May 14, 2016, 03:15 |
Error:Install LEMOS in openfoam2.3.0
#1 | |
Qiaoling Wang
Rep Power: 11 |
Dear foamers,
I try to install LEMOS into openfoam2.3.0: http://www.lemos.uni-rostock.de/en/d.../cfd-software/ Quote:
/usr/bin/ld: cannot find -lgsl collect2: error: ld returned 1 exit status make: *** [/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libLEMOS-2.3.x.so] Error 1 + cd applications + wmake all solvers Making dependency list for source file scalarPimpleFoamLDMMS.C Making dependency list for source file PODSolver.C Making dependency list for source file scalarPimpleFoamMFM.C Making dependency list for source file scalarPimpleFoam.C could not open file PODODE.H for source file PODSolver.C due to No such file or directory could not open file ODESolver.H for source file PODSolver.C due to No such file or directory SOURCE=PODSolver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/libLEMOS-2.3.x/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PODSolver.o SOURCE=scalarPimpleFoamLDMMS.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/fvOptions/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -IlnInclude -I. -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarPimpleFoamLDMMS.o PODSolver.C:35:20: fatal error: PODODE.H: No such file or directory #include "PODODE.H" Code:
compilation terminated. SOURCE=scalarPimpleFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/fvOptions/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -IlnInclude -I. -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarPimpleFoam.o SOURCE=scalarPimpleFoamMFM.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/turbulenceModels/LES/LESfilters/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/fvOptions/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -IlnInclude -I. -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarPimpleFoamMFM.o make[2]: *** [Make/linux64GccDPOpt/PODSolver.o] Error 1 make[2]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/PODSolver' not remade because of errors. make[1]: *** [PODSolver] Error 2 make[1]: Target `application' not remade because of errors. make: *** [basic] Error 2 Code:
compilation terminated. make[3]: *** [Make/linux64GccDPOpt/postChannelExt.o] Error 1 make[3]: *** [Make/linux64GccDPOpt/vectorSnapshots.o] Error 1 make[3]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/vectorSnapshots' not remade because of errors. make[2]: *** [vectorSnapshots] Error 2 make[3]: *** [Make/linux64GccDPOpt/scalarSnapshots.o] Error 1 make[3]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/scalarSnapshots' not remade because of errors. make[2]: *** [scalarSnapshots] Error 2 make[2]: Target `application' not remade because of errors. make[1]: *** [POD] Error 2 make[3]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/postChannelExt' not remade because of errors. make[2]: *** [postChannelExt] Error 2 make[2]: Target `application' not remade because of errors. make[1]: *** [miscellaneous] Error 2 g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/postProcessing/postCalc -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/home/customer/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/LambdaCI.o -L/home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib \ /home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/postCalc.o -lfiniteVolume -lmeshTools -lgenericPatchFields -lOpenFOAM -ldl -lm -o /home/customer/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/LambdaCI make[1]: Target `application' not remade because of errors. make: *** [postProcessing] Error 2 make: Target `application' not remade because of errors. Thanks. Last edited by wyldckat; December 3, 2016 at 17:16. Reason: fixed link to LEMOS page |
May 14, 2016, 10:26 |
Qiaoling Wang
Rep Power: 11 |
Now I tried again to install LEMOS into Openfoam2.3.1. But the problem is till there.
Does anyone know why? |
May 15, 2016, 08:01 |
This error Code:
EXE_INC = \ -I$(LEMOSEXT)/libLEMOS-2.3.x/lnInclude \ ... |
May 16, 2016, 08:20 |
Qiaoling Wang
Rep Power: 11 |
Thank you for your reply, Alexey.
I am new in OpenFOAM. I installed two versions of OF. So I add the path of bashrc of LEMOS-2.3.x to the bashrc of OpenFOAM2.3.1. After I sourcing the bashrc of OpenFOAM2.3.1, and "echo LEMOSEXT,LIB_LEMOS_SRC" all give the right path. But after that, the ./Allwmake still give the wrong message like this: Code:
+ wmake libso libLEMOS-2.3.x /usr/bin/ld: cannot find -lgsl collect2: error: ld returned 1 exit status make: *** [/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libLEMOS-2.3.x.so] Error 1 Code:
/usr/bin/ld: cannot find -lLEMOS-2.3.x collect2: error: ld returned 1 exit status make[2]: *** [/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/PODSolver] Error 1 make[1]: *** [PODSolver] Error 2 make[1]: Target `application' not remade because of errors. make: *** [basic] Error 2 Code:
make[1]: *** [Make/linux64GccDPOpt/scalarPimpleFoamMFM.o] Error 1 make[1]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarPimpleFoamMFM' not remade because of errors. make: *** [scalarPimpleFoamMFM] Error 2 make[1]: *** [Make/linux64GccDPOpt/scalarPimpleFoamLDMMS.o] Error 1 make[1]: Target `/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarPimpleFoamLDMMS' not remade because of errors. make: *** [scalarPimpleFoamLDMMS] Error 2 make: Target `application' not remade because of errors. Code:
usr/bin/ld: cannot find -lLEMOS-2.3.x collect2: error: ld returned 1 exit status make[3]: *** [/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/vectorSnapshots] Error 1 make[2]: *** [vectorSnapshots] Error 2 /usr/bin/ld: cannot find -lLEMOS-2.3.x collect2: error: ld returned 1 exit status make[3]: *** [/home/customer/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/scalarSnapshots] Error 1 make[2]: *** [scalarSnapshots] Error 2 make[2]: Target `application' not remade because of errors. make[1]: *** [POD] Error 2 make[1]: Target `application' not remade because of errors. make: *** [postProcessing] Error 2 make: Target `application' not remade because of errors. |
May 16, 2016, 08:30 |
The error causes all other errors is:
/usr/bin/ld: cannot find -lgsl |
May 16, 2016, 08:42 |
Qiaoling Wang
Rep Power: 11 |
Thanks Alexey,
Maybe I will try to remove the -lgsl to see whether it affects or look into the two libraries you mentioned. Hope it works |
May 21, 2016, 11:36 |
Qiaoling Wang
Rep Power: 11 |
Sorry that I forget to post the result.
After I remove the -lgsl. the compile of the libLEMOS-2.3.x.so just work fine. Though there is some mistakes when I compile the included solvers in LEMOS, but that's ok since I mainly use the Inflow-generator. |
November 26, 2016, 08:04 |
Rep Power: 11 |
Hi Qiaoling
I have the same problem in compiling LEMOS how did you solve it? thank you |
December 3, 2016, 17:17 |
#9 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Which version are you trying to install, namely which OpenFOAM version and LEMOS version?
December 4, 2016, 17:18 |
#10 |
Rep Power: 11 |
Hi Bruno
I solved my problem I had not all the development tools installed the OpenFOAM version is 2.3.1 with LEMOS 2.3.x thank you |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 01:58 |
interFoam employed LEMOS inflow generator | dkjiao | OpenFOAM Running, Solving & CFD | 0 | February 20, 2017 04:12 |
[OpenFOAM] How to use paraFoam with ParaView4.2 in OpenFOAM2.3.0 | Detian Liu | ParaView | 0 | November 14, 2014 10:24 |
OpenFOAM2.3.0 on Intel Xeon Phi with OpenMPI-1.6.5 | manredd | OpenFOAM Installation | 1 | June 6, 2014 16:41 |
