[swak4Foam] groovyBC and probe measurement
Like Tree2Likes
  • 1 Post By odellar
  • 1 Post By gschaider
Old   June 19, 2014, 08:54
Default groovyBC and probe measurement
Olie
odellar is on a distinguished road
I'm trying to use groovyBC to implement closed-loop control in a simulation. I have a probe (in the controlDict) set to record a pressure measurement at a particular position in the geometry, and wish to use this value in conjunction with groovyBC to perform some maths operation on the value of pressure at the probe at each timestep, and use this value to update the value of a particular boundary condition for the next timestep.
So far my thinking takes me thus far:
actuatorBoundary
type                     groovyBC;
valueExpression        "0.5*(probeReading)"; // Some function of the probe recording     variables                "probeReading *** NOT SURE HOW TO DO THIS? ***
value                     uniform (0 0 0);
Can anyone help me with the code to implement this? I can't find an example which does this sort of thing exactly.
Thanks a lot,
Olie
manuc likes this.
odellar is offline   Reply With Quote
Old   June 19, 2014, 09:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by odellar View Post
actuatorBoundary
type                     groovyBC;
Thanks a lot,
Olie
What confuses people here mostly is that you don't use a probe but a sampled-set. swak can't access probes for technical reasons (basically: probes don't want to be accessed). But a sampled set of type cloud is equivalent. Examples that do that in the swak-Examples are groovcBC/fillingTheDam and FromPresentations/cleaningTank. Also in the swak-presentation at PennState (see the swak-page) a similar thing is explained
manuc likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 20, 2014, 07:49
Olie
Oh okay - didn't realise that. I've not used a cloud type sampled set before - does this just go in the controlDict as the probe would? (Do you know where I can find some documentation on cloud's use?).
Okay so after some more reading and re-reading I think, after I've got a cloud sample correct, the groovyBC boundary in the 0/U file should look something like this:
actuator
   type                     groovyBC;
   variables              "pMeasurement@cloudSampler=p;"
   valueExpression   "10*p";             // Or *SOME* mathematical expression
   value                   uniform (1 0 0); // Or *SOME* initial conditions
Is this the right idea? (Note here I've assumed the same usage with a cloud sampled set as that when using a patch.
Thanks again,
Olie
****EDIT****
Oh no - found some documentation on using cloud and it appears you can only use this in sampleDict - so now I'm confused.. How do I use this during runtime so it samples (like a probe) at each time step such that groovyBC can then use the value?
Old   June 20, 2014, 12:50
Assistant Moderator
Bernhard Gschaider
actuator
   type                     groovyBC;
Thanks again,
Olie
****EDIT****
Have a look at the cleaningTank-example. It uses a cloud-set to control the run (control is probably a BIT more complicated than what you intend to do)
Old   June 23, 2014, 11:35
Olie
Okay thank you. I've tried to base my approach on this, and so far now have the addition of the following in my controlDict:
functions
    readpField {
        type readAndUpdateFields;
        fields ( p );
    createMeasurement
    type createSampledSet;
    outputControl outputTime;
    outputInterval 1;
    setName sensor1;
    set {
        type cloud;
        axis x;
        points (
            (0 -0.5 0.5)
in an attempt to 'sample' the value of p at the coordinates (0 -0.5 0.5) at each written timestep, and the following in a funkySetFieldsDict located in system:
expressions (
    buildP
        field p;
        create true;
When I run the solver however, it fails and says --> FOAM FATAL ERROR:
Field p does not exist
From function Foam::readAndUpdateFields::read(const dictionary& dict)
in file misc/readAndUpdateFields/readAndUpdateFields.C at line 128.
FOAM exiting
What am I doing wrong?
Thanks again, Olie
Old   June 27, 2014, 15:22
Olie
? Anyone?
Old   July 1, 2014, 13:26
Default Working (I think) but strange results.
Olie
I believe I've got it working now - I put this in the functions section of the controlDict:
createMeasurement
	outputInterval 1;
	setName sensor1;
	set {
		type cloud;
		axis xyz;
		points (
			(0 -0.5 0.5)
and made this the entry in the 0/U directory for the boundary I want to be controlled based on the measurement from sensor1:
actuator
	type groovyBC;
	variables (
		"pressureMeasurement{set'sensor1}=p;"
	valueExpression "0.01*vector(0,pressureMeasurement,0)";
So sensor1 is meant to measure the pressure at (0,-0.5,0.5), then multiply this value by 0.01 to give the velocity - this velocity value is to be used as a uniform velocity boundary condition for actuator.
I think it's *close* to working, but not quite. The attached image (hope the attaching works) shows the sampled pressure from sensor1, p_wall, the velocity on the actuator boundary v_act, and the ratio of p_wall to v_wall, which *should* be 100, given groovyBC is set to give v_act=0.01*p_wall, but it's more like 200.
Am I doing something wrong? Thanks!
Old   July 2, 2014, 18:45
Assistant Moderator
Bernhard Gschaider
createMeasurement
	outputInterval 1;
	setName sensor1;
	set {
		type cloud;
		axis xyz;
		points (
			(0 -0.5 0.5)
actuator
	type groovyBC;
	variables (
That looks strange. Should work. How do you measure the velocity on the boundary?
