June 27, 2019, 05:41 |
How to run CfMesh in parallel?
Carlo_P
Rep Power: 8 |
Dear all,
I'm trying to use CfMesh in parallel. I'm not an able user of Linux. Can someone explain me step by step every single command? I tryed with cartesianMesh, but I have a error: attempt to run parallel on 1 processor. Thanks a lot, Carlo |
June 27, 2019, 07:57 |
Kmeti Rao
Rep Power: 8 |
June 28, 2019, 05:35 |
Carlo_P
Rep Power: 8 |
Thanks Krao for the link.
I saw also before it, but I didn't understand where I have to modify OMP_NUM_THREADS . Should I also decompose the case before? Thanks a lot, Carlo |
June 28, 2019, 07:16 |
Kmeti Rao
Rep Power: 8 |
Hi Carlo,
Open the terminal and go to the directory in which your mesh is placed. Before running the command cartesianMesh or whichever you would like to run, enter 'bash' and press 'enter'. After this, type for example, 'export OMP_NUM_THREADS=4,4'. Use the system monitor to know, whether the application utilising all the cores. Also, you would see change in total meshing time. I think it is not required to decompose. It is only required to run the application. Krao |
July 2, 2019, 06:01 |
Carlo_P
Rep Power: 8 |
Thanks Krao,
your process worked perfectly! Thanks a lot again, Carlo |
cfmesh, meshing, parallel |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
