[swak4Foam] Difficulties compiling with OpenFOAM v5.0
Like Tree6Likes
  • 1 Post By Antimony
  • 1 Post By mpanch13114
  • 2 Post By gu1
  • 1 Post By abbasTN
  • 1 Post By LeOtTeRz
Old   October 6, 2017, 10:09
Default Difficulties compiling with OpenFOAM v5.0
Maurício Guilherme Alves dos Reis
MauricioReis is on a distinguished road
Hi all,
Is it possible to compile swak4foam for OpenFOAM 5.0? I'm using this version https://sourceforge.net/p/openfoam-e.../develop/tree/.
MauricioReis is offline   Reply With Quote
Old   October 6, 2017, 10:53
Assistant Moderator
Bernhard Gschaider
Originally Posted by MauricioReis View Post
Hi all,
The develop-branch supports 5.0 for some time https://twitter.com/swakPyFoam/statu...29065463332864
(if you look at the commit-messages in your link you see a lot of "5.0" there)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 23, 2017, 10:07
Esmaeel Eftekharian
Esmaeelef is on a distinguished road
Hi Bernhard,
I desperately need to use openFOAM version 5 because of its ability in water wave modeling. I do need funkySetField to initialize water phase. However, swak4foam is not installed on openFOAM 5. I receive an errorr as below:
"Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard".
Is there any way to install swak4foam or at least funkySetField on OpenFOAM 5?
Esmaeelef is offline   Reply With Quote
Old   October 23, 2017, 14:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by Esmaeelef View Post
Hi Bernhard,
The development branch should compile with OF 5.0 (not the default branch. See https://openfoamwiki.net/index.php/C...am#Development)
The compilation process should complain about something else above the error message that you posted. THAT would be the interesting error message
Old   January 10, 2018, 06:10
Antimony is on a distinguished road
Tried to compile swak4Foam for OF5.0, but doesn't seem to work. Here is the log of the Allwmake process (attached)
Could someone please point as to what it is that I am missing and that is causing the error?
Also, I think the instructions page needs to be amended slightly from:
hg update development
to
hg update develop
Thank you.
Cheers,
Antimony
P.S. Apologies, I wanted to post the output here as code but encountered errors saying that the number of characters is too many. Hence it is being attached instead. And since the size of the log file exceeded allowed limit, it is being uploaded as a zip file.
AnnaF likes this.
Antimony is offline   Reply With Quote
Old   January 10, 2018, 06:55
Panchatcharam Mariappan
mpanch13114 is on a distinguished road
Dear Antimony,
All error in your log file says, it is missing the libradiationModels.so file. Could you have a quick look at your openfoam5/platform directory (in my system it is under /opt/openfoam5/platforms/linux64GccDPInt32/lib). If libradiationModels.so is missing, then there should be an error at your openfoam5 installation. Try to recompile the thermoPhysicalModels under src directory and do check if that works.
Regard
Panchatcharam
mpanch13114 is offline   Reply With Quote
Old   January 11, 2018, 00:51
Dear Panchatcharam,
Thanks! That seemed to do the trick - when OF5 was installed, apparently this library had been missed out. Since the installation was done by admin, I copied the thermoPhysicalModels to my local/user OpenFOAM directory, compiled it, added it to LD_LIBRARY_PATH.
And it worked!
Cheers,
Antimony
Old   March 9, 2018, 05:52
Saicharan
wavefunction is on a distinguished road
I am unable to find swak4Foam for OpenFOAM v5.0. I guess it is not available. If possible, kindly let me know if there is any other way to add a setFields for a scalar depending on an expression.
Thanks in advance.
wavefunction is offline   Reply With Quote
Old   March 9, 2018, 06:16
People have already used swak4Foam in OF5. You could try
hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
hg update develop
If you are using git repo, then the following should work
git checkout branches/develop
If you are in the develop branch, then ./Allwmake should work.
All the best
AnnaF likes this.
Old   May 15, 2018, 08:48
Fahime Firoozpour
Fahime is on a distinguished road
I try to install swak4foam for openfoam5 but got this error. can anyone help me with this error?
