[swak4Foam] access field variables in groovyBC
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 29, 2015, 08:17
Default access field variables in groovyBC
Mehtab
mehtab is on a distinguished road
I tried implementing temperature boundary condition at Inlet as:
T_s = T_0 + 1/C_p(Q_f/m" - Hv)
Here is my files
boundaryField
    outlet
        type            inletOutlet;
        inletValue      uniform 298.15;
        value           uniform 298.15;
    sides
        type            inletOutlet;
    base
        type            zeroGradient;
    inlet
    type                          groovyBC;
    valueExpression        "T0+((1/cpi)*((Qf/m)-Hv))";
    variables                  "T0=300;m{inlet}=phi;Hv=8500;Qf{inlet}=Qr;cpi{inlet}=cp;";
    value                        300;
controlDict
application     fireFoam;
startFrom       startTime;
startTime       0.0;
stopAt          endTime;
endTime         1.0;
deltaT          1.0e-2;
writeControl    adjustableRunTime;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.6;
maxDeltaT       0.1;
functions
    fieldAverage
        type            fieldAverage;
        functionObjectLibs ( "libfieldFunctionObjects.so" );
        enabled         true;
        outputControl   outputTime;
        fields
              U
                  mean on;
                  prime2Mean on;
                  base time;
          T
                  mean on;
                  prime2Mean on;
                  base time;
          CH4
                  mean on;
                  prime2Mean on;
                  base time;
          CO2
                  mean on;
                  prime2Mean on;
                  base time;
          H2O
                  mean on;
                  prime2Mean on;
                  base time;
          O2
                  mean on;
                  prime2Mean on;
                  base time;
libs (
    "libOpenFOAM.so"
    "libgroovyBC.so"
    "libgroovyStandardBCs.so"
    "libsimpleFunctionObjects.so"
    "libsimpleSwakFunctionObjects.so"
    "libswakFunctionObjects.so"
    "libswakPythonIntegration.so"
    "libswakTransportTurbFunctionPlugin.so"
I also checked my solver fireFoam createFields.H to check how Cp is being used.
createFields.H
volScalarField cp
        IOobject
            "cp",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        thermo.Cp()
I am getting this error:
swak4Foam: Setting default mesh
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM Warning :
    From function ConcretePluginFunction<DriverType>::exists
    in file lnInclude/ConcretePluginFunction.C at line 121
    Constructor table of plugin functions for PatchValueExpressionDriver is not initialized
--> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.1-2" :"field Qr not existing or of wrong type"
"Qr"
Context of the error:
- Driver constructed from scratch
  Evaluating expression "Qr"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1189.
FOAM exiting
What should I modify in me expressions? Have I defined cp correctly or should I change to thermo.Cp? Here Qr is totat radiative flux being calculated through radiation model. I am not able to understand the error. Please help
Thanks in advance....
[ Moderator note: moved from http://www.cfd-online.com/Forums/ope...-values-2.html ]
Last edited by wyldckat; September 21, 2015 at 15:42. Reason: Added [CODE][/CODE] markers and moderator note
mehtab is offline   Reply With Quote
Old   May 5, 2015, 14:54
Mehtab
Is it possible to access field variables (mass flow, temperature, heat flux) in groovyBC? If yes then how?
Please help
Thanks
Old   September 21, 2015, 16:09
Retired Super Moderator
Bruno Santos
Greetings firefoam,
I've had your questions on my to-do list for quite sometime now and only today did I finally manage to come to it .
The first issue I'm not able to reproduce. I used the tutorial case "combustion/fireFoam/les/smallPoolFire2D" as a test case for this and tried this condition:
    inlet
      type                          groovyBC;
      valueExpression            "T0+(Qf/m)";
      variables                  "T0=300;m=phi;Qf=Qr;";
      value                        300;
It worked fine without any problems. For future reference, I used OpenFOAM 2.4.x and swak4Foam 0.3.2.
