[OLAFLOW] wmake error when installing on RHEL 6.5 |
October 27, 2016, 12:15 |
Lewis
Rep Power: 10 |
Hi All,
I am a new OpenFOAM user and currently study to learn build wave model by using waves2Foam and OLAFoam. And I have installed the OpenFOAM/2.4.0 in the cluster linux system, which is Red Hat Enterprise Linux Server release 6.5 (RHEL). However, when I try to install OLAFoam as a example, the terminal reports wmake error as bellow. Code:
<command-line>:0:1: error: macro names must be identifiers linux64Gcc49DPOpt/options:6: *** missing separator. Stop. wmake error: file 'Make/linux64Gcc49DPOpt/objectFiles' could not be created olaFoam compilation failed For this issue, I think this error might cause by rule formatting in the file from linux64Gcc49 folder. So, I enclose the file: /OpenFOAM-2.4.0/wmake/rules/linux64Gcc49/general below. Code:
CPP = cpp -traditional-cpp PROJECT_LIBS = -l$(WM_PROJECT) -ldl include $(GENERAL_RULES)/standard include $(RULES)/c include $(RULES)/c++ I really look forward to having some helps from you. Cheers! zuodong |
October 30, 2016, 10:46 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: We need the following information:
October 30, 2016, 21:23 |
Pablo Higuera
Rep Power: 19 |
Hi Zuodong,
from what you say, not being even able to compile interFoam indicates that there is something wrong in the OpenFOAM global installation. Maybe you can provide the log file for the complete installation (the output from the allMake file). Once OpenFOAM is correctly installed, I assure you that olaFoam will compile without any errors. Best, Pablo |
November 4, 2016, 02:19 |
Lewis
Rep Power: 10 |
Hi! @Bruno Santos, thanks for quick reply and your sugguestions. According to your advice and following your steps to test our RHEL 6.5 linux system, the outcomes are shown below:
(1) Code:
which cpp Code:
/sw/gcc/4.9.0/bin/cpp Code:
cpp --version Code:
cpp (GCC) 4.9.0 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Code:
wclean solvers/olaFoamOF240 wmake all solvers/olaFoamOF240 > log.make 2>&1 gzip < log.make > log.make.gz (4) Code:
gzip < solvers/olaFoamOF240/Make/linux*/options > options.gz Thanks for considering my problems and I am looking forward to your reply. Best regards, zuodong |
November 4, 2016, 02:39 |
Lewis
Rep Power: 10 |
Hi @Pablo! Firstly thanks for your work that making a good OLAFoam for generating wave. Now, I have installed the OLAFoam in a laptop with Fedora 24 Linux system, in which the OF30X installed. However, the simulation of large modelling case have to run in the Cluster System. I run the command
./allMake > log.allMake 2>&1 Code:
<command-line>:0:1: error: macro names must be identifiers linux64Gcc49DPOpt/options:8: *** missing separator. Stop. wmake error: file 'Make/linux64Gcc49DPOpt/objectFiles' could not be created in /export/home/studentID/OLAFOAM/genAbs/waveGeneration \n\nWave generation boundary conditions compilation failed Thanks for your time and help! Cheers! zuodong |
November 6, 2016, 17:18 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Zuodong: From what I can figure out, something very wrong is going on with cpp. Please run the following commands: Code:
cpp -traditional-cpp -D$WM_ARCH -DWM_$WM_PRECISION_OPTION solvers/olaFoamOF240/Make/options > options.test 2>&1 gzip < options.test > options.test.gz Another thing that comes to mind is regarding the installation itself... please run the following command and let us know what it gives you: Code:
which blockMesh Bruno |
November 9, 2016, 21:38 |
Lewis
Rep Power: 10 |
Hi! @Bruno Santos good to see you !