-o Make/linux64GccDPInt32Opt/helpers/exprString.o
In file included from lnInclude/CommonValueExpressionDriver.H:847:0,
from helpers/exprString.C:39:
lnInclude/CommonValueExpressionDriverI.H: In member function ‘bool Foam::CommonValueExpressionDriver::updateSet(Foam: :autoPtr<T>&, const Foam::word&, Foam::CommonValueExpressionDriver::SetOrigin) const’:
lnInclude/CommonValueExpressionDriverI.H:326:32: error: ‘class Foam::IOobject’ has no member named ‘headerOk’
header.headerOk()
lnInclude/CommonValueExpressionDriverI.H:336:43: error: ‘class Foam::IOobject’ has no member named ‘filePath’
<< header.filePath()
/opt/openfoam5/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/helpers/exprString.o' failed
make: *** [Make/linux64GccDPInt32Opt/helpers/exprString.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Fahime is offline   Reply With Quote
Old   May 16, 2018, 16:08
Assistant Moderator
Bernhard Gschaider
header.headerOk()
Which version of swak4Foam are you using? Currently only the develop-branch compiles with OF 5.0. See https://openfoamwiki.net/index.php/C...am#Development
Old   May 24, 2018, 04:44
  #12
Shailesh BG
shaileshbg is on a distinguished road
Hello All,
I am trying to install swak4foam for openFoam v5.0, these are the steps that I followed:
Dependencies:
1) Bison : bison (GNU Bison) 3.0.4
I tried with an older version (2.7), but it said swak4foam development version works with bison version >=3
2) Flex: flex 2.6.0
The first few lines of log file read:
Current OpenFOAM version is 5.0.
Previously compiled for OpenFOAM (5.0)
No file 'swakConfiguration'. Python etc won't work. See README for details
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
Checking swak4Foam-version and generating file
Swak version is 0.4.2
abort: there is no Mercurial repository here (.hg not found)
Could not get version of the sources
Bison: /usr/bin/bison
Flex: /usr/bin/flex
Bison is version 3.0.4
Flex is version 2.6.0 (Minor version: 0)
OpenFOAM-version: Major 5 Minor 0 Patch 0 (-1 == x / 0) Fork: org
No change to swak4FoamParsers/foamVersion4swak.H
Downloading: I tried from these three different sources but I get the same error every time.
1) I tried downloading from the Mercurial development repository.
2) Manually download a snapshot from the Mercurial interface at Sourceforge.net.
3) Mirror Git repository
Tried installing by running
./Allwmake > log.make 2>&1
in my run folder.
Error:
../../Libraries/swak4FoamParsers/lnInclude/preloadFieldsFunction.H:65:13: error: no matching function for call to ‘Foam::IOobject::typeHeaderOk(bool, bool, bool)’
             if
In file included from /opt/openfoam5/src/OpenFOAM/lnInclude/regIOobject.H:41:0,
                 from /opt/openfoam5/src/OpenFOAM/lnInclude/objectRegistry.H:39,
                 from /opt/openfoam5/src/OpenFOAM/lnInclude/Time.H:42,
                 from /opt/openfoam5/src/finiteVolume/lnInclude/fvCFD.H:6,
                 from funkyDoCalc.C:42:
/opt/openfoam5/src/OpenFOAM/lnInclude/IOobject.H:433:18: note: candidate: template<class Type> bool Foam::IOobject::typeHeaderOk(bool)
             bool typeHeaderOk(const bool checkType = true);
/opt/openfoam5/src/OpenFOAM/lnInclude/IOobject.H:433:18: note:   template argument deduction/substitution failed:
In file included from funkyDoCalc.C:296:0:
../../Libraries/swak4FoamParsers/lnInclude/preloadFieldsFunction.H:65:13: note:   candidate expects 1 argument, 3 provided
             if
../../Libraries/swak4FoamParsers/lnInclude/preloadFieldsFunction.H: In instantiation of ‘void preLoadFieldsFunction(const Foam::DynamicList<Foam::fvMesh*>&, const wordList&, Foam::PtrList<T>&) [with FieldType = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::wordList = Foam::List<Foam::word>]’:
funkyDoCalc.C:472:13:   required from here
The log file ends by saying:
/opt/openfoam5/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/funkyDoCalc.o' failed
make[1]: *** [Make/linux64GccDPInt32Opt/funkyDoCalc.o] Error 1
make[1]: Leaving directory '/home/shailesh/OpenFOAM/shailesh-5.0/run/swak4Foam/Utilities/funkyDoCalc'
/opt/openfoam5/wmake/makefiles/apps:39: recipe for target 'funkyDoCalc' failed
make: *** [funkyDoCalc] Error 2
I have attached the tarball of the log file.
