[swak4Foam] Problem: Defining a linear scalar BC with groovyBC
Like Tree2Likes
  • 2 Post By gschaider
Old   July 11, 2012, 18:22
Default Problem: Defining a linear scalar BC with groovyBC
holp is on a distinguished road
Hello everybody,
I'm new in this forum, so first: greetings everyone
Im currently in my 4th semester and was assigned a project which mainly involves openFoam. I was hoping you could help me with a problem, it would be very much appreciated.
I have to define a linear temperature distribution as B.C. over the lateral surface of a cylinder (along the z-axis). Since I couldn't find any tutorial how to adapt / write my own B.C. (it's also a bit complicated for a beginner), I wanted to use groovyBC in order to define the boundary condition.
My problem: it doesn't work. Or put another way: I screwed something up.
I downloaded the swak4Foam GNU tarball, executed wmake all and added
libs ("libOpenFOAM.so""libgroovyBC.so");
to my controlDict.
I then tried to define my B.C in the 0/T file:
surface
         type     groovyBC;
         variables "zp = pos().z; m = pts().z ;minZ = min(m); maxZ =max(m)";
         valueExpression "200 + (zp) / (maxZ - minZ)) * 100";
         value uniform 1;
I also tried some simpler variants variants, like
valueExpression "100*pos().z";
and used the mag() function since I wasn't enterely sure whether I was dealing with scalar values. Nothing worked.
When I execute paraFoam before calculating anything, the default value uniform 1 is always being used. Executing my modified IcoFoam solver, openFoam gives a bug report and crashes.
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field T
Reading field U
Starting time loop
Time = 1
Courant Number mean: 0 max: 0
DILUPBiCG:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG:  Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
word::stripInvalid() called for word zp
    For debug level (= 2) > 1 this is considered fatal
I would appreciate any help / advise. Thanks a lot in advance.
holp
holp is offline   Reply With Quote
Old   July 14, 2012, 07:30
Assistant Moderator
Bernhard Gschaider
Originally Posted by holp View Post
Hello everybody,
to my controlDict.
surface
         type     groovyBC;
         value uniform 1;
That's alright I'm afraid: paraview does not know how to interpret groovyBC and therefor uses the old value (subsequent timesteps will always get value written and therefor be useful)
Create time
Reading field p
Reading field T
Reading field U
Starting time loop
Time = 1
holp
My bad: you tried to make it more readable by adding spaces. Now swak4Foam uses the variable name "zp " and OpenFOAM does not think this is a word. It occurred once before and I meant to fix this but I forget about such SEPs ("Somebody elses problem") if they are not in the Mantis. So for the time being remove the space before the = and you should be fine
Old   July 19, 2012, 09:46
Thank you very much for your answer, and also my apologies for answering one week late.
I managed to get it running by not defining the variables and only using the valueExpression term. But it's always good to know what caused the problem - might save me quite some trouble in the future.
I didn't expect that problem, because every (programming) language I ever dealt with absolutely ignores blank spaces.
You programmed swak4Foam? Respect, and thanks a lot!
holp
Old   July 19, 2012, 21:19
Assistant Moderator
Bernhard Gschaider
You're right (although one might say: Fortran 77 and Python take spaces very seriously. For different reasons ... and in one case I'd say: for good reasons). And swak ignores spaces everywhere else. But that part (variables) was a bit of an afterthought. And I'm a bit stubborn there: either a client demands a fix from me there or someone takes the time to write a bug report on the Mantis before I fix it
You're welcome. And as I said above: best "Thank you" is writing precise bug report on the Mantis, because the only three priorities for me to improve swak are: client demands, stuff that interests me and stuff that touches my ego (and keeping the number of bugs in the swak/openfoam-extend-Mantis low is important to my ego)
wyldckat and vitors like this.
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 06:57
[swak4Foam] GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Community Contributions 7 October 18, 2014 10:25
suitable boundary condition for scavenging process? immortality OpenFOAM Running, Solving & CFD 3 January 25, 2013 20:10
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
