Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] Criteria for choosing time step
Like Tree1Likes
  • 1 Post By bigphil
Old   July 20, 2021, 11:07
Post Criteria for choosing time step
Mena Pillai
mgppsk is on a distinguished road
Is there any specific criteria for choosing the deltaT (time step) while simulating solids (seabed in my case) in openFOAM like the CFL criteria for fluids?
Thanks and Regards,
Mena
mgppsk is offline   Reply With Quote
Old   July 21, 2021, 06:10
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Thanks and Regards,
Mena
Hi Mena,
It depends on whether the time integration scheme used in the solid solver is implicit or explicit. If implicit, the solid solver is conditionally stable and any reasonable time-step can be chosen. If explicit, the solid solver requires that the time-step obeys the standard CFL criterion i.e. the Courant number needs to be less than 1.0.
Of course, the choice of time-step also depends on your desired temporal resolution/accuracy. This equally applies to both implicit and explicit approaches.
Philip
xiangxiang likes this.
bigphil is offline   Reply With Quote
Old   July 21, 2021, 06:24
Mena Pillai
Thank you so much sir
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
