[swak4Foam] some questions about neibours of patches in groovyBC
Like Tree2Likes
  • 2 Post By wyldckat
Old   February 19, 2013, 18:12
Default some questions about neibours of patches in groovyBC
immortality's Avatar
Ehsan
immortality is on a distinguished road
in groovyBC contrib there are some definitions that i have some questions about.
1)is internalField of a field the value of that fiels at neighbour of the patch of boundary condition?
2)how can use Cn tool?does for instance Cn(p) gives us the value at neighbor or it just shows the place of neighbor?
3)what does coupled patch mean?then whats neighbourField?
Cn
neighbour cell centers of the patch
delta
Return cell-centre to face-centre vector
weights
Return patch weighting factors
3.5 Functions that need another field are:
snGrad
Gradient of that field
internalField
internal values of that field
neighbourField
neighbour values for a coupled patch
immortality is offline   Reply With Quote
Old   February 20, 2013, 10:36
Ehsan
no answers yet?
Old   February 22, 2013, 07:24
Ehsan
nobody can explain a bit about those?
Old   February 26, 2013, 18:58
Ehsan
Mr.Gschaider could you guide me about post 1?
Old   February 27, 2013, 06:28
Assistant Moderator
Bernhard Gschaider
To explain that more thoroughly than it already is explained would take me more time than I currently have
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 27, 2013, 10:51
Ehsan
all answers on it whenever is appreciated(sooner is better).
Old   March 3, 2013, 12:00
Ehsan
one who asks a question is a fool for five minutes,one who does not ask a question remains a fool forever
Chinese proverb
Old   March 3, 2013, 12:38
Retired Super Moderator
Bruno Santos
Hi Ehsan,
Quoting from wikipedia, on a topic from a favourite book of mine: http://en.wikipedia.org/wiki/Answer_...thing_.2842.29
[...] a group of hyper-intelligent pan-dimensional beings demand to learn the Answer to the Ultimate Question of Life, The Universe, and Everything from the supercomputer, Deep Thought, specially built for this purpose. It takes Deep Thought 7½ million years to compute and check the answer, which turns out to be 42. The Ultimate Question itself is unknown.
Basically, even if one asks a question, the quality of the answer will depend on the quality of the question.
And when it comes to Computational Fluid Dynamics it becomes even more true and complex, because simply asking what is "x" in "A*x=B", usually is not enough
OK, but mathematical existentialism aside, your questions on this thread will require you to help us help you. In essence, please prepare and share one or more simple test cases, where you and anyone else can help you figure out what each one of these functions/capabilities are.
The reason I ask you is rather simple: setting up cases usually takes longer than figuring out what each function really does!
So, I suggest you do the following steps:
  1. Create a simple cube shaped test case. It can be the tutorial "incompressible/icoFoam/cavity", modified to work in 3D. It can still be prepared to work with icoFoam, which is a rather simple case and has a low count of cells. potentialFoam is another good candidate, because it's fast and extremely simple.
  2. Create a few variants of this case:
    1. Remove the top moving wall patch. Add one outlet patch and an inlet patch. Doesn't matter much where the they are located, but keep in mind that opposite patches are good for some tests and perpendicular patches are good for other cases.
      Another detail is to keep all 6 sides of the cube assigned to a specific patch name, to make it easier to switch patches to walls and vice-versa.
    2. Based on 2.1, change the inlet patch for use groovyBC with a known expression that should work. Something like fixed value or height based. This will be used for figuring out each feature that groovyBC has got.
    3. Another one based on 2.1 or 2.2, but this time using the icoFoam with temperature, as described at http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam . The reason here is because it will make it easier to use the T field as "the other field" or perhaps the T field to be based on p or U.
  3. Share the cases here on this thread, in a state before generating the mesh. It's easy to clean up a tutorial, simply by running:
    foamCleanTutorials
Having access to these simple test cases will make it rather easy to then do some trial-and-error tests. It will also make it easy to know what the values stand for, because the cases are so simple that values can be calculated by hand.
Best regards,
Bruno
t.oliveira and Hamoon like this.
Problem with periodically repeated partially overlapping patches / nested cyclicACMI Nysander OpenFOAM Running, Solving & CFD 1 October 10, 2017 11:01
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" preibie OpenFOAM Meshing & Mesh Conversion 28 March 29, 2017 05:56
OF ext-3.2 new createPatch cyclics issue Jack001 OpenFOAM Pre-Processing 0 May 26, 2016 15:43
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
[snappyHexMesh] On which patches to set BC's for snappyHexMesh ? Talder OpenFOAM Meshing & Mesh Conversion 0 November 8, 2015 19:25
