[PyFoam] having problems with pyfoam Installation
Like Tree1Likes
  • 1 Post By gschaider
Old   November 30, 2014, 20:46
Default having problems with pyfoam Installation
vitor spadeto
vitorspadetoventurin is on a distinguished road
I am having problems with pyfoam Installation... after install... I made the test (from http://openfoamwiki.net/index.php/Co...e_installation):
HTML Code:
a@a-Aspire-V3-571:~$ python
Python 2.7.3 (default, Feb 27 2014, 19:58:35)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import PyFoam
>>> import PyFoam
>>> import PyFoam.FoamInformation
>>> print PyFoam.FoamInformation.foamTutorials()
do not appears nothing... should appears..
/home/nonroot/OpenFOAM/OpenFOAM-1.2-devel/tutorials
what is happening?
my OF: 2.3.0
pyfoam: 0.6.3
I tried to install as root and as regular user...
As root:
a@a-Aspire-V3-571:~/PyFoam-0.6.3$ sudo python setup.py install
[sudo] password for a:
running install
running build
running build_py
running build_scripts
running install_lib
running install_scripts
changing mode of /usr/local/bin/pyFoamReadDictionary.py to 755
changing mode of /usr/local/bin/pyFoamTestConfiguration.py to 755
changing mode of /usr/local/bin/pyFoamSurfacePlot.py to 755
changing mode of /usr/local/bin/pyFoamClearEmptyBoundaries.py to 755
changing mode of /usr/local/bin/pyFoamUpgradeDictionariesTo17.py to 755
changing mode of /usr/local/bin/pyFoamMeshUtilityRunner.py to 755
changing mode of /usr/local/bin/pyFoamRunner.py to 755
changing mode of /usr/local/bin/pyFoamCreateModuleFile.py to 755
changing mode of /usr/local/bin/pyFoamFromTemplate.py to 755
changing mode of /usr/local/bin/pyFoamComparator.py to 755
changing mode of /usr/local/bin/pyFoamDisplayBlockMesh.py to 755
changing mode of /usr/local/bin/pyFoamChangeBoundaryName.py to 755
changing mode of /usr/local/bin/pyFoamNetList.py to 755
changing mode of /usr/local/bin/pyFoamEchoDictionary.py to 755
changing mode of /usr/local/bin/pyFoamTimelinePlot.py to 755
changing mode of /usr/local/bin/pyFoamStandardLogAnalyzer.py to 755
changing mode of /usr/local/bin/pyFoamInitVCSCase.py to 755
changing mode of /usr/local/bin/pyFoamClusterTester.py to 755
changing mode of /usr/local/bin/pyFoamCreateBoundaryPatches.py to 755
changing mode of /usr/local/bin/pyFoamDecompose.py to 755
changing mode of /usr/local/bin/pyFoamExecute.py to 755
changing mode of /usr/local/bin/pyFoamWriteDictionary.py to 755
changing mode of /usr/local/bin/pyFoamUtilityRunner.py to 755
changing mode of /usr/local/bin/pyFoamSamplePlot.py to 755
changing mode of /usr/local/bin/pyFoamEchoPickledApplicationData.py to 755
changing mode of /usr/local/bin/pyFoamCompareDictionary.py to 755
changing mode of /usr/local/bin/pyFoamPrepareCase.py to 755
changing mode of /usr/local/bin/pyFoamVersion.py to 755
changing mode of /usr/local/bin/pyFoamAddEmptyBoundary.py to 755
changing mode of /usr/local/bin/pyFoamCompressCaseFiles.py to 755
changing mode of /usr/local/bin/pyFoamSTLUtility.py to 755
