[IHFOAM] IHFOAM patch problem IH_Waves_InletVelocity
Like Tree1Likes
  • 1 Post By IHFOAM Team
Old   February 22, 2018, 11:56
Default IHFOAM patch problem IH_Waves_InletVelocity
Jorge Molines
jormollo is on a distinguished road
Hi!
I have downloaded and installed OpenFoam and Ihfoam and I have a problem with the patchField type IH_Waves_InletVelocity. My versions are Ubuntu 16.04, OpenFoam 1706 and ihFoam 1706 downloaded from http://ihfoam.ihcantabria.com/source-download/.
Both installations of OpenFoam and ihFoam finished succesfully. I am running an example of a breakwater with porous media that I also downloaded from the web prepared for OF 230_240 and I modified some patches and the mode of the operating solver from PIMPLE to PISO. However, I do not know how to solve the new problem . Thanks in advance for any advise,
Jorge.
jorge@jorge-VirtualBox:~/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater$ ihFoam
| \\ / O peration | Version: v1706 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : v1706
Arch : "LSB;label=32;scalar=64"
Exec : ihFoam
Date : Feb 22 2018
Time : 16:49:22
Host : "jorge-VirtualBox"
PID : 26351
Case : /home/jorge/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field porosityIndex
Porosity activated
Reading porosity variables
Number of materials: 4
a = 4(0 50 50 50)
b = 4(0 1.2 2 0.6)
c = 4(0 0.34 0.34 0.34)
D50 = 4(1 0.01 0.035 0.12)
porosity = 4(1 0.49 0.493 0.5)
Transient formulation is 0
Creating fields: porosity, aPor, bPor, cPor and D50Por
Reading field p_rgh
Reading field U
--> FOAM FATAL IO ERROR:
Unknown patchField type IH_Waves_InletVelocity for patch type patch
Valid patchField types are :
81
SRFFreestreamVelocity
SRFVelocity
SRFWallVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicACMI
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
extrapolatedCalculated
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalInletOutletVelocity
fixedNormalSlip
fixedProfile
fixedShearStress
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
interstitialInletVelocity
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
noSlip
nonuniformTransformCyclic
outletInlet
outletMappedUniformInlet
outletPhaseMeanVelocity
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
pressurePIDControlInletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetry
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentDFSEMInlet
turbulentInlet
uniformFixedGradient
uniformFixedValue
uniformInletOutlet
uniformJump
uniformJumpAMI
variableHeightFlowRateInletVelocity
waveTransmissive
waveVelocity
wedge
zeroGradient
file: /home/jorge/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater/0/U.boundaryField.inlet from line 26 to line 28.
From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam:imensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>]
in file /home/jorge/OpenFOAM/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 134.
FOAM exiting
jormollo is offline   Reply With Quote
Old   February 26, 2018, 08:23
IHFOAM Team's Avatar
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
IHFOAM Team is on a distinguished road
Hi Jorge,
I just add here the answer I already sent you in case anyone might need it:
IHFOAM boundary conditions are now implemented and released within OpenFOAM (since version v1612+) thanks to an agreement between ESI & IH-Cantabria.
(https://www.openfoam.com/releases/op...ave-generation)
You can find several tutorials in:
~/OpenFOAM-XXX/tutorials/multiphase/interFoam/laminar/waveExampleXX
If you want to use the old ihFOAM tutorials, you must just change and adapt the names of the BC's.
Best Regards,
IHFOAM Team.
jormollo likes this.
IHFOAM Team is offline   Reply With Quote
Old   February 28, 2018, 11:07
Jorge Molines
Thanks for your answer!
Regards,
Jorge.
Old   October 23, 2018, 00:26
Luo_Bingjun
Robin86 is on a distinguished road
Hello!I meet the same problem as you. The error "Unkown IHFOAM patch problem IH_Waves_InletVelocity" happens. My version is of v1806. How can I solve this problem. Thank you!
Robin86 is offline   Reply With Quote
Old   October 23, 2018, 04:08
Hi Robin86
Originally Posted by Robin86 View Post
How can I solve this problem.?
Please, canyou tell me which version of IHFoam have you tried to used with OpenFOAM-v1806?
Regards,
IHFOAM Team
Old   October 23, 2018, 04:42
Luo_Bingjun
I use OpenFoam v1806 and ihFoam v1806.
Old   October 25, 2018, 22:52
Luo_Bingjun
I use OpenFOAM 1806 to run the IHFOAM old version tutorials. The same problem "Unknown patchField type IH_Waves_InletVelocity" appears, just like the above problem. How can I solve it? Should I change the old version tutorials BC's? Which BC needs to be changed and how to change it? I am new OpenFOAM user. Thank you!
Old   November 6, 2018, 10:32
Hi Robin86,
There is no point in using the old version of IHFOAM with OpenFOAM-v1806.
Why? Because, IHFOAM boundary conditions are already implemented within OpenFOAM-v1806 in a more accurate and faster way than the first release.
Can I ask you why do you want to do this strange thing?
Best Regrards,
IHFOAM Team
Old   November 6, 2018, 21:34
Luo_Bingjun
Actually, I want to run the old tutorials to understand how to monitor free surface of wave. The old tutorials realize this while the tutorials in OpenFOAM 1806 do not. How to draw the curve of wave elevation and time in specified location? Thank you!
Old   November 7, 2018, 03:49
Hi Robin86,
We have added some monitoring tools in the controlDict (free surface sensors) to be able to track and draw the free surface elevation in time in a specific location.
Please, take a look to the end of the controlDict:
functions
    line
        type            sets;
        libs            ("libsampling.so");
        enabled         true;
        writeControl    writeTime;
        writeInterval   1;
        interpolationScheme cellPoint;
        setFormat       raw;
        sets
            line1
                type    uniform;
                axis    distance;
                start   ( 1.0 0.02 0.0 );
                end     ( 1.0 0.02 0.55 );
                nPoints 1001;
            line2
                type    uniform;
                axis    distance;
                start   ( 2.0 0.02 0.0 );
                end     ( 2.0 0.02 0.55 );
                nPoints 1001;
            line3
                type    uniform;
                axis    distance;
                start   ( 3.0 0.02 0.0 );
                end     ( 3.0 0.02 0.55 );
                nPoints 1001;
            line4
                type    uniform;
                axis    distance;
                start   ( 5.0 0.02 0.0 );
                end     ( 5.0 0.02 0.55 );
                nPoints 1001;
            line5
                type    uniform;
                axis    distance;
                start   ( 7.5 0.02 0.0 );
                end     ( 7.5 0.02 0.55 );
                nPoints 1001;
            line6
                type    uniform;
                axis    distance;
                start   ( 10.0 0.02 0.0 );
                end     ( 10.0 0.02 0.55 );
                nPoints 1001;
            line7
                type    uniform;
                axis    distance;
                start   ( 12.0 0.005 0.0 );
                end     ( 12.0 0.005 0.55 );
                nPoints 1001;
            line8
                type    uniform;
                axis    distance;
                start   ( 14.0 0.005 0.0 );
                end     ( 14.0 0.005 0.55 );
                nPoints 1001;
        fixedLocations  false;
        fields
            U alpha.water
Best Regards,
IHFOAM Team
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 37 November 29, 2024 11:15
[Gmsh] Single volume Mesh gmsh PeteH OpenFOAM Meshing & Mesh Conversion 9 August 6, 2013 09:54
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
