[isoAdvector] Is it possible to add isoAdvector capabilities to interphaseChangeFoam?
Like Tree2Likes
  • 2 Post By srikrishnan_balasubramani
Old   July 12, 2017, 05:33
Default Is it possible to add isoAdvector capabilities to interphaseChangeFoam?
万超辉
chaohui is on a distinguished road
Originally Posted by roenby View Post
Dear foam’ers
Today we release the first version of our new geometric Volume-of-Fluid (VOF) algorithm for general meshes, isoAdvector:
https://github.com/isoAdvector/isoAdvector
The performance of and conceptueal ideas behind the method are described in the paper, “A computational method for sharp interface advection” just published in Royal Society Open Science:
http://dx.doi.org/10.1098/rsos.160405
We hope the large part of the CFD community working with interfacial flows will benefit from the improved accuracy and interface sharpness obtained with isoAdvector.
The isoAdvector code and concept are still under development. Therefore, if you test the code, we would appreciate if you could give us a few lines of feedback with description of your case setup and the effect isoAdvector has on your runs. The best way to give feedback is to write a post on cfd-online.com/Forums/openfoam/ under the relevant category and tag the post 'isoadvector'.
Kind regards,
Johan Roenby
can this method couple with interphasechangfoam or does interisofoam can add cavitation model ? if yes ,dose it may lead to better result about cavitation compared with interphasechangfoam?
[Moderator note: Moved from thread IsoAdvector release ]
chaohui is offline   Reply With Quote
Old   July 13, 2017, 05:32
Johan Roenby
roenby will become famous soon enough
I don't know enough about how interphasechangfoam works to answer these questions. Can someone else answer these questions?
roenby is offline   Reply With Quote
Old   July 13, 2017, 06:35
Andrea Ferrari
Andrea_85 is on a distinguished road
Cavitation requires source terms in alphaEqn and as far as i understood isoAdvector does not support that for the moment. So i think the answer is no.
Andrea_85 is offline   Reply With Quote
Old   July 13, 2017, 09:55
Rodrigo
guin is on a distinguished road
You basically need to introduce source terms in the calculation of the alpha transport equation. The trick is to get them into isoAdvection::advect(), where the equation is been solved. I played a little bit adding comments before and after the actual implemented code in order to show where would this come from and which could be the final alternative.
void Foam::isoAdvection::advect()
    isoDebug(Info << "Enter advect" << endl;)
    //Interpolating alpha1 cell centre values to mesh points (vertices)
    ap_ = vpi_.interpolate(alpha1_.oldTime());
    //Initialising dVf with upwind values, i.e. phi[fLabel]*alpha1[upwindCell]*dt
    dVf_ = upwind<scalar>(mesh_, phi_).flux(alpha1_.oldTime())*
        mesh_.time().deltaT();
    //Do the isoAdvection on surface cells
    timeIntegratedFlux();
    //Syncronize processor patches
    syncProcPatches(dVf_, phi_);
    //Adjust dVf for unbounded cells
    limitFluxes();
    // Advect the free surface (here we go...)
  //ddt(alpha1_) + div(alphaPhi) = Su + Sp*alpha1_; // (MAIN IDEA)
  //ddt(alpha1_) + fvc::surfaceIntegrate(alphaPhi) = Su + Sp*alpha1_;
  //ddt(alpha1_) + fvc::surfaceIntegrate(upwind<scalar>(mesh_, phi_).flux(alpha1_.oldTime())) = Su + Sp*alpha1_;
  //ddt(alpha1_) + fvc::surfaceIntegrate([upwind<scalar>(mesh_, phi_).flux(alpha1_.oldTime())*mesh_.time().deltaT()]/mesh_.time().deltaT()) = Su + Sp*alpha1_;
  //ddt(alpha1_) + fvc::surfaceIntegrate([dVf]/mesh_.time().deltaT()) = Su + Sp*alpha1_;
  //ddt(alpha1_) + fvc::surfaceIntegrate(dVf)/mesh_.time().deltaT() = Su + Sp*alpha1_;
  //(alpha1_ - alpha1_.oldTime())/mesh_.time().deltaT() + fvc::surfaceIntegrate(dVf)/mesh_.time().deltaT() = Su + Sp*alpha1_;
  //alpha1_ - alpha1_.oldTime() + fvc::surfaceIntegrate(dVf) = mesh_.time().deltaT()*(Su+Sp*alpha1_);
    alpha1_ = alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_); // (CURRENT STATE) ...+ mesh_.time().deltaT()*(Su+Sp*alpha1_)
  //alpha1_ = alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_) + mesh_.time().deltaT()*(Su+Sp*alpha1_);
  //alpha1_ = alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_) + mesh_.time().deltaT()*Su + mesh_.time().deltaT()*Sp*alpha1_;
  //alpha1_ - mesh_.time().deltaT()*Sp*alpha1_ = alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_) + mesh_.time().deltaT()*Su;
  //alpha1_ * (1.0 - mesh_.time().deltaT()*Sp) = alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_) + mesh_.time().deltaT()*Su;
  //alpha1_ = ( alpha1_.oldTime() - fvc::surfaceIntegrate(dVf_) + mesh_.time().deltaT()*Su ) / (1.0 - mesh_.time().deltaT()*Sp); // (SUGGESTION)
    alpha1_.correctBoundaryConditions();
Sp and Su might be taken from interPhaseChangeFoam, etc., as well as the relevant ones in pEqn.H.
