[Other] [Request] OpenFOAM mesh to 2D Ansys fluent mesh |
Rep Power: 8 ![]() |
The foamMeshToFluent utility can convert only 3D meshes to Ansys Fluent Mesh. Is there any tool that generate 2D Fluent Mesh from OpenFOAM?
As you know, in OpenFOAM if we want to do a 2D simulation we create a 3D mesh with at least one cell thick in the third dimension and specifying it as empty Boundary condition. IMO, it is more natural to have a tool or at least adding some options to the existing foamToFluentMesh utility to convert these 2D meshes to 2D mesh for Ansys Fluent. Is it is easy to program this tool? Last edited by anon_q; February 16, 2019 at 14:56. |
Hi Evren!
You are right since OpenFOAM works with 3D meshes by default and one does not have to treat 2D or axis-symmetric meshes in some special way, no modifications come to your equations. There are too possibilities:
Alexander
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
Thank you for your reply dear Alexander,
Yes I tried to go with the second option but it will take some time. here is an example of Fluent 2D ascii mesh. Regarding the first option, I am pretty sure they will never accept the feature request. |
hi Evren) it depends to which team you talk, ESI are quite open. I will have a look a bit later what can be done.
Thank you for your interest
jose daniel
Rep Power: 6 ![]() |
Hello, I'd like to know if you found a solution. Thanks!
desimuser1
Rep Power: 3 ![]() |
use fluent3DMeshToFoam myMesh.msh
fluent, mesh 2d, openfoam |
[ANSYS Meshing] Difficulty in mesh upload to ansys fluent | Ayo_gboyega | ANSYS Meshing & Geometry | 1 | June 17, 2018 03:02 |
Is it possible to convert a 3D mesh in Ansys Fluent to a 2D mesh? | anon_q | FLUENT | 0 | May 9, 2018 20:40 |
Exporting Mesh from Pointwise to ANSYS FLUENT | mrswordf1sh | Pointwise & Gridgen | 14 | September 6, 2017 10:23 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam | archymedes | OpenFOAM Meshing & Mesh Conversion | 1 | April 1, 2010 05:26 |
