[Tutorials] OpenFOAM Screencast - Showing how to build an OpenFOAM case from scratch |
Tobias Holzmann
Rep Power: 51 ![]() ![]() ![]() |
Dear FOAM'er,
I am creating a series of screencasts where I demonstrate how to build your own case for an arbitrary geometry. The screencasts are split into different topics in order to allow everybody to check out the part he/she is interested in. In general I am talking about the following stuff:
You can find everything here » Move me to the screencast « Everything is based on geometry that is shown below and we are using OpenFOAM, Salome and Blender during the screencasts. Share it, comment it, like it, criticize it, enjoy it,... Screencast.jpg
Keep foaming, Tobias Holzmann Last edited by Tobi; December 14, 2017 at 07:49. |
Jose Rey
Rep Power: 17 ![]() |
Thank you very much for this contribution. I enjoyed the screencast.
power
Rep Power: 12 ![]() |
Dear Tobi,
very helpful video tutorials, what you linked. Thanks so much. What a pity not got before! |
#4 | |
Tobias Holzmann
Of course, thanks to you Valentine too, for giving me some feedback.
Keep foaming, Tobias Holzmann |
Rep Power: 10 ![]() |
Dear Tobias,
Thank you very much first of all for your teaching on your website http://www.holzmann-cfd.de! I watched through your teaching videos and learned a lot, especially about creating mesh with Salome and snappyHexMesh. Your website is very helpful for beginners like me! I met a problem with salome. I want to simulate blood flow in a blood vessel, which is basically like a pipe, but has irregularly curved surfaces and flow path. The geometry is saved in .step or a .stl file. I could import the .step file into salome. After I right clicked and chose create group, the dialog box became frozen. I could move the dialog box, but couldn't choose faces. The memory is sufficient, still plenty are free. I tried a much simpler geometry, a pipe, there was no problem to create groups. Since I began to use salome yesterday, I am not sure whether is it an installation problem or do I meet the limit of salome so quickly in a day? It would be a great favor of me if you would like to give me some hints! Thank you very much in advance! All the best, Sitajeje |
Tobias Holzmann
Dear Sitajeje,
thank you very much for your feedback. Salome can be very slow if your STEP is very complex and has a lot of shells/faces/etc. I suggest, wait ![]() Sent from my HTC One mini using CFD Online Forum mobile app
Dear Tobias,
professionals are professional! Your hint provides exactly the solution: take it easy and have a coffee break! Thank you very much! Have a nice evening! sitajeje |
power
Hi Tobias,
I'm trying to mesh a very complex geometry to apply snappyHexMesh. I deeply studied your tutorial videos and what I cannot apply is to set the same wire segmentation on both two connected faces. The problem I encountered is that sometimes an edge on one face is different on the other face. In this case, setting an equal 'nb of segments' submesh on both two faces, obviously it misses to connect all points of the border mesh. I tried to fuse edges, but I've not understood how to manage Fuses, because in that case they are not children of the same face. So, how to solve that? Thanks |
#9 |
Hi Tobias,
I'm trying to mesh a multiRegion domain with SHM. I've got 3 domains. If you have a look at the picture, you may see that internally there is a cylindrical surface I would like to snap better. That surface is internal and I want only to mesh better the interface between regions. I tried different ways, even increasing levels on refienements surfaces, but I got a "stepped" surface; I'd like to have it smoothed. this is an extract of my SHM dict Code:
refinementSurfaces { fluid { level (1 1); regions { airAmbOutlet { level (1 1); patchInfo { type patch; }} airAmbInlet { level (1 1); patchInfo { type patch; }} airCombInlet { level (1 1); patchInfo { type patch; }} airCombOutlet { level (1 1); patchInfo { type patch; }} simmetry { level (1 1); patchInfo { type patch; }} wallAirAmb { level (1 1); patchInfo { type wall; }} wallAirComb { level (1 1); patchInfo { type wall; }} wallSolido { level (1 1); patchInfo { type wall; }} } } tuboScamb1 { level (3 3); faceType internal; } tuboScamb2 { level (3 3); faceType internal; } tuboPlt { level (3 3); faceType internal; } regionAirAmb { level (2 2); faceZone regionAirAmb; cellZone regionAirAmb; cellZoneInside inside; boundary internal; } regionAirComb { level (2 2); faceZone faceAirCombZone; cellZone cellAirCombZone; cellZoneInside inside; boundary internal; } Code:
splitMeshRegions -cellZones -ovrwrite Enclosed there's the step file of the domain. Thanks for any help. Regards Michele. |
openfoam, screencasts |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
