June 9, 2016, 08:12 |
Installing and using swak4foam
Frederik
Rep Power: 10 |
Hello cfd-online.com
I am trying to use swak4foam for a project, but I seem to miss an important step. I use Ubuntu14.04LTS and OpenFoam2.4.0 I installed the swak4foam version for OF2.0 and higher Code:
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x https://openfoamwiki.net/index.php/I...14.04_to_15.10 But when I try to use this function in my controlDict Code:
functions { pressureDrop { type patchExpression; variables ( "pOut{patch'outlet}=sum(p*area())/sum(area());"); accumulations ( min max ); patches ( inlet ); expression "p-pOut"; verbose true; } } Code:
--> FOAM FATAL ERROR: Unknown function type patchExpression Valid functions are : 4 ( patchProbes probes sets surfaces ) From function functionObject::New(const word& name, const Time&, const dictionary&) in file db/functionObjects/functionObject/functionObject.C at line 92. FOAM exiting Code:
export SWAK4FOAM_SRC=$HOME/swak4Foam_2.x/Libraries/ I am relativly new to Ubuntu and openFoam. Any help is deeply appreciated |
June 13, 2016, 03:26 |
Solved
Frederik
Rep Power: 10 |
If anyone in future has the same misconceptions as I do.
You can't just put in the functionObjects from swak4Foam in the ControlDict of a random case. You need the .libs too. There is a folder "Examples" in the "./swak4Foam/" main folder. Pick your desired option and C&P them into your file. |
of240, swak4foam, ubuntu14.04 |
