[Tutorials] Flow induced rotation with AMI and 6DOF
Like Tree1Likes
  • 1 Post By Tobi
Old   January 24, 2018, 09:44
Default Flow induced rotation with AMI and 6DOF
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear Community,
I am happy to announce a new tutorial that combines the AMI boundary condition and 6DOF library in order to build a flow induced rotation of a vertical axis wind turbine also named VAWT. The case is published on my website. Enjoy.
Case: https://holzmann-cfd.com/community/training-cases/vertical-axial-wind-turbine
Video: https://www.youtube.com/watch?v=N0MN79bpl58
PS: Did you realize the fluctuations of the passive scalar? Can you explain it?
zfaraday likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   July 13, 2021, 06:03
Pedro
phelps is on a distinguished road
Hi Tobi,
First of all I would like to thank you for all your work, I have learned a lot about OpenFoam thanks to you.
Also, I would like to ask you something about this case. I'm trying to study the effects of the wake produced by a turbine into another turbine next to the first one, so I need to implement 6DoF for both turbines, but I'm unable to achieve this.
I have tried tons of solutions over the past week, but none seems to work in OpenFoam 8. Could you please shed a light on how to get more than one object with flow induced movement? I would be very gratefull.
Thank you.
phelps is offline   Reply With Quote
Old   July 14, 2021, 04:48
Tobi's Avatar
Tobias Holzmann
Hi Pedro,
thank you for your feedback. It is good to know that my work supports the community. To your question: As far as I know, OpenFOAM-8 cannot handle two 6-DoF zones. I guess the ESI version does have a library which allows you to use as much 6 DOF zones as you want. (This is my personal idea without checking the Foundation/ESI version regarding your problem).
Tobi
Keep foaming,
Tobias Holzmann
Old   July 15, 2021, 19:55
Pedro
Hello Tobias,
Thanks for your answer, it was very helpful. I installed ESI version (OpenFOAM 2012) and as you said, I' ve been able to set two 6DoF using dynamicMotionSolverListFv.
I've been able to start the simulation, however, it crashes after a few minutes. Checking the log file I've seen that time step continuity error gets huge, as well as bounding k and omega. So I guess I will have to change some discretization schemes.
Anyway, I don't want to bother you with this matter and I know this is not the right thread for this issues, but I wanted to thank you and leave this reply, someone may find helpful to know that you were right.
Best regards,
Pedro.
Old   October 7, 2022, 05:41
Default Mesh moves around AMI
okay to be anonymous
ExtRas is on a distinguished road
Dear Tobias,
I tried to apply the dynamicMeshDict of this tutorial and the Kaplan turbine one to a custom VAWT (an anemometer in fact). What a find, is the AMI interface is not really used. The mesh is morphed around AMI or around the solid depending on the inner / outer distance I choose.
I use OF2206, but I dont think the problem is my version of Openfoam.
In pointDisplacement, AMI1 and AMI2 are set to cyclicAMI. I think everything is well defined, I don't understand why the AMI is "sticky".
Did you experienced this kind of troubles when you worked on this case ?
B.R.
Marc
ExtRas is offline   Reply With Quote
Old   October 7, 2022, 08:44
Tobi's Avatar
Tobias Holzmann
I don't get your statement:
the AMI is not used
You know that if you use my stuff, its a flow-induced rotation. Hence, you need to change also the moment of inertia and stuff like that. You cannot simply copy paste my files.
Keep foaming,
Tobias Holzmann
Old   October 8, 2022, 10:43
Thanks for answering.
In fact, I am trying to have the anemometer rotating with the fluid forces. I do not want the mesh to be morphed and I would like that only the mesh inside the AMI, turns. Obviously I changed the values of the moment of inertia by the one given by Salome.
But what I got, is an uggly morphed mesh around the AMI and / or inside the AMI, depending on my BC in pointDisplacement and my inner or outer distances in the dynamicMeshDict.
Here they are :
|  \\    /   O peration     | Version:  9                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       pointVectorField;
    location    "0";
    object      pointDisplacement;
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    AMI1
        type            fixedValue;
        // type            cyclicAMI;
        value           uniform (0 0 0);
    AMI2
    type fixedValue;
        // type            calculated;
        // type            cyclicAMI;
    inlet
        type            fixedValue;
    outlet
        type            fixedValue;
    walls
        type            fixedValue;
    stator
        type            fixedValue;
    rotor
        type            calculated;
I tried a lot of stuff for the AMI BC : fixedValue, cyclicAMI, calculated, but the mesh is still morphed.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh      dynamicMotionSolverFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
motionSolver            sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
    //- The following stuff is read from the rigidBodyMeshMotionSolver class
    //  lOD = lookupOrDefault | l = lookup
    //  :: l :: patches
    //  :: l :: innerDistance
    //  :: l :: outerDistance
    //  :: l :: g                   (only if g is in db())
    //  :: lOD :: test              (default = false) | test mode, only g act
    //  :: lOD :: rho               (default = rho)   | needed for inco.
