[swak4Foam] Using calculated swak expressions in another functions
Like Tree1Likes
  • 1 Post By gschaider
Old   October 21, 2016, 09:06
Default Using calculated swak expressions in another functions
Arsalan
arsalan.dryi is on a distinguished road
Dear Foamers,
How could I use the calculated swak expressions at other functions for example like below:
    createInterface
        type createSampledSurface;
        outputControl timeStep;
        outputInterval 1;
        surfaceName interface;
        surface {
            type isoSurface;
            isoField alpha.water;
            isoValue 0.5;
            interpolate true;
 surface
	ignore_unimplemented_simpleFunctionObject::movePoints true;
        type swakExpression;
        valueType surface;
        verbose true;
        expression "sum(area())";
        accumulations (
            min
	autowrite true;
    k
	aliases {
 		alphawater alpha.water;
        valueType internalField;
	variables (
	"thres=0.5;"//which cells to keep
	"VolC= sum (alphawater < thres ? C*vol() : 0);"
	expression "VolC/surface";
        accumulations (
		average
Here I want to use calculated area() from surface function in the k function, what kind of method should be implemented in this situation?
Moreover, we couldn't calculate area() in the k function separately because this function has an internalField valueType while using area() needs a surface valueType!
The second question is how could we use the runTime() value in the functions? I think it has a keyword but I don't remember that.
Any help and comment will be appreciated.
Regards,
Arsalan.
arsalan.dryi is offline   Reply With Quote
Old   October 22, 2016, 08:20
Assistant Moderator
Bernhard Gschaider
Originally Posted by arsalan.dryi View Post
Dear Foamers,
    createInterface
        outputInterval 1;
        surface {
            type isoSurface;
            isoValue 0.5;
            interpolate true;
 surface
        valueType surface;
        verbose true;
        accumulations (
            min
    autowrite true;
    k
    aliases {
    variables (
        accumulations (
        average
An external expression (in the variables list of k)
"surface{surface'interface}=sum(area());"
should do what you want (the surface-functionObject can go unless you need the value for postProcessing afterwards)
The function you're looking for is called time()
Regards,
Arsalan.
Both questions are answered in the (incomplete) Reference Guide in the Documentation folder. Especially the external expressions (with your nomenclature it can be a bit confusing which "surface" means what)
arsalan.dryi likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 22, 2016, 12:07
Arsalan
Dear Bernhard,
Thanks for your straightforward answer, works like a charm.
I'm sorry for that, that's my fault because I'd forgotten this reference completely.
You are right and the first question is explained in detail at page "24" of the reference pdf and the time() keyword is defined at the 14th page. So I should read this reference as soon as possible.
For now, do you have any idea about post-processing (or could be programming) problem that asked in below thread?!
http://www.cfd-online.com/Forums/ope...hase-flow.html
I'm very grateful to you for your helps.
Best regards,
Arsalan.
internalfield, surface, swak4foam, swakexpression
One more time: wall functions - SST CellZone OpenFOAM Pre-Processing 22 June 11, 2021 14:27
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 11:11
Wall functions vs. boundary layers kandelabr OpenFOAM Running, Solving & CFD 3 June 12, 2017 08:05
When I use the wall functions....! maximus Main CFD Forum 7 January 20, 2003 10:35
N-S equations:divergence free functions? D. Puigjaner Main CFD Forum 1 July 27, 2000 13:43
