[waves2Foam] objectRegistry region0 failed
Like Tree1Likes
  • 1 Post By ngj
Old   November 14, 2016, 13:44
Default objectRegistry region0 failed
Gautami Erukulla
gautami is on a distinguished road
Dear Dr. Jacobsen,
I am trying to simulate the tutorial waveFlume in parallel and the sequence of commands used are as follows:
• blockMesh
• cp –r 0.org 0 (The case directory had 0.org,constant and system folders)
• setWaveParameters
• setWaveField
• decomposePar
After the command decomposePar, the following error is displayed:
Request for dictionary waveProperties from objectRegistry region0 failed available objects of type dictionary are
4
decompseParDict
fvSchemes
fvSolution
data
The method used for domain decomposition in the decomposeParDict under system folder is ‘hierarchical’.
numberOfSubdomains is 4
hierarchicalCoeffs
n (2 2 1)
delta 0.001
order xyz
Kindly can you please provide me your guidance. Thank you for your time.
Most&More,
Gautami Erukulla.
Last edited by wyldckat; August 25, 2018 at 08:39. Reason: removed reference to post that I've deleted from referenced thread
gautami is offline   Reply With Quote
Old   November 15, 2016, 03:50
Paritosh Vasava
vasava will become famous soon enough
Not an expert on waveFoam but I recommend to
  1. check spellings and formats in the waveProperties file
  2. check all the domain and boundary names in the waveProperties file.
  3. check header of the waveProperties file.
vasava is offline   Reply With Quote
Old   November 15, 2016, 04:27
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
No, the problem is related to the fact that the waveProperties-file is not loaded with decomposePar and waveProperties is required by the boundary conditions waveAlpha and waveVelocity.
I am often completely ignoring waveAlpha and waveVelocity, since I have a relaxation zone in front. Alternatively, you can use changeDictionary functionality to switch back and forth between a dummy zeroGradient and the true boundary condition.
I will put it on my to-do list to resolve this issue.
Kind regards,
Niels
Linmunn likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   November 15, 2016, 13:14
Gautami Erukulla
Dear Dr. Jacobsen,
Thank you for your reply. As suggested will try using 'changeDictionary' option for now.Thank you.
Most&More,
Gautami Erukulla.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