BTW: just to be sure make it "pressureMeasurement{set'sensor1}=average( p );" (I think otherwise it might break in parallel)
Old   July 3, 2014, 05:48
Olie
I sample velocity afterwards using the following in the sampleDict under sets:
actuator_velocity
    type        uniform;
    axis         z;
    start       (-0.015 0 0);
        end         (-0.015 0 1);
        nPoints     3;
I know these seems a daft way to sample a point but I've never worked out how else to do it! So given my case is a 2D geometry, so is length 1 in the z-direction (but with just one mesh cell in that direction), I sample a line in the z-direction with 3 points located at z=0, z=0.5 and z=1 and look at the middle one - any help on the proper way of sampling at a point would be greatly appreciated!
Oh thank you I'll put in average().
Also, can you use matrices in groovyBC expressions? Similar to how you can use vectors somehow? If so how do you do this?
Thanks a lot.
Old   July 3, 2014, 09:16
Default Also...
Olie
Also, I'm using some storedVariables for a boundary condition, which update themselves each timestep, something like storedVariable1 = 0.5*storedVariable1 (there's more to it, but that's the general idea). However my thinking is that it updates the value of the variable every computational timestep which is a variable time step - I only want it to update at every write interval - so how do I specify that it's only to update at, for example, every 0.5 seconds? NOT ever actual computational time step?
Thanks a lot again, Olie
Old   July 3, 2014, 16:22
Assistant Moderator
Bernhard Gschaider
actuator_velocity
    type        uniform;
    axis         z;
    start       (-0.015 0 0);
        end         (-0.015 0 1);
        nPoints     3;
Thanks a lot.
Sampling the point with a cloud like you did above is the way to do it. Without the average only the processor that has the point would have a value. That's why it is needed
matrixes are called tensors (3x3). swak supports all the operations on them OF supports (see the programmers-guide)
Old   July 3, 2014, 16:30
Assistant Moderator
Bernhard Gschaider
I don't think that mixing the physical (your BC) with the discretization (output-times) is a good idea. Solution would depend on how often you write something out.
You want your storedVariable1 to "decay" exponentially, right? A bit of fiddling around with deltaT() and exp() will give you a decay with the same rate (it is year 1 mathematics. So don't ask me for formulas. I don't want to embarrass myself)
Old   July 4, 2014, 07:32
Olie
Thanks I'll look into tensors.
No that was just an example of the manner in which I'm wanting to use storedVariables - what I'm trying to do with them is actually more complicated, using them as state values for a discrete time state-space controller. But this shouldn't matter - the point is I need it to only update storedVariables at certain times: the times when data is written.
Correct the solution will depend on how often it's written - this is CORRECT in my particular situation (don't ask why, unless you're really interested!). So is this possible?
Thank you for all your help so far! I dare say I'm at the final hurdle!
Old   July 5, 2014, 07:52
Assistant Moderator
Bernhard Gschaider
An example for discrete states would be in Examples/FromPresentations the cleaning-tank examples
General swak-Expressions have no function "outputTime()" that is true for times when OF does output (for the reasons above). What DOES have such a variable is the Python-integration
Old   July 7, 2014, 05:51
Olie
Okay thank you - where abouts is the code relating to these situated? Is it anything to do with the commonVariables file?
Thanks, Olie
Old   July 9, 2014, 15:05
Assistant Moderator
Bernhard Gschaider
Thanks, Olie
No. That is for common expressions between BCs (mostly for "smoothing" what goes out on one side to be used as input on the other side). Variables for the state are declared in system/controlDict in the defineState functionObject.
Old   July 14, 2014, 08:46
Olie
Thank you, this certainly helps, but I'm still not sure - just by reading the code in the example - how to actually use it.
My guess is to put something like this in controlDict:
defineState {
type addGlobalVariable;
outputControl runtime;
outputInterval 0.5; // to output every 0.5 seconds?
globalScope stateInformation;
globalVariables {
state1 {
valueType scalar;
value 0; // What does this mean?
state2 {
valueType scalar;
then I don't know where to go from there?
If it helps, the attached image shows what I'm trying to implement - note that state values x do not refer to some physical state (such as pressure, velocity etc), they're just values that are updated at each write interval according to x_k+1 = Ax_k + Bs_k, and in the image when I refer to 'timestep' I also mean write interval, i.e. some fixed interval (in my case 0.5 seconds).
Thanks
Old   July 22, 2014, 17:43
Assistant Moderator
Bernhard Gschaider
defineState {
globalVariables {
state1 {
valueType scalar;
state2 {
valueType scalar;
Thanks
That is a huge picture.
Anyway: For the meaning of value etc see http://openfoamwiki.net/images/c/c0/...rogrammers.pdf starting at page 30. A few pages later calculateGlobalVariables is explained (which would be how you get the sensor values). The groovyBC then will only have to get the global variables (that is also explained there)
groovybc, probe pressure
[swak4Foam] Error using groovyBC - 'parser error for expression driver' odellar OpenFOAM Community Contributions 4 September 21, 2015 12:51
[swak4Foam] groovyBC and probe problem, needing your help! wwbbit OpenFOAM Community Contributions 4 April 17, 2010 01:31
