[swak4Foam] groovyBC using swakExpression
Like Tree1Likes
  • 1 Post By osha
Old   November 16, 2014, 17:38
Default groovyBC using swakExpression
Kalli
osha is on a distinguished road
I am writing a BC for a patch in my computational domain using groovyBC which uses the average value of temperature on a faceSet created using topoSet utility.
I can write the average temperature on faceSet using swakExpression but I am not sure how to use it in groovyBC for a faceSet created from topoSet. Is it possible?
Instead, one can access the temperature of other patches in groovyBC but is it possible to access field variables like temperature on a faceSet.
Thank you for your insight and help.
osha is offline   Reply With Quote
Old   November 16, 2014, 19:07
Assistant Moderator
Bernhard Gschaider
It has been described a number of times. The latest instance would be http://openfoamwiki.net/images/7/7a/...icTraining.pdf sildes 152ff (just replace cellSet with faceSet)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 17, 2014, 02:45
Kalli
Dear Bernhard,
Thank you very much for pointing me to right direction. I apologize as I didn't pose the question as I should have. Your solution does answer the question I had asked in first post perfectly.
I think I should give you a little more background on what I am trying to achieve. I have developed a multiRegion solver which is similar to chtMultiRegionFoam. A simple representation of my case is shown below.
My sensor is a faceSet in different region, i.e. AIR and using the average temperature calculated on this faceSet I intend to calculate my boundary condition using an expression that I define using groovyBC on a patch defined in different region, i.e. SOLID.
As the faceSet is defined for the region AIR, it doesn’t get accessed by groovyBC on the region SOLID. I get an error
XYZ not found in table. Valid entries:
0
This is the reason why I evaluated the expression using swakExpression with a hope that it can be accessed by groovyBC like internalField.
Sorry again for curt explanation of my problem earlier.
Old   November 17, 2014, 06:09
Default Solved
Kalli
I think I have figured it out. If someone else is facing similar problem like the one described above, you can refer to the example multiRegionHeaterFeedback in Examples/groovyBC folder.
the syntax is like this
<nameOfVariable>{ faceSet'<nameOfFaceSet>/<nameOfRegion>} = <expression>
Bernhard, thank you very much for all the help!
Hamoon likes this.
Old   November 17, 2014, 06:10
Assistant Moderator
Bernhard Gschaider
Good. I was just going to point you to the same Example
Old   November 17, 2014, 06:23
Kalli
Thanks again Bernhard. As I explore OpenFOAM further I realize that no other tool improves FOAM's usability like swak4foam.
faceset, groovybc, gschaider, swak4foam, wyldkat
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 08:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 07:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 04:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 08:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 09:49