I'm guessing the second question is related to the same problem, therefore I would need more details in order to be able to answer better to your question, because access to the "T" field should be straight forward and the other calculations could perhaps be achieved by using what's shown here: http://www.cfd-online.com/Forums/ope...tml#post446085 - post #5.
Best regards,
Bruno
Old   September 28, 2015, 14:12
Mehtab
Dear Bruno,
Thank you very much for looking at my problem. I also checked with OF 2.4.0 and swak4Foam 0.3.2. I took smallpoolfire3D tutorial case in OpenFoam.
First I defined my boundary condition exactly same as you and it was working fine. Then I added Cp term into my equation as below.
inlet
        type                          groovyBC;
        valueExpression            "T0+1/Cp*(Qf/m)";
      	value                        300;
But in this case the solver does not recognise Cp as mentioned in the valueExpression and gives error.
I referred to the link provided by you : http://www.cfd-online.com/Forums/ope...tml#post446085
I have added the following piece of code into my controlDict and try to run the tutorial.
loadThermo {
    type loadPsiThermoModel;
    correctModel false;
    //        correctModel true;
    allowReload false;
    failIfModelTypeExists false;
    outputControl timeStep;
    outputInterval 1;
cvField {
    type expressionField;
    autowrite false;
    outputInterval 1;
    expression "thermo_Cv()";
    fieldName CRRv;
cpField {
    autowrite false;
    outputInterval 1;
    expression "thermo_Cp()";
    fieldName CRRp;
My error is below:
Parser Error for driver PatchValueExpressionDriver at "1.6-9" :"field CRRp not existing or of wrong type"
"T0+1/CRRp*(Qf/m)"
- From dictionary: /home/maqsood/OpenFOAM/maqsood-2.4.0/tutorials/combustion/fireFoam/les/smallPoolFire3D/0/T.boundaryField.inlet
Evaluating expression "T0+1/CRRp*(Qf/m)"
FOAM exiting
Please suggest where I am doing it wrong.
Thanks
Old   October 2, 2015, 08:26
Mehtab
Dear Bruno and Ehsan,
I am facing the same problem from quite a long time. But after reading this thread, I realized that I might be missing some functions in my controlDict file.
I am attaching my controlDict file and Temperature Boundary condition file where I am using groovyBC.
PS: Bruno, I have referred to your post http://www.cfd-online.com/Forums/ope...-groovybc.html #3 and http://www.cfd-online.com/Forums/ope...-values-2.html #39. I read the full post and think that I must be missing some functions in my controlDict file That is why I am attaching it to have a look for you. Please look at the files. Your guidance will be really helpful.
My error message reads as below:
Parser Error for driver PatchValueExpressionDriver at "1.1-6" :"field thermo not existing or of wrong type"
"thermo:cp()"
Evaluating expression "thermo:cp()"
FOAM exiting
For the information I am using OF2.4.0 with swak4Foam0.3.2 and I am trying to solve the tutorial case of fireFoam :smallpoolfire3D.
Thanks in advance.
[ Moderator note: Moved from http://www.cfd-online.com/Forums/ope...-values-2.html ]
Old   October 4, 2015, 16:50
Bruno Santos
Quick answer: Please provide the complete "system/controlDict" file. I suspect something might be out-of-place and I can't guess what it is without seeing the full contents of the file.
Old   October 5, 2015, 06:40
Mehtab
Dear Bruno,
Please find attached my system/controlDict file and Temperature boundary condition file where I am using groovyBC.