As for the advantage/drawbacks... all the ones related with sharper interfaces, I guess. But anyone should try this out first and report about the experience.
guin is offline   Reply With Quote
Old   October 22, 2017, 14:19
Default adding isoadvector to intercondensatingevaporatingfoam
sandy
saddy is on a distinguished road
Hello guys
i know it's a little bit old thread, but nevertheless,
i want to ask is it possible to add isoadvector to intercondensatingevaporatingFoam just like one can modify interfoam to isoflow.
i am using intercondensatingevaporatingfoam from -v1612+ and v1706+ both
can you guys comment....plz help
    limitFluxes();
saddy is offline   Reply With Quote
Old   August 28, 2018, 11:39
Srikrishnan Balasubramanian
srikrishnan_balasubramani is on a distinguished road
Hi Dr. Roenby,
First of all, thanks for your incredible work.
I tried to change the interIsoFoam for phasechange flows.
Based on Rodrigo's comment, I added the source terms for the alpha equations. (thanks rodrigo)
The solution runs fine until certain time and then I get a lot foam warnings and finally the simulation stops.
Here is the warning message :
PIMPLE: iteration 1
--> FOAM Warning :
From function void Foam::isoCutFace::cutPoints(const pointField&, const scalarField&, Foam::scalar, Foam:ynamicList<Foam::Vector<double> >&)
in file fvMatrices/solvers/isoAdvection/isoCutFace/isoCutFace.C at line 669
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.77292e-15 -9.8908e-15 -1.3714e-15) and f0 = 0
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.76423e-15 -9.89949e-15 -1.38009e-15) and f0 = 8.68645e-18
--> FOAM Warning :
From function void Foam::isoCutFace::quadAreaCoeffs(const Foam:ynamicList<Foam::Vector<double> >&, const Foam:ynamicList<Foam::Vector<double> >&, Foam::scalar&, Foam::scalar&) const
in file fvMatrices/solvers/isoAdvection/isoCutFace/isoCutFace.C at line 707
Vertex face was cut at pf0 = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05))
--> FOAM Warning :
in file fvMatrices/solvers/isoAdvection/isoCutFace/isoCutFace.C at line 716
Vertex face was cut at pf1 = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05))
Number of isoAdvector surface cells = 43264
isoAdvection: Before conservative bounding: min(alpha) = -1.94668e-05, max(alpha) = 1 + -0.000175214
isoAdvection: After conservative bounding: min(alpha) = -3.61432e-12, max(alpha) = 1 + -0.000175231
isoAdvection: time consumption = 47%
Phase-1 volume fraction = 0.119029 Min(alpha.water) = 0 Max(alpha.water) = 0.999825
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.77198e-15 -9.88832e-15 -1.3703e-15) and f0 = 0
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.76329e-15 -9.89701e-15 -1.37899e-15) and f0 = 8.68645e-18
--> FOAM Warning :
--> FOAM Warning :
isoAdvection: Before conservative bounding: min(alpha) = -2.71233e-05, max(alpha) = 1 + -0.000175231
isoAdvection: After conservative bounding: min(alpha) = -1.45423e-12, max(alpha) = 1 + -0.000175247
Phase-1 volume fraction = 0.119027 Min(alpha.water) = 0 Max(alpha.water) = 0.999825
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.77281e-15 -9.88353e-15 -1.37721e-15) and f0 = 0
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.76413e-15 -9.89222e-15 -1.38589e-15) and f0 = 8.68645e-18
--> FOAM Warning :
--> FOAM Warning :
isoAdvection: Before conservative bounding: min(alpha) = -1.58733e-05, max(alpha) = 1 + -0.000175247
isoAdvection: After conservative bounding: min(alpha) = -3.4395e-12, max(alpha) = 1 + -0.000175264
Phase-1 volume fraction = 0.119025 Min(alpha.water) = 0 Max(alpha.water) = 0.999825
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.77266e-15 -9.88052e-15 -1.37948e-15) and f0 = 0
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.76397e-15 -9.8892e-15 -1.38817e-15) and f0 = 8.68645e-18
--> FOAM Warning :
--> FOAM Warning :
Number of isoAdvector surface cells = 43266
isoAdvection: Before conservative bounding: min(alpha) = -2.03621e-05, max(alpha) = 1 + -0.000175264
isoAdvection: After conservative bounding: min(alpha) = -1.4312e-12, max(alpha) = 1 + -0.00017528
Phase-1 volume fraction = 0.119023 Min(alpha.water) = 0 Max(alpha.water) = 0.999825
