[waves2Foam] Stokesfirst wave profile asymetrical against the still water level?? |
March 19, 2015, 22:23 |
Xiantao Zhang
Rep Power: 12 |
Dear foamers,
I am now trying to generate regular waves using the tutorial "waveFlume" of waves2Foam. And the result shows that the value of wave crest is larger than the wave trough. ( asymmetrical against the still water level). The relevant input files are shown as follows: 1. blockMesh Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( ( 0 -1.035 0 ) ( 13.5 -1.035 0 ) ( 0 -0.10 0 ) ( 13.5 -0.10 0 ) ( 0 0.10 0 ) ( 13.5 0.10 0 ) ( 0 0.265 0 ) ( 13.5 0.265 0 ) ( 0 -1.035 0.1 ) ( 13.5 -1.035 0.1 ) ( 0 -0.10 0.1 ) ( 13.5 -0.10 0.1 ) ( 0 0.10 0.1 ) ( 13.5 0.10 0.1 ) ( 0 0.265 0.1 ) ( 13.5 0.265 0.1 ) ); blocks ( hex (0 1 3 2 8 9 11 10) (1000 46 1 ) simpleGrading (1 0.3333 1) hex (2 3 5 4 10 11 13 12) (1000 20 1) simpleGrading (1 1 1) hex (4 5 7 6 12 13 15 14) (1000 11 1) simpleGrading (1 2 1) ); edges ( ); patches ( patch inlet ( (2 0 8 10) (4 2 10 12) (6 4 12 14) ) wall bottom ( (0 1 9 8) ) patch outlet ( (1 3 11 9) (3 5 13 11) (5 7 15 13) ) patch atmosphere ( (7 6 14 15) ) empty frontBack ( (8 9 11 10) (10 11 13 12) (12 13 15 14) (0 2 3 1) (2 4 5 3) (4 6 7 5) ) ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object loggingProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceElevationAnyName { type waveGauge; pointDistribution lineDistribution; N 200; linestart (1.5 -0.5 0.05); lineend (11.5 -0.5 0.05); add ( 0 0.7 0); axis y; stretch 1; } // ************************************************************************* // 3. wavePropertiesinput Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object environmentalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // seaLevel 0.00; // A list of the relaxation zones in the simulation. The parameters are given // in <name>Coeffs below. relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { // Wave type to be used at boundary "inlet" and in relaxation zone "inlet"这里同时给出了boudary入口与relaxation zone入口的边界条件,合二为一 waveType stokesFirst; // Ramp time of 2 s Tsoft 1.1; // Water depth at the boundary and in the relaxation zone depth 1.035; // Wave period period 1.1; // Phase shift in the wave phi 0.000000; // Wave number vector, k. direction (3.1415926 0.0 0.0); // Wave height height 0.16; // Specifications on the relaxation zone shape and relaxation scheme relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0 -1.035 0); endX (2 0.265 0.1); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 1.1; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (9.5 -1.035 0); endX (13.5 0.265 0.1); orientation (1.0 0.0 0.0); } }; // ************************************************************************* // 4. The simulated regular waves The generated regular wave has the height of 0.18m. We can find from the figure that the wave crest is about 0.1m while the wave trough is about 0.6m. Could anyone help me with the problem? Last edited by wyldckat; March 21, 2015 at 08:36. Reason: Added [CODE][/CODE] |
March 21, 2015, 05:03 |
Stefan
Rep Power: 16 |
hi,
You may enlarge your water depth and also vary mesh density. Set-up seems to be OK. /Stefan |
March 23, 2015, 13:08 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good afternoon,
@Xiantao: First order wave theory is not applicable. Try inserting your values in one of the many diagrams of applicable wave theories and you will see what I mean. (Edit: A quick test shows that with a wave height of 0.08 m and stokesSecond you get good results. For larger wave heights, you will need theories of higher order than second) Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; October 8, 2018 at 10:11. Reason: removed answer to another post that was on the main thread |
water level inlt boundary condition | trapan13 | OpenFOAM Pre-Processing | 3 | May 22, 2018 10:16 |
Discrepancy between contour of alpha1 = 0.5 and water level from pressure probes. | JamesRunnalls | OpenFOAM Post-Processing | 0 | December 27, 2016 10:26 |
height of water level in two-phase flows? | Michael Bo | CFX | 2 | August 23, 2004 02:50 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