First, I run the below command: Code:
cpp -traditional-cpp -D$WM_ARCH -DWM_$WM_PRECISION_OPTION solvers/olaFoamOF240/Make/options > options.test 2>&1 gzip < options.test > options.test.gz Then, run Code:
which blockMesh Code:
/sw/OpenFoam/OpenFOAM-2.4.0/platforms/linux64Gcc49DPOpt/bin/blockMesh Code:
module load OpenFoam/2.4.0 Best regards, zuodong |
November 13, 2016, 10:09 |
#8 | |
Bruno Santos
Rep Power: 128 |
echo $WM_ARCH echo $WM_PRECISION_OPTION Please inform your system's administrator that the module is incomplete, because at least "WM_ARCH" is undefined, although "WM_PRECISION_OPTION" might also be undefined, which are necessary when building custom source code. In your case, the quick fix is to run: Code:
export WM_ARCH=linux64 export WM_PRECISION_OPTION=DP The reason why I'm stating this is because the command I asked you to run with cpp gave this warning at the start of the command: Code:
<command-line>:0:0: error: macro names must be identifiers Code:
cpp -traditional-cpp -D path/to/file |
November 24, 2016, 08:48 |
installing OpenFOAM-2.4.0 on HPC (RHEL6.5)
#9 |
sudhakar singh
Rep Power: 10 |
Hi All,
I am a new OpenFOAM user and currently study to learn build wave model by using waves2Foam and OLAFoam. And I have installed the OpenFOAM/2.4.0 in the cluster linux system, which is Red Hat Enterprise Linux Server release 6.5 (RHEL). However, when I try to install OLAFoam as a example, the terminal reports wmake error as bellow. Code: <command-line>:0:1: error: macro names must be identifiers linux64Gcc49DPOpt/options:6: *** missing separator. Stop. wmake error: file 'Make/linux64Gcc49DPOpt/objectFiles' could not be created olaFoam compilation failed Additionally, I even though can not re compile a default solver (such as interFoam) by typing the wmake command, then it still has the same error as mention above. For this issue, I think this error might cause by rule formatting in the file from linux64Gcc49 folder. So, I enclose the file: /OpenFOAM-2.4.0/wmake/rules/linux64Gcc49/general below. Code: CPP = cpp -traditional-cpp PROJECT_LIBS = -l$(WM_PROJECT) -ldl include $(GENERAL_RULES)/standard include $(RULES)/c include $(RULES)/c++ Does anyone have a same problem with mine ? I really look forward to having some helps from you. Cheers! zuodong Hello zuodong, i wann to install openfoam-2.4.0 on RHEL 6.5, but i am not getting the OpenFOAM-2.4.0 package for RHEL 6.5. I am new to OpenFOAM. I need help from you for installing openfoam-2.4.0 on HPC (RHEL 6.5). cheers! sudhakar singh |
November 24, 2016, 08:50 |
#10 |
sudhakar singh
Rep Power: 10 |
Hello zuodong,
November 26, 2016, 11:10 |
Solved
#11 |
Lewis
Rep Power: 10 |
@Bruno Santos @Pablo Thanks for your help! Now, I can install the OF2.3.0 in RHL 6.5 and successfully compile the olaFoam solver with it.
Hi!@sudhakar singh. Good to see you here since we are using the same Cluster system. As for my way to solve this problem. I have installed the Version of 2.3.0 OF in the RHL 6.5 system. Please follow the instruction step by step: Link:https://openfoamwiki.net/index.php/I...HEL#CentOS_6.5 Please note that, to install the OF in the RHL 6.5, you need to be in the sudo list for some root behaviors. Otherwise, you have to let the system administrator to do so. Also, as for me, the cluster is not allow user to do some visual operations, i.e. I can not use the paraview to check simulation results. Therefore, I just finished all the installation until the step No.17. Also, I suggest you to install OpenFOAM in the root folder rather in your personal path. After the installation, using the bashrc file to module load the OF for your simulation. Cheers! Zuodong |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 02:36 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 14:28 |
