Rep Power: 16 ![]() |
Hi All,
I would like to run series of OpenFoam simulations using PyFoam and concurrently, i.e running multiple simulation in parallel. I created Python script using PyFoam and joblib. The script works perfectly fine when each simulation itself is running in serial. However, when I want to run each simulation in parallel then the script still works but simulations gets very slow. For example, I have 64 cores and I want to use 2 processors for each simulations, so basically running 32 parallel simulations concurrently. I checked the CPU usage and when I run the script in parallel then some of processors have very low usage which does not happen when running in serial. Here is my script and I would highly appreciate if anyone can give me some comments/hints to resolve the issue. I was wondering if it has something to do with then LAMMachine settings (maybe specifying node numbers)? Many thanks in advance Ashkan Code:
import sys,os import numpy as np from os import path from PyFoam.Execution.UtilityRunner import UtilityRunner from PyFoam.Execution.BasicRunner import BasicRunner from PyFoam.Infrastructure.ClusterJob import SolverJob from PyFoam.RunDictionary.SolutionFile import SolutionFile from PyFoam.RunDictionary.SolutionDirectory import SolutionDirectory from PyFoam.RunDictionary.ParsedParameterFile import ParsedParameterFile from PyFoam.Execution.ParallelExecution import LAMMachine from PyFoam.Basics.DataStructures import Vector from PyFoam.Error import error from joblib import Parallel, delayed import multiprocessing ############################################################################################ num_cores = multiprocessing.cpu_count() #number of cores on machine OFcpus = 2 #number of CPUs for each simulation num_cases_paral = int(num_cores/OFcpus) print(num_cases_paral) solver="simpleFoam" OrigCase="BaseCase" curpath=os.path.abspath('.') nu = 1.e-6; Leng = 8.0; U0 = 0.; Ue = 2.0; dU = .1 NumUin = int((Ue - U0)/dU) + 1 CurrVel = np.linspace(U0,Ue,NumUin,endpoint=True) roughness = np.array([5e-6, 4e-5, 2e-3, 4e-2]) ############################################################################################ #---------------------defining the function for cloning and running-------------------- def Run_Case(iu,ir) : flowVelocity = CurrVel[iu]; ks = roughness[ir]; #-------Estimating initial values---------- flowRe = flowVelocity*Leng/nu TurbInt = 0.168*pow(flowRe,-1./8.) turbulentKE = (3./2.)*pow((flowVelocity*TurbInt),2.) turbulentEpsilon = pow(0.09,3./4.)*pow(turbulentKE,3./2.)/(0.07*Leng); turbulentOmega = np.sqrt(turbulentKE)/(0.07*Leng); #-------Creating new case directory---------- NewCase="CurrProfile"+"Uc_"+str(flowVelocity)+"Ks_"+str(ks) orig=SolutionDirectory(OrigCase,archive=None,paraviewLink=False) case=orig.cloneCase(NewCase) dire=SolutionDirectory(NewCase,archive=None,paraviewLink=False) #-------Modifying initial conditions---------- velFile=ParsedParameterFile(path.join(dire.initialDir(),"U")) velFile["internalField"].setUniform(Vector(flowVelocity,0,0)) velFile["boundaryField"]["inlet"]["average"]=Vector(flowVelocity,0,0) velFile.writeFile () pressFile=ParsedParameterFile(path.join(dire.initialDir(),"p")) pressFile["internalField"].setUniform(0) pressFile.writeFile () kFile=ParsedParameterFile(path.join(dire.initialDir(),"k")) kFile["internalField"].setUniform(turbulentKE) kFile["boundaryField"]["inlet"]["average"]=turbulentKE kFile.writeFile () omegaFile=ParsedParameterFile(path.join(dire.initialDir(),"omega")) omegaFile["internalField"].setUniform(turbulentOmega) omegaFile["boundaryField"]["inlet"]["average"]=turbulentOmega omegaFile.writeFile () epsilonFile=ParsedParameterFile(path.join(dire.initialDir(),"epsilon")) epsilonFile["internalField"].setUniform(turbulentEpsilon) epsilonFile["boundaryField"]["inlet"]["average"]=turbulentEpsilon epsilonFile.writeFile () nutFile=ParsedParameterFile(path.join(dire.initialDir(),"nut")) nutFile["boundaryField"]["bottom"]["Ks"].setUniform(ks) nutFile.writeFile () #-------Meshing---------- os.system('m4 '+NewCase+'/system/blockMeshDict.m4'+' > '+NewCase+'/system/blockMeshDict') blockRun = BasicRunner(argv=["blockMesh","-case",NewCase],silent=True,logname="Blocky") print("Running blockMesh") blockRun.start() if not blockRun.runOK() : error("There was a problem with blockMesh in Case ",NewCase) #-------decomepose the case---------- decompRun = UtilityRunner(argv=["decomposePar -force","-case",NewCase,],silent=True) print("Decomposing the case") decompRun.start() if not decompRun.runOK() : error("There was a problem with decomposPar in Case ",NewCase) #--------Run the simulation in parallel-------------- machine = LAMMachine(nr=OFcpus) print("Running case",NewCase) theRun = BasicRunner(argv=[solver,"-case",NewCase], silent=True, lam=machine) theRun.start() #------------------------Running the Function in parallel----------------------- Parallel(n_jobs=num_cases_paral)(delayed(Run_Case)(i, j) for j in range(len(roughness)) for i in range(1,len(CurrVel))) |
