[swak4Foam] installation problem with version 0.2.3
Like Tree2Likes
  • 2 Post By samiam1000
Old   May 7, 2013, 06:59
Default installation problem with version 0.2.3
Claudio
Claudio87 is on a distinguished road
Hi everybody!
I'm trying to install swak4Foam on OF-2.1.0, without success!
I downloaded the last version (0.2.3) - "Swak4Foam_2.x_release_0.2.3.tar.gz" ; after extracting, I went in the dyrectory and then I did ./Allwmake; the result gave me back an error.
Attached there is the log file.
Could anyone help me?
Thank you!
Best regards,
Claudio
Claudio87 is offline   Reply With Quote
Old   May 7, 2013, 07:51
Assistant Moderator
Bernhard Gschaider
Originally Posted by Claudio87 View Post
Hi everybody!
Thank you!
Best regards,
Claudio
Your textfile only has the standard-output, but not the standard-error-stuff (where the real problem is described ... you should see it on the terminal). To get all that into one file you usually do something like
./Allwmake 2>&1 >wmake.txt
Anyway. You say 2.1.0? Not 2.2.0? Because in that case it probably would have beent the problem described at ("Warning: seems like there ....")
http://openfoamwiki.net/index.php/Co...am#Downloading
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 7, 2013, 08:04
Claudio
Thank you for the quick answer!
First of all, yes, I'm sure my version of OF is 2.1.0.
Then, here there is the output from the terminal
claudio87@debian:~/Scrivania/Swak4Foam_2.x_release_0.2.3$ ./Allwmake 2>&1 > wmake.txt
In file included from /usr/include/bits/errno.h:25,
                 from /usr/include/errno.h:36,
                 from lex.fvexpr.c:41:
/usr/include/linux/errno.h:4:23: error: asm/errno.h: No such file or directory
In file included from lnInclude/FieldValueExpressionParser_location.hh:44,
                 from FieldValueExpressionParser.tab.hh:65,
                 from lnInclude/FieldValueExpressionDriver.H:49,
                 from lnInclude/FieldValueExpressionDriverYY.H:36,
                 from ../FieldValueExpressionLexer.ll:33:
position.hh: In function ‘bool parserField::operator==(const parserField::position&, const parserField::position&)’:
position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’
lex.fvexpr.c: In function ‘int parserFieldlex(parserField::FieldValueExpressionParser::semantic_type*, parserField::location*, void*, Foam::FieldValueExpressionDriver&, int&, int&)’:
lex.fvexpr.c:62496: warning: use of old-style cast
lex.fvexpr.c:62575: warning: use of old-style cast
lex.fvexpr.c:62592: warning: use of old-style cast
lex.fvexpr.c:62605: warning: use of old-style cast
lex.fvexpr.c:63665: warning: use of old-style cast
lex.fvexpr.c: In function ‘int yy_get_next_buffer(void*)’:
lex.fvexpr.c:63813: warning: use of old-style cast
lex.fvexpr.c:63845: warning: use of old-style cast
lex.fvexpr.c:63868: warning: use of old-style cast
lex.fvexpr.c:63881: warning: use of old-style cast
lex.fvexpr.c:63902: warning: use of old-style cast
lex.fvexpr.c:63902: error: ‘EINTR’ was not declared in this scope
lex.fvexpr.c:63927: warning: use of old-style cast
lex.fvexpr.c:63930: warning: use of old-style cast
lex.fvexpr.c: In function ‘yy_state_type yy_get_previous_state(void*)’:
lex.fvexpr.c:63956: warning: use of old-style cast
lex.fvexpr.c:63966: warning: use of old-style cast
lex.fvexpr.c: In function ‘yy_state_type yy_try_NUL_trans(yy_state_type, void*)’:
lex.fvexpr.c:63992: warning: use of old-style cast
lex.fvexpr.c: In function ‘int yyinput(void*)’:
lex.fvexpr.c:64028: warning: use of old-style cast
lex.fvexpr.c:64086: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprrestart(FILE*, void*)’:
lex.fvexpr.c:64109: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexpr_switch_to_buffer(yy_buffer_state*, void*)’:
lex.fvexpr.c:64131: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexpr_load_buffer_state(void*)’:
lex.fvexpr.c:64167: warning: use of old-style cast
lex.fvexpr.c: In function ‘yy_buffer_state* fvexpr_create_buffer(FILE*, int, void*)’:
lex.fvexpr.c:64188: warning: use of old-style cast
