[waves2Foam] Problem of deep water simulation(wavelength become larger as propagation)
Like Tree1Likes
  • 1 Post By jessica_ict
Old   February 13, 2019, 03:23
Default Problem of deep water simulation(wavelength become larger as propagation)
i-chen,tsai
jessica_ict is on a distinguished road
Dear all,
I have a problem with deep water simulation.
Wavelength would become larger as wave propagation.
Could someone tell me how to solve the problem?
The following are my file:
waveProperties:
seaLevel	0.00;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
initializationName outlet;
inletCoeffs
    // Wave type to be used at boundary "inlet" and in relaxation zone "inlet"
    waveType    stokesSecond;
    // Ramp time of 2 s
    Tsoft       1.2;
    // Water depth at the boundary and in the relaxation zone
    depth       0.900000;
    // Wave period
    period      1.20;
    // Phase shift in the wave
    phi         0.000000;
    // Wave number vector, k.
    direction  (1.0 0.0 0.0);
    // Wave height
    height      0.06;
    debug       false;
    // Specifications on the relaxation zone shape and relaxation scheme
    relaxationZone
        relaxationScheme Spatial;
        relaxationShape  Rectangular;
        beachType        Empty;
        relaxType   INLET;
        startX      (0.0  0.0 -0.9);
        endX        (6.0  0.9  0.3);
        orientation      (1.0 0.0 0.0);
outletCoeffs
    waveType    potentialCurrent;
    U           (0 0 0);
    Tsoft      	1.2;
    relaxationZone
        beachType        Empty;
        relaxType   OUTLET;
        startX      (29.0  0.0 -0.9);
        endX        (35.0  0.9  0.3);
controlDict:
application interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         60;
deltaT          0.001;
writeControl    adjustableRunTime;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.25;
maxAlphaCo      0.25;
maxDeltaT       0.001;
fvSolution
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        alphaOuterCorrectors yes;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    3;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
    pcorr GAMG
        tolerance        1e-7;
        relTol           0.0;
        smoother         DIC;//GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    pcorrFinal GAMG
        tolerance        1e-7;
        relTol           0.0;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        mergeLevels      1;
    p_rgh GAMG
        tolerance        1e-7;
        relTol           0.0;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        mergeLevels      1;
    p_rghFinal GAMG
        tolerance        1e-8;
        relTol           0.0;
        nPreSweeps       0;
        nPostSweeps      2;
        nFinestSweeps    2;
        mergeLevels      1;
    U PBiCG
        preconditioner   DILU;
        tolerance        1e-09;
        relTol           0;
    UFinal PBiCG
        tolerance        1e-09;
        relTol           0;
    gamma PBiCG
        tolerance        1e-07;
        relTol           0;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 1;
    nCorrectors     3;
    nNonOrthogonalCorrectors 1;
relaxationFactors
    fields
    equations
        ".*" 1;
fvScheme
ddtSchemes
    default Euler;
gradSchemes
//    default	cellLimited fourth 1;
    default         Gauss linear;
    grad(U)         Gauss linear;
    grad(alpha1)     Gauss linear;
divSchemes
//    default	    Gauss linear;
    div(rhoPhi,U)  Gauss limitedLinearV 1;
//    div(phi,gamma)  Gauss vanLeer;
//    div(rho*phi,U)  Gauss MUSCL;
//    div((muEff*dev(T(grad(U))))) Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phi,alpha)  Gauss MUSCL;
    div(phirb,alpha) Gauss interfaceCompression;
//    div(rhoPhi,U)   Gauss limitedLinearV 1;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
domain
x:35m z:1.2m
dx:0.005m dz:0.0025
wave condition
period:1.2 sec
wave height:0.06m
water depth:0.9m
This is deep water condition!
There are 24 cells per wave height and about 439 cells per wavelength.
I tried two versions of OpenFOAM (1712plus and extend 4.0), different types of mesh and different timesteps.
The result of different timesteps, version and mesh type shown below:
ms.hashempour likes this.
jessica_ict is offline   Reply With Quote
Old   February 26, 2019, 19:05
Hillary Kiptoo
larry k is on a distinguished road
Quick answer: You need to check your numerical schemes for example, from my experience, CrankNicolson works best than euler
larry k is offline   Reply With Quote
Old   February 27, 2019, 14:55
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Also, if you compare the conditions with stream function wave theory, then you will see that stream function wave theory is roughly 1% longer, so after 13 wave lengths it amounts to a noticeable effect.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   March 6, 2019, 03:21
i-chen,tsai
@ngj
Dear Niels,
Thanks for your quick reply.
I found that the result is much more approach to Stokes 5th wave, not Stokes 2nd waves.
Would you please tell me why the wave condition is appropriate to choose Stokes 2nd Wave, but the result is more approach to Stokes 5th wave?
Thank you very much!
discrete model problem (water droplet evaporation) rabaeto1984 FLUENT 4 October 1, 2018 05:16
Problem after mergeMesh, water flows through the wall, which should not happen Andy_Wang OpenFOAM 13 June 15, 2016 09:11
shallow water VS deep water Paul Main CFD Forum 10 August 30, 2004 12:56
Problem Patching Water Depth (2-D) SEMC FLUENT 3 March 15, 2004 20:58
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