Taher Chegini
Rep Power: 12 ![]() |
OpenFOAM has a lot of utilities that allows you to do these kind of scripting using only bash so you don't have to rely on third-party scripts such as pyFoam. I would suggest to explore those options as well because in the future if you want to use a cluster, setting up all these third-party software in a way to work with OF is a lot of unnecessary and painful work!
Back to your question, do you have 64 physical core or are you using hyper-threading, virtual cores? You can check it by running lscpu and multiply Core(s) per socket by Socket(s). For example on my laptop it would be 2x1 = 2 while CPU(s) is equal to 4. OF only uses the physical cores and if you try use the virtual cores the performance may drop noticeably. Another question is do you have enough memory for all these cases to run simultaneously? It could be another bottleneck. If I remember correctly, a rule of thumb in OF is for about 1 mil cells you need 1 GB of memory. |
Thanks for your comments Taataa.
I personally believe PyFoam is a very useful tool for interacting with OpenFoam particularly in cases when you need to run many simulations of a same problem but with different conditions. I am just learning it though. Regarding OF only using physical cores, are you certain? I did a test while ago with and without hyperthreading on my laptop. I noticed that the simulations were slightly faster with 8 cores (hyperthreading) than only 4 physical cores. So I think OF does use virtual cores as well. But I might be wrong! I also think that the problem might be the physical-virtual cores combinations but believe it might be the Python handling of cores rather than OF, that's why I thought maybe I need to define the node list but have no idea how to do it here. Thanks again for your comments Ashkan |
Taher Chegini
Yes, I am sure. I asked Chris, one of the OF developers, and he confirmed. It depends on the case but it's better use the physical ones.
Regarding pyFoam, I am not disregarding its benefits but you can do all that it does with bash and OF utilities so why not exploit them? I usually use python scripts for data analysis only. Anyhow, cores and memory are usually the bottlenecks in these situations where you don't have to worry about IO communications. |
#5 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 ![]() ![]() |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
#6 | ||
#7 | |
Taher Chegini
#8 | |
Assistant Moderator
Bernhard Gschaider
#9 | |
Assistant Moderator
Bernhard Gschaider
#10 | |
I am trying to see if it is possible to assign multiple processors to each task in Python so the mpi call have sufficient processors. Any comments is highly appreciated. Many thanks again for the comments. |
#11 | |
Assistant Moderator
Bernhard Gschaider
Try running multiple runs (with pyFoamRunner) without your script and see if the same things happens
#12 | |
https://stackoverflow.com/questions/...parallel-cases Also, attached the corrected script. I have also ran two instances simultaneously each with 2 processors using the PyFoamRunner.py directly rather than my script. Now with the revised script, the processors workload is fine (4 cores have 100% CPU usage) but interestingly, the PyFoamRunner.py is just slightly faster than my python script approach. Attached also the log files of PyFoam and PythonScript for comparison. Any comments is highly appreciated. |
#13 | |
Assistant Moderator
Bernhard Gschaider
Just one remark: if you have more than one layer (in your case: mpi, PyFoam, the multiprocessing-library) above the OS then processor pinning is a bad idea: let the OS do the assignment (BTW: PyFoam doesn't mess with the pinning). It is quite good at it
parallel, pyfoam |
Ansa Script | ganesh0481 | ANSA | 47 | February 21, 2019 04:09 |
Ansa Script | Grigoriy_Ermolaev | ANSA | 3 | April 20, 2017 04:50 |