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.77065e-15 -9.88057e-15 -1.37311e-15) and f0 = 0
--> FOAM Warning :
cutPoints = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)) for pts = 3((-0.000205501 0.00754821 -5.28758e-05) (-0.000233354 0.00755288 -7.26279e-05) (-0.000219663 0.00753114 -5.45055e-05)), f - f0 = 3(1.76196e-15 -9.88926e-15 -1.3818e-15) and f0 = 8.68645e-18
--> FOAM Warning :
--> FOAM Warning :
Number of isoAdvector surface cells = 43265
isoAdvection: Before conservative bounding: min(alpha) = -0.00026042, max(alpha) = 1 + -0.00017528
isoAdvection: After conservative bounding: min(alpha) = -3.41937e-12, max(alpha) = 1 + -0.000175297
Phase-1 volume fraction = 0.11902 Min(alpha.water) = 0 Max(alpha.water) = 0.999825
GAMG: Solving for p_rgh, Initial residual = 0.0358953, Final residual = 0.000537933, No Iterations 2
time step continuity errors : sum local = 6.95233e-08, global = -7.09544e-09, cumulative = -0.000199076
GAMG: Solving for p_rgh, Initial residual = 0.0209545, Final residual = 0.000479413, No Iterations 2
time step continuity errors : sum local = 6.45061e-08, global = -7.96381e-10, cumulative = -0.000199077
GAMG: Solving for p_rgh, Initial residual = 0.01146, Final residual = 8.86714e-08, No Iterations 20
time step continuity errors : sum local = 1.20871e-11, global = -2.28937e-13, cumulative = -0.000199077
smoothSolver: Solving for omega, Initial residual = 0.00597309, Final residual = 7.71023e-09, No Iterations 5
smoothSolver: Solving for k, Initial residual = 0.0152823, Final residual = 3.69396e-09, No Iterations 6
ExecutionTime = 31976.8 s ClockTime = 32003 s
If you have any idea about it, try to help me.
For your info, below is the details at some particular time where I don't get warnings.
PIMPLE: iteration 1
Number of isoAdvector surface cells = 10983
isoAdvection: Before conservative bounding: min(alpha) = -0.00250367, max(alpha) = 1 + 3.7198e-05
isoAdvection: After conservative bounding: min(alpha) = -9.19778e-07, max(alpha) = 1 + 1.30901e-07
isoAdvection: time consumption = 11%
Phase-1 volume fraction = 0.991469 Min(alpha.water) = 0 Max(alpha.water) = 1
Number of isoAdvector surface cells = 11627
isoAdvection: Before conservative bounding: min(alpha) = -0.00225283, max(alpha) = 1 + 3.71182e-05
isoAdvection: After conservative bounding: min(alpha) = -1.53212e-06, max(alpha) = 1 + 2.09213e-07
Phase-1 volume fraction = 0.991457 Min(alpha.water) = 0 Max(alpha.water) = 1
Number of isoAdvector surface cells = 11656
isoAdvection: Before conservative bounding: min(alpha) = -0.00108297, max(alpha) = 1 + 0.000133022
isoAdvection: After conservative bounding: min(alpha) = -1.55246e-06, max(alpha) = 1 + 1.5678e-07
Phase-1 volume fraction = 0.991445 Min(alpha.water) = 0 Max(alpha.water) = 1
Number of isoAdvector surface cells = 11660
isoAdvection: Before conservative bounding: min(alpha) = -0.00110323, max(alpha) = 1 + 3.72188e-05
isoAdvection: After conservative bounding: min(alpha) = -9.14948e-06, max(alpha) = 1 + 2.18349e-07
Phase-1 volume fraction = 0.991432 Min(alpha.water) = 0 Max(alpha.water) = 1
Number of isoAdvector surface cells = 11655
isoAdvection: Before conservative bounding: min(alpha) = -0.00219646, max(alpha) = 1 + 3.73554e-05
isoAdvection: After conservative bounding: min(alpha) = -5.02188e-05, max(alpha) = 1 + 1.28155e-07
Phase-1 volume fraction = 0.99142 Min(alpha.water) = 0 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.521383, Final residual = 0.0155201, No Iterations 1
time step continuity errors : sum local = 2.29426e-05, global = -3.93426e-09, cumulative = -1.76012e-05
GAMG: Solving for p_rgh, Initial residual = 0.25023, Final residual = 0.00734931, No Iterations 1
time step continuity errors : sum local = 8.20731e-06, global = -1.7044e-09, cumulative = -1.76029e-05
GAMG: Solving for p_rgh, Initial residual = 0.148065, Final residual = 9.90889e-08, No Iterations 277
time step continuity errors : sum local = 1.01872e-10, global = -3.75169e-13, cumulative = -1.76029e-05
smoothSolver: Solving for omega, Initial residual = 0.00370818, Final residual = 1.8865e-09, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.0173377, Final residual = 5.85093e-09, No Iterations 5
ExecutionTime = 406.54 s ClockTime = 407 s
Thanks in advance.
