[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue |
August 18, 2014, 06:40 |
Steve C
Rep Power: 13 |
Greetings
I'm having an issue installing swak4Foam 0.3.1 on OF2.2.2 & Ubuntu 12.04. During installation, I get the following in the log file: /opt/OpenFOAM/openfoam222/src/sampling/lnInclude/sampledSet.H:47:22: fatal error: coordSet.H: No such file or directory Second run of ./Allwmake attached (hopefully - first post here ). I understand this was an issue with earlier versions of swak4Foam and OF2.2.x as per http://www.cfd-online.com/Forums/ope...m-2-2-0-a.html . However, I'm assuming this shouldn't be an issue with version 0.3.1 & can't see any evidence of this from a forum search. The log file suggests I'm installing the expected version & have the right prerequisites. I have a couple of different OF installations & am wondering if this is tangling anything up. Doing the same installation into my OF2.3.0 directory results in the same error. Hope this is sufficient info, any clues appreciated. Thanks Steve |
August 18, 2014, 16:22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Steve and welcome (back) to the forum!
I've tested just now following the instructions from here: http://openfoamwiki.net/index.php/In...ling_On/Ubuntu - in my main machine with Ubuntu 12.04 and OpenFOAM 2.2.2, and I did not have any problems. The first error message: Code:
In file included from repositories/SetsRepository.H:51:0, from repositories/SetsRepository.C:37: /opt/OpenFOAM/openfoam222/src/sampling/lnInclude/sampledSet.H:47:22: fatal error: coordSet.H: No such file or directory compilation terminated. I suggest you take a quick look at this wiki page: http://openfoamwiki.net/index.php/In...with_the_Shell - there you'll find several details on how to have more than one OpenFOAM installation in your machine. Best regards, Bruno
August 19, 2014, 05:53 |
Steve C
Rep Power: 13 |
Hi Bruno
Thanks for your reply, and thank you also for your extensive posting, which has assisted me multiple times in the past. I agree it's an environment issue, and as you might have guessed I also have an older copy of OF installed (1.6-ext), and the search location for the file during installation ($FOAM_SRC/sampling/lnInclude/) does indeed correspond to the 1.6-ext installation, not for the required 2.2.2 installation ($FOAM_SRC/fileFormats/lnInclude/) for which I am installing swak4Foam. I use alias commands to source the different installations in the bashrc file, and during troubleshooting got rid of the alias altogether & just referenced the newer 2.2.2 installation. There are some "ghosts in the machine" with regard environment variables, which I knew about & still have to fix, but which I considered peripheral enough to not be likely to affect the swak4Foam installation. Obviously not the case in hindsight. Env & Export output attached for completeness, but I don't expect you to trawl through them. All the basic stuff ($FOAM_SRC etc) appears correct. What I don't have my head around yet is the best way to find the source of the offending environment variable. I would have expected that a search of the output from env or export would be likely to turn up the text string "sampling/lnInclude", but that doesn't appear to be the case. Not asking a specific question at this point - I obviously have some work to do & just wanted to thank you for your response. Regards Steve |
August 20, 2014, 07:59 |
Steve C
Rep Power: 13 |
Ha - OK, sorted it out in the end. I had my different OF installations nicely sorted out via alias commands at the end of the .bashrc file. I couldn't understand how I was getting cross-contamination between different version environment variables despite this.
I finally had a closer look at the entire .bashrc file, only to find a sneaky little source command as the FIRST line of the file, referring to the original installation. Obviously put there during my earliest stumblings around with OF & going unnoticed until the new OF installation. Pretty funny now, but I wasn't laughing earlier... |
[OpenFOAM.com] Multiple Installation Issue: Parallel Processing No Longer Works | dancfd | OpenFOAM Installation | 11 | November 20, 2018 16:08 |
Engrid 1.4 installation issue on Fedora 20 - VTK? | eaglemckenna | enGrid | 7 | June 15, 2014 08:24 |
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 | zordiack | OpenFOAM Installation | 1 | October 26, 2013 13:08 |
Issue installation OpenFOAM - libopen-rte.so.0 | Voyage_gui | OpenFOAM | 1 | August 12, 2011 03:46 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