lex.fvexpr.c:64197: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexpr_delete_buffer(yy_buffer_state*, void*)’:
lex.fvexpr.c:64218: warning: use of old-style cast
lex.fvexpr.c:64224: warning: use of old-style cast
lex.fvexpr.c:64227: warning: use of old-style cast
lex.fvexpr.c:64229: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexpr_init_buffer(yy_buffer_state*, FILE*, void*)’:
lex.fvexpr.c:64255: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexpr_flush_buffer(yy_buffer_state*, void*)’:
lex.fvexpr.c:64291: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprpush_buffer_state(yy_buffer_state*, void*)’:
lex.fvexpr.c:64326: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprpop_buffer_state(void*)’:
lex.fvexpr.c:64363: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprensure_buffer_stack(void*)’:
lex.fvexpr.c:64390: warning: use of old-style cast
lex.fvexpr.c:64401: warning: use of old-style cast
lex.fvexpr.c:64421: warning: use of old-style cast
lex.fvexpr.c: In function ‘yy_buffer_state* fvexpr_scan_buffer(char*, yy_size_t, void*)’:
lex.fvexpr.c:64449: warning: use of old-style cast
lex.fvexpr.c: In function ‘yy_buffer_state* fvexpr_scan_bytes(const char*, int, void*)’:
lex.fvexpr.c:64502: warning: use of old-style cast
lex.fvexpr.c: In function ‘void yy_push_state(int, void*)’:
lex.fvexpr.c:64530: warning: use of old-style cast
lex.fvexpr.c:64539: warning: use of old-style cast
lex.fvexpr.c:64542: warning: use of old-style cast
lex.fvexpr.c: In function ‘void yy_pop_state(void*)’:
lex.fvexpr.c:64559: warning: use of old-style cast
lex.fvexpr.c: In function ‘int yy_top_state(void*)’:
lex.fvexpr.c:64572: warning: use of old-style cast
lex.fvexpr.c: In function ‘void* fvexprget_extra(void*)’:
lex.fvexpr.c:64617: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprget_lineno(void*)’:
lex.fvexpr.c:64628: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprget_column(void*)’:
lex.fvexpr.c:64641: warning: use of old-style cast
lex.fvexpr.c: In function ‘FILE* fvexprget_in(void*)’:
lex.fvexpr.c:64654: warning: use of old-style cast
lex.fvexpr.c: In function ‘FILE* fvexprget_out(void*)’:
lex.fvexpr.c:64663: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprget_leng(void*)’:
lex.fvexpr.c:64672: warning: use of old-style cast
lex.fvexpr.c: In function ‘char* fvexprget_text(void*)’:
lex.fvexpr.c:64682: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_extra(void*, void*)’:
lex.fvexpr.c:64694: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_lineno(int, void*)’:
lex.fvexpr.c:64706: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_column(int, void*)’:
lex.fvexpr.c:64721: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_in(FILE*, void*)’:
lex.fvexpr.c:64738: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_out(FILE*, void*)’:
lex.fvexpr.c:64744: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprget_debug(void*)’:
lex.fvexpr.c:64750: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_debug(int, void*)’:
lex.fvexpr.c:64756: warning: use of old-style cast
lex.fvexpr.c: In function ‘YYSTYPE* fvexprget_lval(void*)’:
lex.fvexpr.c:64769: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprset_lval(YYSTYPE*, void*)’:
lex.fvexpr.c:64775: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprlex_init(void**)’:
lex.fvexpr.c:64792: error: ‘EINVAL’ was not declared in this scope
lex.fvexpr.c:64796: warning: use of old-style cast
lex.fvexpr.c:64799: error: ‘ENOMEM’ was not declared in this scope
lex.fvexpr.c: In function ‘int fvexprlex_init_extra(void*, void**)’:
lex.fvexpr.c:64825: error: ‘EINVAL’ was not declared in this scope
lex.fvexpr.c:64829: warning: use of old-style cast
lex.fvexpr.c:64832: error: ‘ENOMEM’ was not declared in this scope
lex.fvexpr.c: In function ‘int yy_init_globals(void*)’:
lex.fvexpr.c:64850: warning: use of old-style cast
lex.fvexpr.c:64858: warning: use of old-style cast
lex.fvexpr.c:64871: warning: use of old-style cast
lex.fvexpr.c:64872: warning: use of old-style cast
lex.fvexpr.c: In function ‘int fvexprlex_destroy(void*)’:
lex.fvexpr.c:64886: warning: use of old-style cast
