Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
solids4foam shell elements/formulation
Like Tree4Likes
  • 2 Post By bigphil
  • 1 Post By bigphil
  • 1 Post By bigphil
Old   December 8, 2023, 06:33
Default solids4foam shell elements/formulation
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Question:
Can solids4foam handle shell elements? In particular, with a stacking of several orthotropic materials
Response:
Currently, solids4foam does not currently have general shell element implementation. The closest thing is simple flat "plate" implementation: https://github.com/solids4foam/solid...msPlatesShells and beam formulations: https://www.researchgate.net/publica...ial_curvatures and https://www.researchgate.net/publica...er_Beam_Theory.
Of course, there is a potential for shells to be added in the future, e.g. extend the Simo-Reissner beams to shells.
iBatistic and andyvaldes10 like this.
bigphil is offline   Reply With Quote
Old   April 9, 2024, 21:11
Default Use orthotropic materials in FSI
Andy Valdés
andyvaldes10 is on a distinguished road
But if one wants, for example, to change the material of the beamInCross tutorials for an orthotropic one, in order to do an analysis for a material made from 3D printing. Is this possible? If it is not possible: is it possible to make a single section of the model with orthotropic considerations (example plateHole) and for example use FSI approach to see the displacement in 2D? (with orthotropic material).
Thanks for your help
andyvaldes10 is offline   Reply With Quote
Old   April 10, 2024, 09:00
bigphil's Avatar
Philip Cardiff
Originally Posted by andyvaldes10 View Post
Yes, for finite strain (nonlinear geometry) solid models, you can use
type StVenantKirchhoffOrthotropicElastic;
E1   E1 [1 -1 -2 0 0 0 0] 200e9;
E2  ...
etc
and for small strain (linear geometry)
type orthotropicLinearElastic;
E2  ...
etc
andyvaldes10 likes this.
Old   April 10, 2024, 09:04
bigphil's Avatar
Philip Cardiff
The material directions can be either specified in mechanicalProperties if uniform (materialDirectionsX (1 0 0)) or as a field in the time directory if varying.
Old   April 10, 2024, 12:57
Andy Valdés
E2  ...
etc
E2  ...
etc
Thanks. i'll try
Shell Conduction mrjohnamore FLUENT 0 September 19, 2023 05:31
solids4Foam & FOAM-FSI farah.elias OpenFOAM 21 August 28, 2023 16:57
Multiphase Flow Problem in Shell and Tube Heat Exchanger Arhaam_Mubarak Fluent Multiphase 1 April 29, 2022 06:48
solids4Foam installation, foam-extend 4.0, ubuntu 18.04 baezacaljo OpenFOAM 0 July 17, 2021 01:35
shell conduction @ thin walls Jiri Beran FLUENT 0 May 18, 2008 15:08
