[swak4Foam] groovyBC lookup tables for Reynolds stress R tensor field
Like Tree3Likes
  • 1 Post By rdbisme
  • 2 Post By Gerhard
Old   March 23, 2017, 06:21
Default groovyBC lookup tables for Reynolds stress R tensor field
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
I searched a bit on the forum and it seems that I'm one of the fewest lucky people that can afford to setup all the six Reynolds stress at the inlet from experimental data .
I'm doing a benchmark simulation to test the behavior of the several turbulence models in that specific case (divergent diffuser) and I would like to see how the RSM models behave.
It's the first time I use RSM models, sorry if I would result a bit unexperienced.
By the way I have experimental points for all the six (uu, uv, uw, vv, vw, ww) Reynolds stress components. In the case of scalar (or vectorial) fields what I do is:
Scalar
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1;
boundaryField
    inlet
        type            groovyBC;
        value           $internalField;
        lookuptables (
                name expInlet;
                outOfBounds clamp;
                fileName    "$FOAM_CASE/inlet/omega.dat";
        valueExpression "expInlet(pos().y)";
    outlet
        type            zeroGradient;
    walls
    {   type            omegaWallFunction;
        value           uniform 1e-6;
    front
        type            wedge;
    back
        type            wedge;
    axis
        type            empty;
Vector
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 2);
boundaryField
    inlet
        type            groovyBC;
        lookuptables (
                name expInlet;
                outOfBounds clamp;
                fileName    "$FOAM_CASE/inlet/u_14_ort.dat";
        valueExpression "-expInlet(pos().y)*normal()";
    outlet
        type            zeroGradient;
    walls
    {   type            noSlip;
    front
        type            wedge;
    back
        type            wedge;
    axis
        type            empty;
Can I achieve the same for the R tensor field?
Gerhard likes this.
rdbisme is offline   Reply With Quote
Old   November 10, 2018, 07:53
Gerhard
Gerhard is on a distinguished road
I am also interested to test RSM models on the ERCOFTAC conical diffuser for which experimental data is available.
Please let me know whether you managed to figure this out.
Thanks
Gerhard is offline   Reply With Quote
Old   November 10, 2018, 11:59
Gerhard
Hi
I think I might have figured it out.
Let me know what you think.
Tensor
|  \\    /   O peration     | Version:  5                                     |
FoamFile
    version     2.0;
    format      ascii;
    class       volSymmTensorField;
    object      R;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform (0 0 0 0 0 0);
boundaryField
	inlet
	        type			groovyBC;
		value			uniform (0 0 0 0 0 0);
		lookuptables (
				name		Ruu;
				file		"$FOAM_CASE/0/Ruu.data";
				outOfBounds	clamp;
                name		Rww;
                file		"$FOAM_CASE/0/Rww.data";
                outOfBounds	clamp;
                name		Rvv;
                file		"$FOAM_CASE/0/Rvv.data";
                outOfBounds	clamp;
                name		Ruw;
                file		"$FOAM_CASE/0/Ruw.data";
                outOfBounds	clamp;
                name		Ruv;
                file		"$FOAM_CASE/0/Ruv.data";
                outOfBounds	clamp;
                name		Rvw;
                file		"$FOAM_CASE/0/Rvw.data";
                outOfBounds	clamp;
		variables (
			"origin=vector(0,0,0.025);"  // Patch centre (vector)
			"rp=pos()-origin;"           // Radii from centre (vector)
			"r=mag(rp);"				 // Radii from centre (scalar)
			"vv=symmTensor(1,0,0,0,0,0);"
            "vw=symmTensor(0,1,0,0,0,0);"
            "uv=symmTensor(0,0,1,0,0,0);"
            "ww=symmTensor(0,0,0,1,0,0);"
            "uw=symmTensor(0,0,0,0,1,0);"
            "uu=symmTensor(0,0,0,0,0,1);"
            "xDir=vector(1,0,0);"
            "yDir=vector(0,1,0);"
            "zDir=vector(0,0,1);"
        valueExpression "Rvv(r)*vv + Rww(r)*ww + Ruu(r)*uu + Rvw(r)*vw + Ruw(r)*uw + Ruv(r)*uv";
	casing
        type            kqRWallFunction;
    diffuser
    dump
        type            zeroGradient;
    outlet
        type            zeroGradient;
	axis
		type			symmetryPlane;
	front
		type			wedge;
	back
		type			wedge;
rdbisme and godfatherBond like this.
Old   July 19, 2021, 03:37
Default Applying temperature only at certain provided locations of x.
L S
silviliril is on a distinguished road
I have been trying to simulate nucleate boiling in OpenFOAM. With present model in phaseChangeHeatFoam the wall constant wall temperature can be applied throughout the wall having fixed value. Which generates a thin vapor layer first and then it breaks into several nucleation sites due to density difference. (See bottom nucleation image file attached below)
Now, What I want to do is, apply random value of wall temperature only at certain provided locations (also randomly chosen locations) in lookup table (see posx image file attached below).
I want the nucleation to start only at certain locations and not from entire wall.
One such possibility is to use lookup table feature in groovyBC and another is codedFixedValue BC. But, I could not really figure out that how to use it for my specific purpose.
silviliril is offline   Reply With Quote
groovybc, lrr, reynolds stress model, ssg, swak4foam
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" Jeremie84 ANSYS Meshing & Geometry 70 October 25, 2017 17:03
Lookup tables ali.m.1 OpenFOAM Running, Solving & CFD 2 May 13, 2016 08:11
[swak4Foam] groovyBC 2D lookup ecbmxer OpenFOAM Community Contributions 1 September 24, 2015 11:21
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 12:59