regards,
krishna
srikrishnan_balasubramani is offline   Reply With Quote
Old   May 17, 2019, 15:04
Yağmur GÜLEÇ
yagmur_89 is on a distinguished road
Dear Srikrishnan Balasubramanian,
I would like to try isoAdvection with a source term as well. But I was wondering if you solved why the warnings showed up in the log file.
Thanks,
Best Regards,
yagmur_89 is offline   Reply With Quote
Old   May 17, 2019, 17:12
I am not sure about the reason for warnings. Initially, I used tetra and hexa mesh combined, from Ansys. May be this was the reason for warnings. Later, I used snappy hex mesh. Since then I din get warnings. May be mesh was the reason.
Aabadani and aliyah. like this.
Old   August 17, 2020, 04:16
Default changes
Al
aliyah. is on a distinguished road
    limitFluxes();
Hi, thanks for this suggestion and guidance. How did you define the Su and Sp in isoAdvection.H. I used scalarField& Su; or Foam::fvm::Su; But there were errors in it.
the second question is that I want to add fvm::Sp(divU, alpha1) , fvm::Sp(vDotvAlphal, alpha1) and vDotcAlphal to the definition of alpha instead of Su and Sp. How can I define these in isoAdvection.H and use it in the isoAdvection.c?
aliyah. is offline   Reply With Quote
Old   June 21, 2024, 13:21
Default An issue regarding having access to RDF function of isoAdvection scheme
SiaVash
SiavashB is on a distinguished road
Dear Foamers,
I have an issue regarding running a case in which I am using a modified interIsoFoam solver with openFoam-v2312. The modified interIsoFoam is compiled and in a part of code I need to have access to the reconstructedDistanceFunction (RDF) from the mesh, and I am using a code as below:
RDFFunction = mesh.lookupObject<volScalarField>("reconstructedDistanceFunction")
I also called all of the needed libraries in interIsoFoam.C as below:
#include "fvCFD.H"
#include "dynamicFvMesh.H"
#include "isoAdvection.H"
#include "EulerDdtScheme.H"
#include "localEulerDdtScheme.H"
#include "CrankNicolsonDdtScheme.H"
#include "subCycle.H"
#include "incompressibleTwoPhaseMixture.H"
#include "immiscibleIncompressibleTwoPhaseMixture.H"
#include "incompressibleInterPhaseTransportModel.H"
#include "pimpleControl.H"
#include "fvOptions.H"
#include "CorrectPhi.H"
#include "fvcSmooth.H"
#include "dynamicRefineFvMesh.H"
#include "volPointInterpolation.H"
It seems by calling isoAdvection.H, I have to get access to reconstructedDistanceFunction but I get an error that I don't know how to solve it.
After compiling the code without any error, as soon as I start the run of the code I face this error:
FOAM FATAL ERROR: (openfoam-2312 patch=240220)
    failed lookup of reconstructedDistanceFunction (objectRegistry region0)
    available objects of type volScalarField:
23
FeFilter
sgm_0
interfaceProperties:K
K
PhiFilte
alpha.water
rho
Ue
sgm
p_rgh
eps
interfaceNeighbourMaker
nu
nu1
rhoESubGrid
rho_0
nu2
rhoE
alpha.air
eps_0
H
D
interfaceCellMaker
    From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
    in file /usr/lib/openfoam/openfoam2312/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 628.
I am using this command which is very similar to a code with openfoam-v1812. The point is that, they also compiled the TwoPhaseFlow library developed by DLR and by Dr. Johan Roenby and Dr. Henning Scheufler.
I would appreciate it if anyone can help me to fix this problem.
Regards,
Siavash
SiavashB is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Add Singhal model into interPhaseChangeFoam zhouhoucun OpenFOAM Running, Solving & CFD 0 April 28, 2015 05:32
interphasechangeFoam: How to add U to Residual plotting with gnuplot? shipman OpenFOAM Post-Processing 4 June 15, 2014 23:30
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