    //                              if rho = rhoInf -> lookup rhoInf value
    //- List of mesh patches associated with the solid body
    patches         (rotor);
    //- Inner morphing distance (limit of solid-body region)
   innerDistance   0.0;
    //- Outer morphing distance (limit of linear interpolation region)
    outerDistance   0.1;
    //- Note: Based on innterDistance and outerDistance, we make a pointField
    //  that scales the morphing stuff (see also in the source code)
    //- Gravitational acceleration if g is used in the calculation
    //g               (0 0 0);
    //- Denisty name (normally rho but for incompressible cases we have to
    //  specify rhoInf and set the density). Each name different from rhoInf
    //  will be treated as variable. E.g. if we set rhoTest, FOAM search for
    //  a reserved rhoTest quantity
    rho             rhoInf;
    //- For incompressible cases [kg/m^3]
    rhoInf          1.2;
    //- The following stuff is read from the sixDoFRigidBodyMotion class and
    //  sixDoFRigidBodyMotionState
    //  :: l ::  mass
    //  :: l ::  momentOfInertia
    //  :: lOD :: initialCentreOfMass       (default = l :: centreOfMass)
    //  :: lOD :: centreOfRotation          (default = l :: centreOfMass)
    //  :: lOD :: initialOrientation        (default = l :: orientation)
    //  :: lOD :: orientation               (default = identiy matrix I)
    //  :: lOD :: accelerationRelaxation    (default = 1)
    //  :: lOD :: accelerationDumping       (default = 1)
    //  :: lOD :: report                    (default = false)
    //  :: lOD :: velocity                  (default = (0 0 0))
    //  :: lOD :: acceleration              (default = (0 0 0))
    //  :: lOD :: angularMomentum           (default = (0 0 0))
    //  :: lOD :: torque                    (default = (0 0 0))
    //  -- need subDicts
    //          "solver"
    //     and read if found
    //          "restraints"
    //          "constraints"
    //- Mass of VATK [kg]
    //  Volume in the geomtetry is V = 0.000461158 m^3
    //  Volume of the blades is V = 0.0000687109 m^3
    //  CFK rho = 1.5g/cm^3 = 1.5e-3 kg/cm^3 = 1.5e-3 * 100 * 100 * 100 kg/m^3 [kg/m^3]
    mass        0.48;
    //- Salome calculation
    // IX IY IZ = (0.0053176 0.0053176 0.0103473) based on rho = 1
    // IX IY IZ = (6.898e-6 3.54533e-6 3.545e-6) based on rho = 1
    momentOfInertia (0.000125702 7.57408e-05 7.57408e-05);
    //- Intial center of mass (default) and centre of rotation of the rigid-body
    centreOfMass (0. 0. -0.01156);
    centreOfRotation (0. 0. -0.01156);
    //- Intial center of mass of the rigid-body (used if CenterOfMass move)
    //initialCenterOfMass     (0.1 0.025 0.00125);
    //- Initial orientation of the rigid-body (default) and rotational orient.
    orientation
        1 0 0
        0 1 0
        0 0 1
    //- Initial orientation of the rigid-body (used if orientation differs)
    //initialOrientation
    //    1 0 0
    //    0 1 0
    //    0 0 1
    //- Linear velocity of the rigid-body
    velocity        (0 0 0);
    //- Total linear acceleration of the rigid-body
    acceleration    (0 0 0);
    //- Angular momentum of the rigid-body in local reference frame
    angularMomentum (0 0 0);
    //- Total torque on rigid-body in local reference frame
    torque          (0 0 0);
    //- Report motion data
    report          on;
    //- Acceleration relaxation coeff [0-1]
    //accelerationRelaxation 0.7;
    //- Acceleration dumping coeff (for steady-state simulations) [0-1]
    //accelerationDumping 0.1;
    //- Motion Solver (for AMI not really needed); more related to
    //  moving rigids while the mesh is deformed - not with AMI
    //  Options:
    //  Newmark
    //  Crank-Nicolsen
    //  and others possible
    solver
        type Newmark;
    //- Section for constraints
    //  Checkout the openfoamwiki or the source code
    constraints
        //- Arbitrary name
        zAxis
            //- Fix the axis
            //  Here: rigid-body cannot move in x and z and rotate
            //  But we could move in y direction
            sixDoFRigidBodyMotionConstraint axis;
            axis (0 0 1);
        //- Arbitrary name
        fixedPt
            //- Fix the point
            //  Here: motion also avoided in y direction
            //  Only possibility now -> rotate arount y axis
            sixDoFRigidBodyMotionConstraint point;
            centreOfRotation (0 0 -0.01156);
    //- Section for restraints
    restraints
        //- Some dumping functions
        /*translationDamper
                //- Nms/rad
                //  Acts against motion as friction
                sixDoFRigidBodyMotionRestraint  sphericalAngularDamper;
                coeff 0.05;
I am pretty sure it is something obvious that I do not understand. Maybe with the inner and outer distances.