lex.fvexpr.c: In function ‘void* fvexpralloc(yy_size_t, void*)’:
lex.fvexpr.c:64942: warning: use of old-style cast
lex.fvexpr.c: In function ‘void* fvexprrealloc(void*, yy_size_t, void*)’:
lex.fvexpr.c:64954: warning: use of old-style cast
lex.fvexpr.c: In function ‘void fvexprfree(void*, void*)’:
lex.fvexpr.c:64959: warning: use of old-style cast
../FieldValueExpressionLexer.ll: In member function ‘virtual void Foam::FieldValueExpressionDriver::scan_begin()’:
../FieldValueExpressionLexer.ll:597: warning: use of old-style cast
../FieldValueExpressionLexer.ll: In member function ‘void Foam::FieldValueExpressionDriver::startEatCharacters()’:
../FieldValueExpressionLexer.ll:643: warning: use of old-style cast
../FieldValueExpressionLexer.ll: In member function ‘void Foam::FieldValueExpressionDriver::startVectorComponent()’:
../FieldValueExpressionLexer.ll:655: warning: use of old-style cast
../FieldValueExpressionLexer.ll: In member function ‘void Foam::FieldValueExpressionDriver::startTensorComponent()’:
../FieldValueExpressionLexer.ll:667: warning: use of old-style cast
lex.fvexpr.c: At global scope:
lex.fvexpr.c:64525: warning: ‘void yy_push_state(int, void*)’ defined but not used
lex.fvexpr.c:64554: warning: ‘void yy_pop_state(void*)’ defined but not used
lex.fvexpr.c:64567: warning: ‘int yy_top_state(void*)’ defined but not used
make: *** [Make/linuxGccDPOpt/FieldValueExpressionLexer.o] Error 1
With the command
I get back what I attached before...
Old   May 7, 2013, 08:56
Assistant Moderator
Bernhard Gschaider
The majority of these warnings is "normal". The problem is
which is strange as asm/errrno.h usually is in the same package as linux/errno.h (kernel-headers). Anyway this is not a swak-problem but with your system (have you compiled any other software before?)
With the command
OK. This differs from shell to shell. With bash it usually works
Old   May 7, 2013, 10:06
Claudio
Ok. I did everything again from the beginning (1st: ./Allwclean; then: ./Allwmake, again).
I attached the new log. There is something new, something you can see I could do for the installation?
I didn't compiled any other sotware before anyway.
Thanks!
Old   May 7, 2013, 11:12
Assistant Moderator
Bernhard Gschaider
Thanks!
The problem seems to be that a file that is needed by the compiler is missing. There is nothing to avoid using that on the swak/OpenFOAM-side. That's why I asked whether you ever compiled anything on that machine. Because I think that the compiler on your machine won't compile ANYTHING.
What Distro are you using?
Old   May 7, 2013, 11:49
Claudio
My distribution is
Linux debian 2.6.32-5-amd64.
I don't understand why it shouldn't compile!
Old   May 7, 2013, 12:21
Assistant Moderator
Bernhard Gschaider
My distribution is
The file that is missing (asm/errno.h) is included indirectly over 7 corners and probably will be needed by EVERY C++-program. My guess is that even a simple "Hello World"-program won't compile.
I don't have a Debian-based distro so I can't tell you which package the missing file belongs do. On my distro it is part of kernel-headers. Maybe someone with a Debian/Ubuntu can help you here
Old   May 7, 2013, 13:12
Samuele Z
samiam1000 is on a distinguished road
Maybe this is the package: linux-libc-dev
See here.
Regards,
Samuele
gschaider and wyldckat like this.
samiam1000 is offline   Reply With Quote
Old   May 8, 2013, 11:20
Claudio
Ok. Just to give you a feedback, I solved my problem about the installation.
I updated and upgraded all the system, and now it works. The installation seems done.
Thank you very much for your help!
Best regards,
Claudio
installation Problem - Linux distribution (Not a meshing problem) v_herw Pointwise & Gridgen 2 June 20, 2016 15:47
engrid 1.4 installation problem in openSUSE 12.3 and 13.1 taxalian enGrid 4 March 4, 2014 14:36
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 14:16
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 21:55
OF Installation Problem - Gcc Error Daniel Pilatti OpenFOAM Installation 11 April 19, 2009 23:07