I had both openFoam v4.0 and v5.0 installed on my system, was working with aliases to access them. Before trying to install swak I deleted v4.0 and removed the aliases from my ./bashrc and I am using zsh now. I am not sure if this is the source of the errors.
Thanks and regards,
Shailesh
Regards,
Shailesh
shaileshbg is offline   Reply With Quote
Old   September 8, 2018, 10:09
gu1
Guilherme
gu1 is on a distinguished road
I'm trying to compile swak4Foam in OF5.0 and after all the processes mentioned in that forum topic, I got the following error:
CommonValueExpressionDriver.C: In member function ‘Foam::tmp<Foam::Field<double> > Foam::CommonValueExpressionDriver::makeGaussRandom Field(Foam::label) const’:
CommonValueExpressionDriver.C:1277:48: error: ‘class Foam::Random’ has no member named ‘scalarNormal’
const_cast<scalar&>(result()[i]) = rnd.scalarNormal();
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam5/src/finiteVolume/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/sampling/lnInclude -I/opt/openfoam5/src/fileFormats/lnInclude -I/opt/openfoam5/src/triSurface/lnInclude -I/opt/openfoam5/src/dynamicMesh/lnInclude -I/opt/openfoam5/src/lagrangian/basic/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/opt/openfoam5/src/OpenFOAM/lnInclude -I/opt/openfoam5/src/OSspecific/POSIX/lnInclude -fPIC -c FieldValueExpressionDriver.C -o Make/linux64GccDPInt32Opt/FieldValueExpressionDriver.o
/opt/openfoam5/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/CommonValueExpressionDriver.o' failed
make: *** [Make/linux64GccDPInt32Opt/CommonValueExpressionDriver.o] Error 1
All log can be see here: https://paste.ubuntu.com/p/X5q284RZmM/
gu1 is offline   Reply With Quote
Old   September 11, 2018, 17:41
Post
  #14
Soledad Fioroni
Sole is on a distinguished road
I'm having trouble compiling swak4Foam as well.
Flex is version 2.6.4
OpenFOAM-version: 5.0
This is basically the error message I get. However, I attach the log file for practical purposes.
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/finiteVolume/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/surfMesh/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/sampling/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/fileFormats/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/triSurface/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/dynamicMesh/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/lagrangian/basic/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/surfMesh/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/OpenFOAM/lnInclude -I/home/mys/OpenFOAM/OpenFOAM-5.0/src/OSspecific/POSIX/lnInclude -fPIC -c CommonValueExpressionDriver.C -o Make/linux64GccDPInt32Opt/CommonValueExpressionDriver.o
CommonValueExpressionDriver.C:1277:48: error: ‘class Foam::Random’ has no member named ‘scalarNormal’; did you mean ‘GaussNormal’?
GaussNormal
I hope any of you could help me figure out what I'm missing.
Thank you very much in advance
Sole
Sole is offline   Reply With Quote
Old   November 26, 2018, 23:56
Leandro
LeOtTeRz is on a distinguished road
Originally Posted by Sole View Post
Sole
Hello Soledad and Guilherme.
I have the same error of you, could you solve it? if you could, how?
Could you please help?
I attach my log file.
Thanks
Leandro
LeOtTeRz is offline   Reply With Quote
Old   November 27, 2018, 06:39
gu1
Guilherme
Thanks
Leandro
I solved this problem by modifying lines 1271 through 1282 in the /swak4Foam/Libraries/swak4FoamParsers/CommonValueExpressionDriver.C file.
Foam::Random rnd(seed);
forAll(result(),i) {
#ifdef FOAM_RANDOM_CLASS_NEW_INTERFACE
const_cast<scalar&>(result()[i]) = rnd.GaussNormal<scalar>();
#else
#ifdef FOAM_RANDOM_CLASS_GAUSS_RENAMED
const_cast<scalar&>(result()[i]) = rnd.GaussNormal();
#else
#endif
#endif
billie and Sole like this.