I attach some pictures of the mesh.
Best regards,
Marc
Old   October 10, 2022, 07:18
Tobi's Avatar
Tobias Holzmann
The one from Salome are not correct.
Use the surfaceInertia tool to determine the stuff. My Tutorials are wrong in that sense.
Keep foaming,
Tobias Holzmann
Old   October 11, 2022, 11:13
I think I found the solution.
In fact, the problem was the mesh.
I changed 2 parameters :
1 - (Maybe) the AMI was too close to the solid body
2 - the bottom of the rotor was coincident to the AMI.
Now the AMI is far from the rotor.
If I understand well, even if a want to connect a stator to the rotor (a fixed body connected to a rotating body), it is better to include it inside the rotating zone and to have an AMI far enough to the geometry. (?)
************** EDIT: ****************************
After some tests, I can answer by myself :
If there are non-rotating bodies or parts of non-rotating bodies inside the rotating zone delimitated by the AMI, they have to correspond to a specific patch (or several specific patches).
The non-rotating patches inside the rotating zone have to be set to "noslip" in U BC, and "calculated" in pointDisplacement BC. Tobias's Kaplan turbine tutorial is a good example (see patches "staticWall" and "staticMovingWall").
I am sorry if it was obvious for the most of us but It was not for me as I do not work so much with AMIs.
Best regards
Marc
Old   October 12, 2022, 04:09
Tobi's Avatar
Tobias Holzmann
The AMI cannot be too close. It is a matter of the parameters you specify in the dynamicMeshDict.
To your statement. No. A stator is static and is not inside the AMI. Everything inside the AMI is rotating and a stator is not rotating.
Keep foaming,
Tobias Holzmann
Old   October 12, 2022, 06:53
Ok.
That explains why it never works when I add the stator.
I have to look further into your Kaplan tutorial to understand how works the AMI.
In the picture enclosed to this post (it is part of the Kaplan tutorial geometry), the AMI is in blue, and the pink patches inside the AMI looks like non-rotating parts of a real Kaplan turbine.
What physically happens inside this simulation ? (For now I am not able to make it run, I should install an older version of OF)
The fluid passes through the rotor and makes the whole AMI turns. (?)
1 -- Does the fluid at the wall on the pink patches turn with the AMI
or
2 -- is it static like the rest of the walls of the kaplan turbine in red ?
The hypothesis 2 would explain, in U BC, the differences between "movingWallVelocity" for the rotor and "noslip" for the rest of the walls.
Old   February 13, 2023, 03:37
vin_of is on a distinguished road
Originally Posted by Tobi View Post
Dear Community,
Dear Tobias,
Thanks for your great tutorial case! This is very helpful to me. Here I have two questions:
1. Did the case considered the load torque exerted by electric generator, or just omitted it? The load torque by generator is generally described by k*omega (k is a constant, and omega is the rotational speed).
2. If the load torque is not included in this case, any method/procudure to add this term in the setup?
Many thanks in advance if you could provide any thoughts or suggestions!
Sincerely,
Vin
vin_of is offline   Reply With Quote
Old   December 30, 2023, 04:27
Default How to enable wall collusion in 6DOF
  #13
JunaidAhmad's Avatar
Junaid Ahmad Khan
JunaidAhmad is on a distinguished road
Dear Tobi
Thanks to your and foam community efforts I learn a lot of openfoam, salome.
Sir i am trying to incorporate wall collusion in this freefall simulation and want this cube collide with wall and change its direction accordingly. I want a finite patch to act as constraint. In plane constraint of 6DOF it use an infinite plane but i want a finite plan.
Kindly point me in right direction.
Regards,
Junaid
JunaidAhmad is offline   Reply With Quote
[snappyHexMesh] combining AMI and 6dof rigid bidy motion mo_na OpenFOAM Meshing & Mesh Conversion 0 July 25, 2016 10:24