changing mode of /usr/local/bin/pyFoamIPythonNotebook.py to 755
changing mode of /usr/local/bin/pyFoamDumpConfiguration.py to 755
changing mode of /usr/local/bin/pyFoamPlotRunner.py to 755
changing mode of /usr/local/bin/pyFoamPlotWatcher.py to 755
changing mode of /usr/local/bin/pyFoamRedoPlot.py to 755
changing mode of /usr/local/bin/pyFoamPrintData2DStatistics.py to 755
changing mode of /usr/local/bin/pyFoamPVSnapshot.py to 755
changing mode of /usr/local/bin/pyFoamNetShell.py to 755
changing mode of /usr/local/bin/pyFoamPackCase.py to 755
changing mode of /usr/local/bin/pyFoamAddCaseDataToDatabase.py to 755
changing mode of /usr/local/bin/pyFoamPotentialRunner.py to 755
changing mode of /usr/local/bin/pyFoamClearBoundaryValue.py to 755
changing mode of /usr/local/bin/pyFoamUpgradeDictionariesTo20.py to 755
changing mode of /usr/local/bin/pyFoamCaseBuilder.py to 755
changing mode of /usr/local/bin/pyFoamChangeBoundaryType.py to 755
changing mode of /usr/local/bin/pyFoamRunAtMultipleTimes.py to 755
changing mode of /usr/local/bin/pyFoamSGECommand.py to 755
changing mode of /usr/local/bin/pyFoamClearInternalField.py to 755
changing mode of /usr/local/bin/pyFoamCaseReport.py to 755
changing mode of /usr/local/bin/pyFoamListCases.py to 755
changing mode of /usr/local/bin/pyFoamAPoMaFoXiiQt.py to 755
changing mode of /usr/local/bin/pyFoamUpdateDictionary.py to 755
changing mode of /usr/local/bin/pyFoamJoinCSV.py to 755
changing mode of /usr/local/bin/pyFoamBench.py to 755
changing mode of /usr/local/bin/pyFoamConvertToCSV.py to 755
changing mode of /usr/local/bin/pyFoamSymlinkToFile.py to 755
changing mode of /usr/local/bin/pyFoamSteadyRunner.py to 755
changing mode of /usr/local/bin/pyFoamClearCase.py to 755
changing mode of /usr/local/bin/pyFoamDumpRunDatabaseToCSV.py to 755
changing mode of /usr/local/bin/pyFoamMetaServer.py to 755
changing mode of /usr/local/bin/pyFoamPVLoadState.py to 755
changing mode of /usr/local/bin/pyFoamCloneCase.py to 755
changing mode of /usr/local/bin/pyFoamBuildHelper.py to 755
changing mode of /usr/local/bin/pyFoamModifyGGIBoundary.py to 755
changing mode of /usr/local/bin/pyFoamCopyLastToFirst.py to 755
running install_egg_info
Removing /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.3.egg-info
Writing /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.3.egg-info
vitorspadetoventurin is offline   Reply With Quote
Old   December 1, 2014, 13:04
Assistant Moderator
Bernhard Gschaider
HTML Code:
>>> import PyFoam
>>> import PyFoam
what is happening?
my OF: 2.3.0
pyfoam: 0.6.3
Is the FOAM_TUTORIALS-variable set on that shell?
As root:
running install
running build
running build_py
running install_lib
<<snip>>
What is the output pyFoamVersion.py gives you?
bkay likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 2, 2014, 06:44
vitor spadeto
" thank you for attention friend. "Is the FOAM_TUTORIALS-variable set on that shell?" Im sorry... I am a beginner.. can you tell me how to do it?
