[solids4Foam] 3dTube failing with simple velocity inlet |
February 6, 2023, 11:05 |
Thangam Natarajan
Rep Power: 17 |
I am trying to setup a simple fsi problem of a 3d tube (with a small thickness). To achieve this, I started with the 3dTube tutorial and converted it from symmetry to a full 3D problem. I was able to run the "pressure pulse" fsi problem without any issues for this 3D tube.
Now, I want to provide uniform velocity bc at the inlet in order to mimic an artery/flexible tube. However, setting the inlet to Code:
type fixedValue; value uniform (0 0 1.0); Code:
type zeroGradient; Code:
Time = 5e-05, iteration: 3 Current fsi under-relaxation factor (wall): 0.05 Maximal accumulated displacement of interface 0: 192.863 GAMG: Solving for cellMotionUx, Initial residual = 0.999999, Final residual = 0.000243584, No Iterations 1 GAMG: Solving for cellMotionUy, Initial residual = 0.999996, Final residual = 0.00032079, No Iterations 1 GAMG: Solving for cellMotionUz, Initial residual = 0.999998, Final residual = 0.000547492, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) at ??:? #4 Foam::inv(Foam::UList<Foam::SymmTensor<double> > const&) at ??:? #5 Foam::leastSquaresVectors::calcLeastSquaresVectors() at ??:? #6 Foam::leastSquaresVectors::movePoints() at ??:? #7 void Foam::meshObject::movePoints<Foam::fvMesh>(Foam::objectRegistry&) at ??:? #8 Foam::fvMesh::movePoints(Foam::Field<Foam::Vector<double> > const&) at ??:? #9 Foam::dynamicMotionSolverFvMesh::update() at ??:? #10 Foam::fluidSolidInterface::moveFluidMesh() at ??:? #11 Foam::fluidSolidInterfaces::IQNILSCouplingInterface::evolve() at ??:? #12 ? in "/nethome/tnatarajan6/OpenFOAM/tnatarajan6-9/platforms/linux64GccDPInt32Opt/bin/solids4Foam" #13 ? in "/lib/x86_64-linux-gnu/libc.so.6" #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #15 ? in "/nethome/tnatarajan6/OpenFOAM/tnatarajan6-9/platforms/linux64GccDPInt32Opt/bin/solids4Foam" ERROR I am using OpenFoam 9.0 and solids4Foam 2.0 on Ubuntu 22.04 as no other combination of OF/solids4Foam/extend work on Ubuntu 22.04. What should be the approach to run a simple fsi such as a flexible tube with thickness, one inlet and one outlet? I have attached a MWE for the 3D tube that is failing with velocity inlet bc's. Any pointers is appreciated. Thanks. |
February 22, 2023, 14:25 |
Iago Lessa de Oliveira
Rep Power: 11 |
Hi Thangam,
Why do you used a velocity of 1.0 m/s in the inlet? Is that only a test? FSI simulations may be very sensible to the boundary conditions, so what may be the case is that this velocity is too high for the overall physical setup you are using, which would cause large deformations in the solid domain at the initial coupling iterations, thus leading to the divergence (note the huge maximum accumulated displacement in your log). So I would suggested trying with smaller velocities. That are also other tips for starting an FSI simulation that you can find in this post that may help you: FSI case does not converge, foam extend 4.0 Best, Iago |
flexible pipe, fsi, openfoam, solids4foam |
Simple parabolic velocity UDF with symmetry - what am I not understanding!?! | NPGrad | FLUENT | 1 | September 30, 2016 12:42 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 18:24 |
How to apply an outlet velocity profile to another inlet? | siw | FLUENT | 4 | April 10, 2013 12:19 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
