python version 2 to version 3. The updateObjBrowser() function fails, but as workaround, clicking on Refresh in the object tree context menu will update the tree and display the newly created object. Apparently, in Python the calling object is always an implied argument when a method is called, thus 2 arguments are counted, even if only one is visible in the source code. This might be an indication that the method is expected to be called without (visible) arguments (empty brackets only). I'll check the current Salome Python API and try that out. Apart from the changed Python version, some Salome APIs have had minor changes as well. Thus the cfMesh Python scripts are not compatible with the latest version of Salome.
Claudio Boezio
Hi celestial, I've encountered the same problems with Salome 9.4.0 and I believe you're correct, that the cfMesh Python scripts are for older versions of Python. As a workaround I've used an online converter to convert the source code from Python version 2 to version 3, as you did. The updateObjBrowser() function fails, but as workaround, clicking on Refresh in the object tree context menu will update the tree and display the newly created object. Apparently, in Python the calling object is always an implied argument when a method is called, thus 2 arguments are counted, even if only one is visible in the source code. This might be an indication that the method is expected to be called without (visible) arguments (empty brackets only). I'll check the current Salome Python API and try that out. Apart from the changed Python version, some Salome APIs have had minor changes as well. Thus the cfMesh Python scripts are not compatible with the latest version of Salome.
Elaxender david
Hello
I used salomeTriSurf3.py and many other script, But all failed. please help me to overcome that issues. I got that error. >>> exec(open("/home/smeralda/Cfmesh/cfMesh/python/Salome/salomeTriSurf3.py", "rb").read()) >>> triSurf().writeFms(‘FileName.fms’) Traceback (most recent call last): File "/opt/Salome/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/codeop.py", line 87, in _maybe_compile code1 = compiler(source + "\n", filename, symbol) File "/opt/Salome/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/codeop.py", line 102, in _compile return compile(source, filename, symbol, PyCF_DONT_IMPLY_DEDENT) File "<input>", line 1 triSurf().writeFms(‘FileName.fms’) ^ SyntaxError: invalid character in identifier >>> |
#9 | |
Elaxender david
Hello I used salomeTriSurf3.py and many other script, But all failed. please help me to overcome that issues. I got that error. >>> exec(open("/home/smeralda/Cfmesh/cfMesh/python/Salome/salomeTriSurf3.py", "rb").read()) >>> triSurf().writeFms(‘FileName.fms’) Traceback (most recent call last): File "/opt/Salome/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/codeop.py", line 87, in _maybe_compile code1 = compiler(source + "\n", filename, symbol) File "/opt/Salome/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/codeop.py", line 102, in _compile return compile(source, filename, symbol, PyCF_DONT_IMPLY_DEDENT) File "<input>", line 1 triSurf().writeFms(‘FileName.fms’) ^ SyntaxError: invalid character in identifier >>> |
#10 |
Claudio Boezio
#11 | |
Elaxender david
Finally succeeded thanks a lot |
#12 | |
Elaxender david
Hello Thank you for your post. I did exactly what you wrote but failed at the begging of pressing Enter button. I don't know why?. Thanks again. |
#13 |
Elaxender david
#14 |
Joshua Oseh
Rep Power: 0 ![]() |
If anyone stumbles on this post, what worked for me (Salome 9.9.0) was:
1) Update extractFeatureEdges.py to py2/3 using futurize. Skip to Step 1, 1b here if you already have python installed. This updates your file to work with Python 2 or 3. 2) Delete "x" in "xrange" in 3 places to use "range" which is what is used in Python3 3) Delete or comment out the last 2 lines (line 131,132). in extractFeatureEdges.py. cfmesh hasn't been updated in years so should be same for you. i.e # if salome.sg.hasDesktop(): # salome.sg.updateObjBrowser(True) 4) Run script in Salome as usual 5) Refresh through object browser as "Ship Designer" mentioned This worked for me! Last edited by joddy466; December 21, 2022 at 23:24. |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