and results of pyFoamVersion.py are:
a@a-Aspire-V3-571:~$ pyFoamVersion.py
Machine info: Linux | a-Aspire-V3-571 | 3.11.0-26-generic | #45~precise1-Ubuntu SMP Tue Jul 15 04:02:35 UTC 2014 | x86_64 | x86_64
Python version: 2.7.3 (default, Feb 27 2014, 19:58:35)
[GCC 4.6.3]
Python executable: /usr/bin/python
PYTHONPATH is not set
Location of this utility: /usr/local/bin/pyFoamVersion.py
 PyFoam WARNING on line 192 of file /usr/local/lib/python2.7/dist-packages/PyFoam/FoamInformation.py : Basedir /home/a/OpenFOAM for fork openfoam does not exist or is not a directory
Version () Fork openfoam of the installed 1 versions:
extend-3.1 : /home/a/foam/foam-extend-3.1
  This version of OpenFOAM uses the old calling convention
pyFoam-Version: 0.6.4
ALERT: Reported version (0, 6, 4) is different from hardcoded version (0, 6, 3) -> probably inconsistent library installation
Path where PyFoam was found (PyFoam.__path__) is ['/usr/local/lib/python2.7/dist-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/a/.pyFoam/pyfoamrc'), ('directory', '/home/a/.pyFoam/pyfoamrc.d')]
Configuration files (used): []
Installed libraries:
cython               :  No 	 Not used. Maybe will by used later to spped up parts of PyFoam
cProfile             :  Yes
docutils             :  No 	 Not necessary. Needed for RestructuredText to HTML conversion
Gnuplot              :  No 	 Not a problem. Version from ThirdParty is used
hotshot              :  Yes
ipdb                 :  No 	 Not necessary. Only makes debugging more comfortable
IPython              :  No 	 Not necessary. But the interactive shell may be more comfortable
matplotlib           :  No 	 Only Gnuplot-plotting possible
mercurial            :  Yes 	 version: 2.0.2
nose                 :  No 	 Only needed for running the unit-tests (developers only)
Numeric              :  No 	 Not supported anymore. No need to install it
numpy                :  Yes 	 version: 1.6.1
openpyxl             :  No 	 Not a problem. Only used for exporting pandas-data to Excel-files (advanced)
pandas               :  No 	 Not a problem. Only used for handling of advanced data-handling
ply                  :  No 	 Not a problem. Version from ThirdParty is used
profile              :  Yes
psyco                :  No 	 Not a problem. Acceleration not possible
PyQt4                :  Yes 	 version: 4.8.1
PyQt4.Qwt5           :  No 	 Only an alternate plotting back-end
scipy                :  No 	 Not yet used. Possibly use signal-fitting etc
Tkinter              :  No 	 Not a problem. Used for the old version of DisplayBlockmesh and some matplotlib-implementations
twisted              :  Yes 	 version: 11.1.0
vtk                  :  Yes 	 version: 5.8.0
xlwt                 :  No 	 Not a problem. Only used for exporting pandas-data to Excel-files
Library locations
cProfile             : /usr/lib/python2.7/cProfile.pyc
hotshot              : /usr/lib/python2.7/hotshot/__init__.pyc
mercurial            : /usr/lib/python2.7/dist-packages/mercurial/__init__.pyc
numpy                : /usr/lib/python2.7/dist-packages/numpy/__init__.pyc
profile              : /usr/lib/python2.7/profile.pyc
PyQt4                : /usr/lib/python2.7/dist-packages/PyQt4/__init__.pyc
twisted              : /usr/lib/python2.7/dist-packages/twisted/__init__.pyc
vtk                  : /usr/lib/pymodules/python2.7/vtk/__init__.pyc
Old   December 2, 2014, 08:18
Assistant Moderator
Bernhard Gschaider
The variable is usually set when you select an Foam-version on the shell. According to pyFoamVersion.py there is no Foam-version selected ("Version () Fork openfoam of the installed 1 versions:"). When you select one (by sourcing the etc/bashrc-file) everything should work as expected
[GCC 4.6.3]
cProfile             :  Yes
hotshot              :  Yes
profile              :  Yes
Library locations
[PyFoam] Problems with installing PyFoam Christoph_84 OpenFOAM Community Contributions 34 October 26, 2021 12:25
[PyFoam] unknown or ambiguous terminal type x11 Tobi OpenFOAM Community Contributions 6 August 13, 2020 12:09
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) immortality Lounge 2 May 24, 2014 04:05
Problems with installation batta31 OpenFOAM Installation 2 September 4, 2012 08:01
installation problems on upgrade from win 3.26 to mic Siemens 5 June 20, 2007 10:40