Thanks in advance
Maqs
Old   October 10, 2015, 11:55
Bruno Santos
Quick answer: My guess was right, you defined the function objects in the wrong place. In theory, the correct content for "controlDict" is this:
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    object          controlDict;
startTime       0.0;
stopAt          endTime;
endTime         4.0;
deltaT          0.001;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
adjustTimeStep  yes;
maxCo           0.6;
maxDeltaT       0.1;
libs (
    "libgroovyBC.so"
    "libswakThermoTurbFunctionPlugin.so"
functions
    loadThermo
        type loadpsiThermoModel;
        correctModel false;
        //correctModel true;
        allowReload false;
        outputInterval 1;
    CvField
            dimension [0 2 -2 -1 0 0 0];
            autowrite false;//false;
            outputInterval 1;
            expression "thermo:Cv()";
            fieldName CRRv;
    CpField
            outputInterval 1;
            expression "thermo:Cp()";
            fieldName CRRp;
It feels like you didn't take good look into the tutorial cases that OpenFOAM has got for function objects. This is also explained in the OpenFOAM User Guide, section 6.2: http://cfd.direct/openfoam/user-guide/function-objects/
Old   October 13, 2015, 11:27
Mehtab
Dear Bruno,
Thank you very much for your support and guidance. I understood from this discussion that "loadPsiThermoModel" will provide all the fields which are defined in createField as thermo.p or thermo.T or thermo.psi etc. (mentioned in below code RoyalBlue color)
createFields.H
Info<< "Creating combustion model\n" << endl;
autoPtr<combustionModels::psiCombustionModel> combustion
    combustionModels::psiCombustionModel::New
        mesh
Info<< "Reading thermophysical properties\n" << endl;
psiReactionThermo& thermo = combustion->thermo();
thermo.validate(args.executable(), "h", "e");
SLGThermo slgThermo(mesh, thermo);
basicMultiComponentMixture& composition = thermo.composition();
PtrList<volScalarField>& Y = composition.Y();
const word inertSpecie(thermo.lookup("inertSpecie"));
Info<< "Creating field rho\n" << endl;
volScalarField rho
    IOobject
        "rho",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    thermo.rho()
volScalarField& p = thermo.p();
const volScalarField& T = thermo.T();
const volScalarField& psi = thermo.psi();
However if I want to access the value of mass concentration of a particular species eg CH4 in this tutorial case for modifying velocity BC, I cannot get it from this function "loadPsiThermoModel". I think the reason is that this multicomponent specie fraction is defined in a different way as shown below.
        mesh
Is there any way to access mass concentration of a particular specie in groovyBC using swak4Foam?
CH4Field
            dimension [0 0 0 0 0 0 0];
            outputInterval 1;
            expression "thermo_composition()";
            fieldName Ych4;
I tried this but did not succeed and getting errors. I tried loading other functions as well but no success. I think I am not using the correct function to load species mass concentration.
Please suggest.
Thanks
Maqs
Old   October 17, 2015, 12:04
Bruno Santos
Quick answer: If the CH4 field is registered in memory and accessible from the outside, it will show up when you test this function object: http://openfoamwiki.net/index.php/Ti...gisteredObject
Kummi likes this.
Old   October 23, 2015, 20:59
Mehtab
Dear Bruno,
Thanks a lot for you help and suggestions. With your help, my temperature boundary condition is working now.
But I tried to implement groovyBC for velocity BC using CH4 field only and this is not running and shows error. It is not calculating the velocity in first iteration only and stops just after rho calculations.
My controlDict file looks fine now. I think the problem is in U file only while defining groovyBC. I have attached the file for your reference. Please suggest, if you point out any error or mistake in files.
Thanks
Maqs
Old   February 4, 2019, 13:08
Scram_1 is on a distinguished road
Hi Mehtab,
Did you manage to fix your issue? If yes, then can you share your solution?
I'm facing a similar problem where my variable is not getting updated with time if I use groovyBC.
Best,
Scram_1
Scram_1 is offline   Reply With Quote
How to access the alpha.water field when coding a velocity boundary. zhxter OpenFOAM Programming & Development 4 December 24, 2021 08:57
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
[swak4Foam] groovyBC and access to fields of other Regions ancolli OpenFOAM Community Contributions 0 July 29, 2017 09:41
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 08:16
