[PyFoam] PyFoam BasicRunner producing LinuxMem error |
October 4, 2016, 17:09 |
Troy Snyder
Rep Power: 19 |
I am utilizing PyFoam to run a number of OpenFOAM cases wherein the value of the velocity on a boundary is parametrically varied. PyFoam works well but I continue to get the following error sporadically:
Getting LinuxMem: [Errno 2] No such file or directory: '/proc/19787/status' Code:
run=BasicRunner(argv=[solver,"-case",case],silent=True,noLog=True) run.start() OpenFOAM version 2.3.0. PyFoam version 0.6.5 Ubuntu 12.04.05 The script still runs just fine and produces the desired output, but I would like to eliminate this error. Any help would be much appreciated. |
October 5, 2016, 12:22 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
October 5, 2016, 12:29 |
Troy Snyder
Rep Power: 19 |
Thanks Bernhard. I thought it had to do with the speed with which the cases were running as inserting a few time.sleep() remedied the situation. I will keep this in mind when running small cases for debugging purposes.
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