Old   November 30, 2018, 14:34
Default solved
  #17
Abbas Tavakolinik
abbasTN is on a distinguished road
Originally Posted by gu1 View Post
Thank you so much
gu1 likes this.
abbasTN is offline   Reply With Quote
Old   December 5, 2018, 03:44
Daniel Pielmeier
billie is on a distinguished road
Thanks this makes swak4foam compile with OpenFOAM-5.
If this is really the correct fix, the change should look probably like the following:
--- Libraries/swak4FoamParsers/CommonValueExpressionDriver.C    2018-11-07 13:11:41.418290528 +0100
+++ Libraries/swak4FoamParsers/CommonValueExpressionDriver.C    2018-12-05 08:07:08.303401756 +0100
@@ -1273,9 +1273,6 @@
 #else
-#ifdef FOAM_RANDOM_CLASS_GAUSS_RENAMED
-        const_cast<scalar&>(result()[i]) = rnd.scalarNormal();
-#else
 #endif
 #endif
However as swak4foam supports a few more OpenFOAM forks the change should probably look different. OpenFOAM-6 and OpenFOAM-dev do not require this change.
Probably instead the if clause defining FOAM_RANDOM_CLASS_GAUSS_RENAMED in Libraries/swak4FoamParsers/include/swak.H should be like:
--- Libraries/swak4FoamParsers/include/swak.H   2018-11-07 13:06:13.534290528 +0100
+++ Libraries/swak4FoamParsers/include/swak.H   2018-12-05 08:28:17.381623756 +0100
@@ -546,7 +546,7 @@
 #define FOAM_RANDOM_CLASS_NEW_INTERFACE
 #endif
-#if (defined(FOAM_VERSION4SWAK_IS_ORG) && FOAM_VERSION4SWAK>=VERSION_NR(5,0,0))
+#if (defined(FOAM_VERSION4SWAK_IS_ORG) && FOAM_VERSION4SWAK>=VERSION_NR(6,0,0))
 #define FOAM_RANDOM_CLASS_GAUSS_RENAMED
 #endif
This is because the the change to rnd.scalarNormal() from rnd.GaussNormal<scalar>() started with OpenFOAM-6.
No C++ programmer though thus I don't know whats the difference between
which is defined in swak.h for ESI OpenFOAM but also used by original OpenFOAM and
which does not exist in OpenFOAM-5,6,dev.
billie is offline   Reply With Quote
Old   December 27, 2018, 18:49
Leandro
Thank you very much Guilherme, works perfectly.
gu1 likes this.
Old   October 16, 2019, 01:58
Default I really need your help!
  #20
chunping ren
handsomedog is on a distinguished road
I met the problems which are same to you ever. Have you solved them? Could you help me?
openfoam 5 has been installed on my computer.
The installation steps as follows:
1. mkdir -p $FOAM_RUNcd "$HOME/OpenFOAM/$USER-$WM_PROJECT_VERSION"
2.svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x
3. ./Allwmake
4. ./maintainanceScripts/compileRequirements.sh
5. ./Allwmake
/home/rcp/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
Swak version is 0.4.1
Bison is version 2.7.12-4996
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 5 Minor 0 Patch 0 (-1 == x / 0) Fork: openfoam
wmake libso swak4FoamParsers
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam5/src/finiteVolume/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/sampling/lnInclude -I/opt/openfoam5/src/fileFormats/lnInclude -I/opt/openfoam5/src/triSurface/lnInclude -I/opt/openfoam5/src/dynamicMesh/lnInclude -I/opt/openfoam5/src/lagrangian/basic/lnInclude -I/opt/openfoam5/src/surfMesh/lnInclude -I/opt/openfoam5/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/opt/openfoam5/src/OpenFOAM/lnInclude -I/opt/openfoam5/src/OSspecific/POSIX/lnInclude -fPIC -c helpers/exprString.C -o Make/linux64GccDPInt32Opt/helpers/exprString.o
header.headerOk()
make: *** [Make/linux64GccDPInt32Opt/helpers/exprString.o] error 1
thanks in advance.
Chunping Ren
handsomedog is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[OpenFOAM.com] Compiling v1806 from source Sgs OpenFOAM Installation 10 January 20, 2019 21:46
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
