[swak4Foam] swak4Foam for foam-extend 1.6 problem
Like Tree2Likes
  • 2 Post By gschaider
Old   October 28, 2016, 15:54
Default swak4Foam for foam-extend 1.6 problem
Saideep
Saideep is on a distinguished road
Hi everyone,
This thread originates from the following post.
http://www.cfd-online.com/Forums/ope...her-field.html
I would like to use groovyBc for some of my face boundaries.
Following the webpage for installation,
I proceeded and got stuck at this specific error.
In file included from entryToExpression/entryToExpression.H:50:0,
from entryToExpression/directEntryToExpression.H:49,
from entryToExpression/directEntryToExpression.C:37:
lnInclude/foamVersion4swak.H:8:37: error: floating constant in preprocessor expression
#define FOAM_VERSION4SWAK_PATCH_NUM 1.6-ext
And the same macro definition seems to fail creation of libraries.
Can anyone guide me here? I would like to use 1.6-ext instead of 3.1-ext as the modified code is seen to perform better though I need to dig deep and make my hands dirty.
Thanks;
Saideep
Saideep is offline   Reply With Quote
Old   October 30, 2016, 09:54
Retired Super Moderator
Bruno Santos
Quick question: I need more details. Which specific installation instructions did you follow and which swak4Foam version did you download?
Old   October 30, 2016, 13:36
Assistant Moderator
Bernhard Gschaider
Originally Posted by Saideep View Post
Hi everyone,
Thanks;
Saideep
According to what I wrote in the README with version 0.3.0 swak lost support for some installations of 1.6-ext (basically those not installed off the nextRelease-branch). If you need only "plain" groovyBC and no newer features I'd suggest you go back to old versions of swak that are still known to support 1.6-ext (I think that would be 0.2.3 or 0.2.4). Basically first clone the regular mercurial repository of swak and then move to the proper tag with
hg update version_0.2.3
or
hg update version_0.2.4
The current default or development-branch of the repository probably won't work with 1.6-ext anymore (at least I haven't tested it)
wyldckat and Saideep like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 2, 2016, 11:05
Saideep
Thanks Bruno and GSchaider,
I tried to install swak-0.2.x as swak-0.3.x gives me an error saying "this version of swak is for OpenFOAM-2.x and higher".
So, I downloaded from the following webpage:
https://openfoamwiki.net/index.php/I...enFOAM_1.6-ext
My bison version was 3.x (this was the main problem) and as Gschaider mentioned that few api's of bison 3.x were not compatible with swak versions. I had to use the "maintainanceScripts" of newer swak version and paste it into my older version of swak.
Tweaking a bit of my Allwmake file (to let it know I have a local bison version of 2.x) as follows worked fine.
### added by me###
swakDir=$(pwd)
requirementsBin=$swakDir/privateRequirements/bin
if [ -e $requirementsBin ];
then
    echo
    echo "$requirementsBin existing. Prepending to PATH-variable (private version of Bison)"
    echo
    export PATH=$requirementsBin:$PATH
fi
Would be good if you added this script into the older swak version as well.
Thanks guys.
foam extend 1.6, swak4foam error
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 17:53
[foam-extend.org] error installing foam extend 1.6 in ubuntu 12.04 christos OpenFOAM Installation 1 May 9, 2016 18:20
problem with RBF in tho Foam 3.0 extend Vesek OpenFOAM Programming & Development 4 June 16, 2014 05:22
[swak4Foam] Basic Error when installing swak4foam with foam extend 3.0 mnobrega OpenFOAM Community Contributions 6 April 1, 2014 02:47
Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend - A.Wendy OpenFOAM 0 February 27, 2013 05:50
