[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam
Like Tree1Likes
  • 1 Post By dani2702
Old   November 17, 2016, 04:30
Default Change in alpha and U with groovyBC in twoPhaseEulerFoam
dani2702 is on a distinguished road
I'm trying to simulate a fludized bed with two inlets for particles (inletParticlesLeft and inletParticlesRight), one inlet for air (inletAir) and one outlet (outletAir). See the attached image #1 for the geometry.
Gas is flowing from inletAir and particles (alpha_Particles = 0.62) are flowing from inletParticlesRight into the geometry.
I'm trying to code the following condition:
If particles are carried out of the geometry (outletAir), then the same amount of particles should be recirculated into the geometry via inletParticlesLeft. So kind of a coupling between outletAir and inletParticlesLeft.
For testing purposes I tried to use groovyBC to implement the scenario:
- If there are no particles at outletAir the gas flow and the volume fraction of particles at inletParticlesLeft shall be 0 and therefore no flow
- If there are particles above a certain value (alpha.particles > 1E-3) at outletAir, the volume fraction of particles at inletParticlesLeft should jump to 0.62 and the velocity should increase to a fixed amount.
Here is my code of the boundary conditions:
alpha.air:
    inletAir
        type            fixedValue;
        value           uniform 1;
    outletAir
		type 		zeroGradient;
    inletParticles
        type            fixedValue;
        value           uniform 0.38;
    inletParticles2
	type groovyBC;
	aliases		{
			alphaP	alpha.particles;
	variables "alphaPMean{outletAir}=sum(alphaP*mag(Sf()))/sum(mag(Sf()));";
	valueExpression "(alphaPMean > 1e-3) ? 0.38 : 1";
	value	      	uniform 1;
alpha.particles:
    inletAir
        type            fixedValue;
        value           uniform 0;
    outletAir
		type 		zeroGradient;
    inletParticles
        type            fixedValue;
        value           uniform 0.62;
    inletParticles2
	type groovyBC;
	aliases		{
	valueExpression "(alphaPMean > 1e-3) ? 0.62 : 0";
	value	      	uniform 0;
U.air
    inletAir
        type               fixedValue;
        value	      	uniform (0 0 5);
    outletAir
		type 			inletOutlet;
		inletValue		uniform (0 0 0);
		value 			uniform (0 0 0);
    inletParticles
        type                fixedValue;
        value 				uniform (-0.3 0 -0.3);
    inletParticles2
	type groovyBC;
	aliases		{
	valueExpression "(alphaPMean > 1e-3) ? vector(0.3,0,-0.3) : vector(0,0,0)";
U.particles
    inletAir
        type               fixedValue;
    outletAir
		type 			inletOutlet;
    inletParticles
        type                fixedValue;
    inletParticles2
	type groovyBC;
	aliases		{
p
    inletAir
		type		zeroGradient;
    outletAir
		type		fixedValue;
		value		uniform 2.25e5;
    inletParticles
		type		zeroGradient;
    inletParticles2
		type		zeroGradient;
p_rgh
    inletAir
		type		fixedFluxPressure;
		value		$internalField;
    outletAir
        type               prghPressure;
	   p				$internalField;
    inletParticles
    inletParticles2
Now the problem I'm getting, as soon as alpha.Particles art outletAir hits the defined critical value in order to switch alpha.particles and U for the boundary inletParticlesLeft, the time step delta T decreases heavily (see attached image #2).
When looking at the last time step for the boundary inletParticlesLeft (when alpha.particle and U already changed for inletParticlesLeft), the alpha value and velocity was correct, but the pressure p and p_rgh were 'abnormal', see attached images #3 and #4.
Therefore the velocity and pressures right after the boundary condition inletParticlesLeft rise in the domain (example for U.air):
That's why the time step decreases (as the velocity rises in such a magnitude)
I don't know why the pressure differs when the swtiching conditions at the groovyBC applies.
I also tried a simulation without groovyBC and coded the fixedValues for U and alpha for inletParticlesLeft. I manually interrupted the simulation and changed for inletParticlesLeft the alpha and U values at the last time step and continued the simulation with no problem.
Do you guys have any solution for my problem?
Thank you!
the_ichthyologist likes this.
dani2702 is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
TwoPhaseEulerFoam alpha "ripples" MichaelB88 OpenFOAM Running, Solving & CFD 1 July 9, 2015 05:20
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 03:08
[swak4Foam] groovyBC and access to alpha field of other patch Tobi OpenFOAM Community Contributions 4 September 2, 2014 05:04
about bounded alpha equation for bubbleFoam and twoPhaseEulerFoam kaifu OpenFOAM 2 May 6, 2011 06:33
